The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: J4ck100 on June 3, 2021, 22:49
Title: MR2 TTE Exhaust Hiss / metallic rattle
Post by: J4ck100 on June 3, 2021, 22:49
Hi all
Recently, my TF300 TTE exhaust has been making a strange hissing noise, most notably when lifting off the throttle.
A noise is emitted that sounds like a hissing/ fizzing noise and/or small metallic rattling noise. Quite hard to describe it really.
Has anyone else experienced anything similar? Seems most prevalent when letting off from around 3k rpm. Thanks in advance
Title: Re: MR2 TTE Exhaust Hiss / metallic rattle
Post by: J4ck100 on June 3, 2021, 23:36
Should there be a bolt here? Perhaps this is the source of the noise if so?
https://imgur.com/a/dzKoGeA
Post by: wotugonado on June 4, 2021, 00:02
Have a search for heatshield rattle, its sounds like it's what your describing.
It's normally the rusty welds that you can't really see that have given up as well.
Post by: s12vea on June 4, 2021, 08:17
Most likely one of the heat shields or corrosion on one of the flanges causing it to blow.
Post by: Nvy on June 4, 2021, 08:53
My TTE had one of the internal pipes broken off, you could hear it if yanking it by hand or when emergency stopping.
Post by: tricky1138 on June 4, 2021, 09:06
Quote from: J4ck100 on June  3, 2021, 23:36Should there be a bolt here? Perhaps this is the source of the noise if so?
Sounds like a heat shield rattle.
Yes there should be a bolt there. I just found any bolt that fit and made sure it was tight.
You might also want to get a big jubilee clip and wrap it round the whole heat shield.
If you still get a rattle, then as others have said, it could be internal to the exhaust itself.
Post by: 1979scotte on June 4, 2021, 11:29
As above sort out the heat shield.
If that doesn't solve it the next most likely culprit will be the internals of the TTE exhaust.
Getting more and more common.
