The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: JohnGee on July 23, 2021, 14:21
Title: Drain holes behind side air vents
Post by: JohnGee on July 23, 2021, 14:21
I've had the car just over a couple of years, so decided that having a look at and a clean out of the drain holes behind the side air vents might be a good idea (and a bit overdue).
Tackled the near side first, all went to plan, white clips played along with me, quite a bit of debris removed with bent wire and hoover. Got the air vent back on, better fit than before, don't think one of the lugs was properly engaged previously.
Off side - different story. One of the white clips was (already) damaged and ineffective, no cover flap present, "mesh" immediately next to where cover flap should have been was seriously mangled, but no debris apparent at all, see most of that below.
(https://live.staticflickr.com/65535/51330561164_7ea9cf5d30_b.jpg) (https://flic.kr/p/2mcUxvf)
There wasn't a lot of debris in the sill area of the car, I tried using the wire but could recover no debris at all from further within the pipework, I tried using the hoover, not sure if that was any more successful, I suspect not.
So my questions are,
Thanks for any help or advice you can offer.
Title: Re: Drain holes behind side air vents
Post by: Joesson on July 23, 2021, 14:54
@JohnGee
My drain cleaning exploit resulted in my loosing a spacer piece in the void. I replaced that with a section of ball point pen barrel.
The flap I believe is to stop ingress from outside and may prevent / reduce possible insect colonisation.
I was otherwise fortunate in my venture and so cannot offer further, other than that www.vehicleclips.co.uk offer a wide range of clips.
Post by: JohnGee on July 23, 2021, 15:34
@Joesson
Yes, I spotted the spacer piece in the body of each intake, near side was a bit loose, but stayed in place, off side was much more secure.
Re colonisation, with global warming, goodness only knows what type of creatures will be living / thriving / breeding in my car in the near future!
Will have a look at the site you suggest.
Thanks for your help.
Post by: Joesson on July 23, 2021, 15:44
@JohnGee
T'was my offside spacer that was loose and was lost!
Post by: JohnGee on July 23, 2021, 15:57
Quote from: Joesson on July 23, 2021, 15:44@JohnGee
Good job your ingenuity - that was a very neat solution - got you out of trouble.
Post by: Gaz mr-s on July 23, 2021, 16:18
You're quite lucky they weren't worse John having not been touched in two years.... either the car is garaged or never parked near trees....?
If you pour water at the hood 'corners' it should immediately appear on the ground.
You were maybe using a 'soft' wire, but be careful, - the drain bags are easily punctured.
Post by: Joesson on July 23, 2021, 16:29
Quote from: JohnGee on July 23, 2021, 15:57
Thank you. But, I was the only one present when the original was lost!
Post by: JohnGee on July 23, 2021, 16:42
Quote from: Gaz mr-s on July 23, 2021, 16:18You're quite lucky they weren't worse John having not been touched in two years.... either the car is garaged or never parked near trees....?
Yes, certainly garaged for last 2 years and I understood the previous owner garaged it as well. Will get a jug of water and see what happens ...
Post by: JohnGee on July 23, 2021, 16:44
Quote from: Joesson on July 23, 2021, 16:29
Don't be so hard on yourself - you exhibited near genius!
Post by: Joesson on July 23, 2021, 17:30
Quote from: JohnGee on July 23, 2021, 16:44
OK I'll settle for being nearly a genius!
As a Sales Trainer once said, "Never look surprised when the buyer gives you the order".
Post by: JohnGee on July 23, 2021, 19:15
Quote from: Joesson on July 23, 2021, 17:30
Apologies, typo, I meant to say you were probably near a genius when you came up with that idea. Sorry.
Post by: Joesson on July 23, 2021, 19:24
Quote from: JohnGee on July 23, 2021, 19:15
No apologies necessary. Near/ nearly, genius and reference to myself on the same page even, where were you when I needed encouragement?
Post by: JohnGee on July 23, 2021, 19:30
Quote from: Joesson on July 23, 2021, 19:24No apologies necessary. Near/ nearly, genius and reference to myself on the same page even, where were you when I needed encouragement?
Somehow, I doubt that you've ever needed encouragement.
I was probably at the Horatio P Farnhill Home for the Bewildered, as an inmate, not a member of staff.
