The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: moca2cv on July 25, 2021, 10:07
Title: Knobbly bits on back of pads
Post by: moca2cv on July 25, 2021, 10:07
Bear with me here... So whilst losing copious amounts of sleep over why my brakes just don't seem to be doing the biz (squishy pedal - stopping power there, just feels rubbish) after changing pads and discs and bleeding the system, I have:
- bled more
- changed calipers all round
- fitted braided hoses
- changed the MC
- bled some more
It's still squishy. Yay. So last night I did a lot of googling about pedal feel with yellowstuffs, and lots of people have lots of different things to say, but one stuck in my mind in particular as the pads were just wrong and didn't quite work with the brakes on this particular car. So then I get to rewinding all I've done on the car and I am 99.9% sure the rear pads do not have the knobbly bits on the back that slot in to the piston.
Now I didn't think anything of it at the time, handbrake is rubbish but as it's a track car I've not really worried too much about that, but reading up on it those knobbly bits seem quite important for the operation of the handbrake self adjust mechanism. But would they give a squishy pedal? If the handbrake isn't self adjusting does this hold the pistons further back than they should be, resulting in that vague feeling?
Any thoughts appreciated, this is driving me potty!
Title: Re: Knobbly bits on back of pads
Post by: 1979scotte on July 25, 2021, 11:43
Always found my handbrake was rubbish when I had yellow stuff.
Post by: Bossworld on July 25, 2021, 12:10
I've owned several other cars with a similar handbrake design to the MR2.
The rest of them hold with ease, and none of them have the rear dimples. From what I understand it acts as an anti rotation point to enable the internal adjustment mechanism to wind out, but we end up in MR2 world with all these weird and wonderful routines of having to wind out half a turn/ensuring alignment.
How worn down are the pads? If they were newly fitted then by having a near-interference fit anyway, I don't think it'd account for any spongy feeling
Post by: Ardent on July 25, 2021, 12:22
As above. Part of the whole self adjusting  mechanism.
Pads should be interference fit.
I have a sim thread. Stock pads. Brakes work. But would like a firmer pedal at the top.
My thread initial brake feel or something.
Some good points in there.
https://www.mr2roc.org/forum/index.php?topic=71434.0
Post by: moca2cv on July 25, 2021, 20:29
Quote from: 1979scotte on July 25, 2021, 11:43Always found my handbrake was rubbish when I had yellow stuff.
Perhaps the knobbly bits are to blame then!
Post by: moca2cv on July 25, 2021, 20:31
Quote from: Bossworld on July 25, 2021, 12:10I've owned several other cars with a similar handbrake design to the MR2.
They've done two track days, not new but not worn either. They've been consistently soft since fitting, throughout a bedding in process (at Brands 😁) and also at Llandow where the brakes got hammered by better drivers than me. Haven't changed a bit 😂
Post by: moca2cv on July 25, 2021, 20:33
Quote from: Ardent on July 25, 2021, 12:22As above. Part of the whole self adjusting  mechanism.
Thanks! Will have a read. I want to believe it's air, they felt fine before I swapped discs and pads, I've got more stopping power but terrible pedal feel, but maybe it is just the pads are duffers. I wonder if I can get some better pads before Thursday...
Post by: Ardent on July 25, 2021, 22:17
cannot recall the post now, but recently someone put a post up about yellows. They looked like they had melted.
Dodgy batch?
Search ebc yellow bound to find it. Looked like they were made of toffee.
Quote from: moca2cv on July 25, 2021, 20:29
As in. Lack of.
Post by: moca2cv on July 25, 2021, 23:07
Quote from: Ardent on July 25, 2021, 22:17cannot recall the post now, but recently someone put a post up about yellows. They looked like they had melted.
Dodgy batch?
I do recall that now you mention it. Mine don't look too bad, the paint bubbles badly but that doesn't stop you so not too fussed. There does seem to be a lot of variation in experience though, maybe their QC isn't all that?
Post by: Gaz mr-s on July 26, 2021, 01:07
Dodgy batch?
The guys with brake knowledge said they'd been abused....allowed to get too hot.
Post by: moca2cv on July 26, 2021, 08:30
Quote from: Gaz mr-s on July 26, 2021, 01:07
Dodgy batch?
Top effort 😁
Post by: Frank Rabbets on July 26, 2021, 08:38
Moca, in answer to your question the dimples should fit inside the recesses of the piston. If not, in my opinion, you could have a squishy pedal as the bad plate might be distorting under pressure before biting the disc fully.
Also try bleeding with the engine running so the brake servo gives a bit of a squirt.
I bet it'e those dimples though.
Post by: moca2cv on July 27, 2021, 08:27
Quote from: Frank Rabbets on July 26, 2021, 08:38Moca, in answer to your question the dimples should fit inside the recesses of the piston. If not, in my opinion, you could have a squishy pedal as the bad plate might be distorting under pressure before biting the disc fully.
Thanks Frank, the pads have no dimples though, so was wondering if that would affect anything other than the handbrake...
I've been on Spyderchat though and a chap mentioned that you could cycle the ABS with Techstream, so that's my next thing to do :)
Post by: Ardent on July 27, 2021, 09:16
Might be worth replacing the pads with those with the pins/lugs/nipples first.
Post by: Mr2paul on July 28, 2021, 15:21
Iv not heared any good things about yellow stuff. Apex brake really well and handbrake is perfect so I'd ditch those tbh and start again
Post by: 1979scotte on July 28, 2021, 18:55
Quote from: Mr2paul on July 28, 2021, 15:21Iv not heared any good things about yellow stuff. Apex brake really well and handbrake is perfect so I'd ditch those tbh and start again
I always liked yellow stuff on the road. Just parking that was the issue.
And that's on a turbo 1zz and a V6 so not exactly slow.
Post by: moca2cv on July 29, 2021, 00:48
They've been nice and consistent on the last two track days, so can't really complain too much! Another couple and they'll be ready to swap out, I've had old Yellows crumble so it's not a good idea in my books to leave them in too long.
I really don't believe my issue is down to the pads. I'll hopefully have Techstream up and running on the weekend to test the ABS, but I do have some random pads in the garage to swap in so will do some testing when I get a chance.
In the meantime, track evening tomorrow 😁
