The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: TheTigerUK on May 9, 2022, 21:27
Title: Oil change
Post by: TheTigerUK on May 9, 2022, 21:27
Do all the under engine covers need to be removed to do an oil change ?
Thanks, I should of looked last time I was under.
Title: Re: Oil change
Post by: Gaz mr-s on May 9, 2022, 21:32
Front one.
Post by: TheTigerUK on May 9, 2022, 22:06
Quote from: Gaz mr-s on May  9, 2022, 21:32Front one.
ps: Are the magnetic sump plugs worth fitting ? M12 x 1.25 ?
Post by: Topdownman on May 9, 2022, 22:14
Quote from: TheTigerUK on May  9, 2022, 22:06Thanks
If you are going to fit one, dont get a cheap one as the threads can strip.
You can get small magnets off ebay and pop one on the outside of the standard sump plug.
Post by: McMr2 on May 9, 2022, 22:21
Quote from: TheTigerUK on May  9, 2022, 21:27Do all the under engine covers need to be removed to do an oil change ?
Unless you have a proper lift, taking off the rear driver side wheel helps with access too.
Post by: TheTigerUK on May 9, 2022, 22:31
Quote from: McMr2 on May  9, 2022, 22:21Unless you have a proper lift, taking off the rear driver side wheel helps with access too.
Post by: Joesson on May 9, 2022, 22:38
Quote from: Topdownman on May  9, 2022, 22:14If you are going to fit one, dont get a cheap one as the threads can strip.
Have a look at Oil Filter Magnets, Motion Pro is one named supplier but they are on eBay from £1.99.
Not sure if sump plugs or oil filter magnets come with a chromium finish though John,  so best replace the engine under covers!
Post by: Ardent on May 9, 2022, 22:58
Quote from: Topdownman on May  9, 2022, 22:14You can get small magnets off ebay and pop one on the outside of the standard sump plug.
Which is what I have done. To date. Nothing on sump plug. Which is good.
Post by: Ardent on May 9, 2022, 23:01
@TheTigerUK
Your ramps will give you more than enough clearance.
Makes me smile. A trap door for the sump plug. But still need to remove nappy for filter access.
Post by: Petrus on May 10, 2022, 08:35
Quote from: Joesson on May  9, 2022, 22:38You can get small magnets off ebay and pop one on the outside of the standard sump plug.
I took that tip some years ago with a roll of dime sized neodymium magnets. Two on top of eachother and fingers crossed they don´t attract the shims from under the valve tappets  ;)   Their magnetic attraction is about a thousand times their own weight.
Do take care removing them as they material us véry brittle. Hence best a roll  ;D
Post by: Joesson on May 10, 2022, 08:43
Quote from: Ardent on May  9, 2022, 23:01@TheTigerUK
I may be cynical but having had my car "serviced" by my local Mr T on four occasions, I would observe that there is little visual evidence of the removal of the filter, whereas the cleanliness of the oil is evident from the dipstick.
Post by: Joesson on May 10, 2022, 08:48
Quote from: Petrus on May 10, 2022, 08:35I took that tip some years ago with a roll of dime sized neodymium magnets. Two on top of eachother and fingers crossed they don´t attract the shims from under the valve tappets  ;)
Can't claim the quote about EBay magnets on the sump plug, that was from @Topdownman. My offering was Oil Filter Magnets, that has received no comment.
Post by: TheTigerUK on May 10, 2022, 08:56
After fitting one to the outside of the plug have you ever tested it to see if the magnetic force goes through the plug ?
Post by: Topdownman on May 10, 2022, 09:27
Quote from: TheTigerUK on May 10, 2022, 08:56After fitting one to the outside of the plug have you ever tested it to see if the magnetic force goes through the plug ?
I have a gold plug one on the V6 and will put a magnet on the new car. I have a magnet on the motorbike but that is still being serviced by the dealer so dont know if there was any debris collected on the plug.
Post by: Petrus on May 10, 2022, 09:28
Yes.
On my motorbike it does not work as the sump ´plug´ is the bronze cap of the gauze filter.
Post by: Ardent on May 10, 2022, 12:32
I tend to recall.
@Carolyn attaches her magnet to the inside end of the sump plug.
