The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: LozB on April 13, 2024, 23:20
Title: Rear subframe welding?
Post by: LozB on April 13, 2024, 23:20
Hi there
Removed manifold and heat shield today on our 2001 and found a hole in the subframe.  See photos below.  Do you reckon this would be a MOT fail? Should I get it welded?
If so does anyone know a mobile welder who can fix whilst car is in my garage in south Brum.
Title: Re: Rear subframe welding?
Post by: Ardent on April 14, 2024, 08:25
Easy to say as not my money. But I would suggest replacing it.
Post by: Call the midlife! on April 14, 2024, 08:47
MOT aside I wouldn't even drive that until you get a replacement, usually they rot out underneath the frame in that spot so for it to have a hole in the upper surface I'd say it was about ready to snap in two.
You CAN get them welded but I'd be surprised if there was much metal to weld to in that area now.
Post by: Carolyn on April 14, 2024, 09:16
That one has rotted through at the opposite end from the usual spot (where the exhaust passes underneath the subframe).
That would indicate a thoroughly rotten item which is past saving.
Replacements (new and used) can be found.
Post by: J88TEO on April 14, 2024, 10:40
Quote from: Ardent on April 14, 2024, 08:25Easy to say as not my money. But I would suggest replacing it.
I have both PFL and FL subframes fro sale, if interested.
Will post some photos this afternoon.
Post by: Joesson on April 14, 2024, 19:10
@LozB
These maybe of interest or use :
The first link suggests supply sources
And the second includes a How To (with torque values in the last post )
https://www.google.co.uk/url?q=https://www.mr2roc.org/index.php%3Ftopic%3D72577.0&sa=U&ved=2ahUKEwjvj6iqp8KFAxVGaUEAHWBNBfYQFnoECAIQAg&usg=AOvVaw3SURw7tGOL6VrbrB8_E-xC
https://www.mr2roc.org/forum/index.php?topic=42248;sslRedirect#p496967
Post by: MrChris on April 16, 2024, 09:31
For what it's worth, my subframe was rotted on the opposite side (as @Carolyn mentions this is the usual place, near the exhaust). It was a bigger hole than this.
I took my subframe out, took it to a local garage and they welded a patch on for about £60.
So far it's held up for well over a year, multiple track days and one trip in to a tyre wall and more track days.
As always, your mileage may vary!
Post by: LozB on June 15, 2024, 10:48
Decided to give welding a go.  We checked out the rest of the subframe and it seems pretty solid.  MOT next week - fingers crossed.
Post by: MrChris on June 15, 2024, 18:39
Quote from: LozB on June 15, 2024, 10:48Decided to give welding a go.  We checked out the rest of the subframe and it seems pretty solid.  MOT next week - fingers crossed.
Had mine done like this but on the under side, has held up well over 2 MOTs. Fingers crossed for you
