I can see in my notes that the tail light bulb is "Tail light 580 /W5/5w", but can I just buy any bulb and the plastic does the colouring or does it have to be red tinted bulb?
Any downside to using LED?
Actually I think my notes might be wrong!!
I've got home now, taken the bulb out and it look bigger... and now that I'm the PC can search properly and I've just seen this:
Quote from: TheTigerUK on November 6, 2021, 21:28Stay away from LED :)
But if you want all the info:
https://www.mr2roc.org/forum/index.php?topic=47742.0
I thought I needed a 580 but not so sure now having read some of that thread, I will remove it tomorrow and see what it is, is the bulb tail and brake ?
Front side lights W5W, 501
Front indicators W21W, 580
Side indicator repeater (amber if you do not have amber lens) W5W, 501
Rear side light/brake light WY21W, 582 (side and brake in one lamp)
Rear high level brake light W5W, 501
Rear reversing light W21W, 580
Rear fog light W21W, 580
Rear indicator (amber) W21W, 580
Rear number plate W5W, 501
These look like the right thing.... https://www.amazon.co.uk/dp/B00BTFF53W
Don't think so. Pretty sure it's a combined stop/tail. It'll be a 5/21W
This, I think.
https://www.ebay.co.uk/itm/405306439887?_trksid=p2332490.c101875.m1851&itmprp=cksum%3A4053064398875a8b2d4f26b7477dbe34d6e56c02324d%7Cenc%3AAQAJAAABQEK7FTfzsGw0VauxYyX1IOHjsuXJ1NPjVWebvOca%252BJbVzh3VqcrGnLFKHjKk2M42BtfNs8bK1jFneKBZqmubi3KliOELM9t%252BdEci5gpDdslh7OhAfE6kkvM8fYp%252BKNxh7asSKmVIXikp%252FwLQXgA1sosUr1605l7HI8S5oyZePzwyUuMN3JTsiX2MARv9Lh8WjXbX%252B69mGz3AoRgDKaXJJfqxb30rZcgyBD6CQwjMZr52aED5PitLGdTcEQins1yAC6fOpVmUrZtHq%252BOUE8N6Fxm5sUi7dvIq3b2uVBjZBGoBPbP9RmO0BXnjHChGOzjbN366nNH0NNoSzCsqukk4SZknixdB6x7VllnVaqs%252BfkJHkWqnzfo7dbDp8jGxTDyKuLjkOwnZFNQ%252FiEmw8SNiSRsCa9Pquiqs7t2KFD%252BeC7Dk%7Campid%3APL_CLK%7Cclp%3A2332490&itmmeta=01JE4SWWZJP24EHBG4TYTEJNG4
I was definitely wrong - my first pick was Orange!!
You're partially right: it is the combined one brake light + tail light, but NOT that round bayonet-style adapter in your ebay link... I took it out the car, but the bulb just crumbled.... so all I really had to work with was the base and it is definitely the pinch style adapter from my link, just in the right colour...
I ordered the Amazon ones in my link... they arrive tomorrow and I'll check.
Quote from: BahnStormer on December 3, 2024, 00:01You're partially right: it is the combined one brake light + tail light, but NOT that round bayonet-style adapter in your ebay link... I took it out the car, but the bulb just crumbled.... so all I really had to work with was the base and it is definitely the pinch style adapter from my link...
It's not those though.....they're single filament going by the description
https://www.amazon.co.uk/Bosch-Pure-Light-light-bulbs/dp/B00TUURW4S?crid=2I2XWJS1MSVAI&dib=eyJ2IjoiMSJ9.fQyqcUM56c-OLz4V9_zFSMc1bO8B9W-79xXR3wERJSA_MNz9WMU_KClvYh1jxScejlO-m36-CDGj5ZYXwYfQMv-a7BjI3Vz41MpmsYrBfPae5rXaGbK9AJEklAhSR00WsT1ZMcscZiVYRHRXOj5HdOUu36ksGeI8FifwAuKnQlmwn7uwoAIjIj0jd8v10D-PhCsx9VsAv80d-D9EJa4uMvjNQ-LSy1c8rqTPMqe9C0g.ukkwb_TGentyHw58N0gY97StbVPTinY2-L-6ZuBkzpc&dib_tag=se&keywords=capless%2B5%2F21w&nsdOptOutParam=true&qid=1733185164&sprefix=capless%2B5%2F21w%2Caps%2C4141&sr=8-5&th=1
Quote from: Gaz mr-s on December 3, 2024, 00:16It's not those though.....they're single filament going by the description
Thanks - I've ordered those Bosch dual filament ones now!
The single filament ones didn't even give me a tail light... dual filament as per that link above work perfectly (or Halfords for £3 each):
Quote from: Gaz mr-s on December 3, 2024, 00:21https://www.amazon.co.uk/Bosch-Pure-Light-light-bulbs/dp/B00TUURW4S?crid=2I2XWJS1MSVAI&dib=eyJ2IjoiMSJ9.fQyqcUM56c-OLz4V9_zFSMc1bO8B9W-79xXR3wERJSA_MNz9WMU_KClvYh1jxScejlO-m36-CDGj5ZYXwYfQMv-a7BjI3Vz41MpmsYrBfPae5rXaGbK9AJEklAhSR00WsT1ZMcscZiVYRHRXOj5HdOUu36ksGeI8FifwAuKnQlmwn7uwoAIjIj0jd8v10D-PhCsx9VsAv80d-D9EJa4uMvjNQ-LSy1c8rqTPMqe9C0g.ukkwb_TGentyHw58N0gY97StbVPTinY2-L-6ZuBkzpc&dib_tag=se&keywords=capless%2B5%2F21w&nsdOptOutParam=true&qid=1733185164&sprefix=capless%2B5%2F21w%2Caps%2C4141&sr=8-5&th=1
Capless is type name.
