The Workshop => General => Topic started by: Bugster_MR2 on January 11, 2025, 21:14
Title: Reliable battery charger?
Post by: Bugster_MR2 on January 11, 2025, 21:14
Good evening.
I have several battery chargers:
CTEK 3,8A
CTEK 7A
Exide 7A
And a 4A digital charger/battery tender from Biltema (Scandinavias answer to Halfords.)
Both 7A charger turns on, seems to ba charging, but battery ends up empty after several hours of charging. The Biltema charger lights up the error lamp straight away when trying to charge my 45A Yaris battery in -7 degrees celsius. Battery measured 12V before charging, so it was definitely not dead. I then tried my newest CTEK which is a 3,8A, and it topped up my battery within 6-7 hours.
Bottom line: All of these chargers fail after a while. They are kinda expensive, and I ain't sustainable to keep buying new chargers every fifth year or so.
So, can anyone on here recommend a very good quality charger that will last for a long time and keep my batteries in ship shape? Mainly for charging ordinary lead, gel and AGM batteries.
Thanks,
Bug
Title: Re: Reliable battery charger?
Post by: Gibla on January 11, 2025, 22:08
Have used a Noco Genius 10/Noco Boost 70 for the previous 12 months following CTEK varieties.......seems very good at the moment
sorry for giving you 2 varieties...I cannot recall offhand which of these 2 that I own (ps it cost circa £150-£160)
Post by: Carolyn on January 12, 2025, 09:26
Just'cos it showed 12V does not mean the battery is good.  It could only be taking a very shallow charge.  I just replaced my battery, which would take a charge but was having difficulty cold cranking in low temperatures.
The difference in how quick the car starts is night and day.
Post by: Joesson on January 12, 2025, 10:42
@Bugster_MR2
Since 2011 I have run 2 cars, my Roadster and a diesel daily.
The Roadster spends 6 months of the year on SORN in the garage and the battery is disconnected on the negative side and left on charge or checked around once a month. Either way the Yuasa battery, bought 29/03/16, for £54.41 is currently ar 12.6V.
My daily, battery purchased in 2017, is at a similar state.
Both batteries have been maintained with the use of a voltage tester and a charger I got from Lidl for £13.00.
I believe that regular checking and charging to prevent damaging excessive discharge is the way to maximise battery performance.
Post by: ChrisGB on January 12, 2025, 17:04
I've been using a Noco charger for many years for AGM maintenance. It is an older model and quite chunky (I think it can deliver up to 15A) and it has been reliable.
Post by: Bugster_MR2 on January 12, 2025, 18:41
Quote from: Carolyn on January 12, 2025, 09:26Just'cos it showed 12V does not mean the battery is good.  It could only be taking a very shallow charge.  I just replaced my battery, which would take a charge but was having difficulty cold cranking in low temperatures.
Agreed. I have many cars and many batteries.
But I know for a fact three of my chargers are not working as they are supposed to/as they used to. And I want a quality item next time. :)
Post by: Bugster_MR2 on January 12, 2025, 18:45
Quote from: Joesson on January 12, 2025, 10:42@Bugster_MR2
Yep, I also disconnect and charge occassionally. I usually have my batteries for many, mamy years.
Post by: Alex Knight on January 12, 2025, 22:58
I'm using a Noco Genius 5.
I'm on my second, the fist failed after about 18 months and was replaced FOC under warranty.
Apart from that, zero issues. Would recommend.
Post by: Beachbum957 on January 13, 2025, 11:22
We have used Battery Tender by Deltran maintenance chargers for years, and only one failure and it was probably 20 years old.  They are often advertised as motorcycle chargers. I am not sure what models are sold in the UK, but we use a little 750ma on our MR2 and leave it connected if the car is going to sit for more than a week. We also have a 3 amp, which will bring up any battery that is still good.  The current battery is 7 years old and still load tests perfectly.  Noco also has a good reputation.
Post by: Oldguy51 on January 13, 2025, 15:58
I also have a Noco charger and it's very reliable and so far no problems
Post by: TheTigerUK on January 14, 2025, 18:47
I use the alternator in the 2 and it seems to keep it charged :)
