The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: ty222 on February 2, 2025, 21:17
Title: Cat convertor flexi
Post by: ty222 on February 2, 2025, 21:17
Hi all
The flexi part of my cat has degraded  and unwoven itself. Is it done for and needs to be replaced? Is there anything DIY that can be done?
Title: Re: Cat convertor flexi
Post by: McMr2 on February 2, 2025, 22:18
Quote from: ty222 on February  2, 2025, 21:17Hi all
Depends how far your DIY will take you! Mine aren't far away from this, plan is to take to a local fab shop and have some replacement flexi sections welded in as my cat still seems to be working.
Other option is an aftermarket replacement pipe/cat
Post by: Carolyn on February 3, 2025, 07:59
Your cat will be close to its sell-by date by now.  So,rather than a repair, a replacement might be a better option?
Cats2U do one that works very well.
Post by: bobo83 on February 3, 2025, 08:31
Mines are also bad and I have ordered two flexis like this https://www.profusionexhausts.com/weld-on-2-25-x-4-inch-exhaust-flexible-joint-repair-flexi-pipe-tube-flex/.
You'd have to have access to a metal workshop and a welder though.
Post by: SurreyMR2 on February 3, 2025, 15:45
I replaced mine recently with a zero item, bit cheap but beautifully made.
https://zeroexhausts.co.uk/products/
Scroll down the page. They are made to order.
I have his cat & back box.
