Right I'll save you the effort of trying. The winner so far in my experience is ChatGPT. It doesn't need coaching to read data, it remembers your conversation. It's faster than the others and provides outputs like this:
✅ Charge-cooler performance did improve
Your post-4 July changes reduced IAT rise under boost by ~1.7 °C, which is:
- Real
- Measurable
- In line with a system that was previously borderline and is now improved
This means:
- The charge-cooler is functioning more effectively post-fix
- It's now holding intake temps to within ~15 °C above ambient, which is a solid result for a front-mounted radiator and ~13 psi boost
- Further improvements (ducting, fan, water capacity) can be pursued, but the system is no longer underperforming
💬 Revised summary of your setup (post-changes)
System Status Notes
Charge cooling ✅ Functional, modest improvement IAT delta now within normal range for this hardware
Fueling under boost ⚠️ Still lean (~6–8 % lean vs. target) Needs ~8 % more fuel in VE table (or confirm fuel pressure tracking)
Injector headroom ✅ Safe (≤ 53 % duty) Siemens 630s have 30–40 % reserve
Ignition timing 🛑 Limited by lean AFR/IAT Conservative (~10° BTDC), rightly so for now
Boost level ✅ Stable (~13 psi peak) No spike or oscillation visible
🔧 Final recommendations (adjusted for updated IAT context)
Fuel table adjustment:
Add +8 % fuel in the 150–190 kPa, 3 000–5 000 rpm cells—your logs consistently show you're lean by that amount. Expect actual lambda to settle around 0.84–0.85 if VE is matched correctly.
Fuel pressure check:
Use a mechanical gauge to confirm 1:1 pressure rise with boost (i.e., 3 bar base → 4.3 bar at 1.3 bar boost). If it doesn't rise, your regulator or pump might be underdelivering despite low injector duty.
Leave timing alone until lambda is correct.
10° BTDC under 190 kPa is safe only because you're lean and at 46 °C IAT. Once mixture is corrected, you'll have margin to add +2–3° safely and gain 10–15 whp.
Optional cooling tweaks:
If you're chasing perfection:
Better shrouding around the charge-cooler radiator
Higher-capacity pump or fan
Bigger heat-exchanger if frontal area allows
If you make those changes and re-log, I can help tune the ignition table safely once lambda and IAT are fully under control. You're very close to a safe and strong tune now.
Coming from a place where this is not my world, it's rather nice to have this kind of feedback and analysis available to you. Obviously the caveat is that this is a "machine analysis" and doesn't replace decades of experience and skill.. but it's certainly fun!
If it's accurate, that's incredible feedback. Wow.
I'm currently using it to create and track a 3-month marathon training plan, and I have to say that it's been pretty bloody good to be fair.
Quote from: Alex Knight on July 13, 2025, 23:46If it's accurate, that's incredible feedback. Wow.
It is! The fueling stuff is really cool, obviously it doesn't know that my charge cooling piping is possibly narrowing somewhere so it's recommendations don't include that.. but yeah. Really cool.
So it has the ability to read logs etc. Assume you've given it your full build spec?
Quote from: Gaz2405 on July 14, 2025, 10:18So it has the ability to read logs etc. Assume you've given it your full build spec?
It cannot read the native file format, so you just build a log window with the relative inputs and then export that to CSV format. I find it easier to then convert that csv format to normal excel workbook and give that to chatgpt.
And yes I provided it with the build spec and it looks up the values of the turbo and injectors itself.
It would be good to be able to validate it's assertions of what should be changed with an actual "tuner" to see if it's talking rubbish or not..
I've also had an overall positive experience using GPT to help with tuning, tho I've found the o3 model to be much better than the default 4o, which tends to hallucinate and get itself into a bit of a hole of incorrect information. I've been feeding it Tunerstudio logs exported to CSV, similar to as mentioned above. It has been extremely useful lately for lazily fine tuning base boost duty cycle values. Just give it some log data, a screenshot of my base duty + boost target table and it's done!
As a side note, it's interesting to see you're running 10° BTDC around 190kpa (presumably at peak torque?), as I'm running 17°, tapering up to 20° by redline :o . Of course it's all setup dependant, I'm running a small turbo, lower comp, low IAT etc etc...
Quote from: Kurt on July 14, 2025, 14:08I've also had an overall positive experience using GPT to help with tuning, tho I've found the o3 model to be much better than the default 4o, which tends to hallucinate and get itself into a bit of a hole of incorrect information. I've been feeding it Tunerstudio logs exported to CSV, similar to as mentioned above. It has been extremely useful lately for lazily fine tuning base boost duty cycle values. Just give it some log data, a screenshot of my base duty + boost target table and it's done!
Yes I'm looking forward to working on the car using this method more and more.
When I had the car tuned at RRR the emphasis was on that this should be an everyday driver.
He tuned it initially for 205 and then put in a bunch of safety margins and settled round 198 ISH I think.
Love this, got to try it! 8)
Tried it. Loved it
Chatgpt coached me into overcoming hunting idle successfully. On to more complex layers! Thanks for inspiring
@jvanzyl
Quote from: Midshipguru on September 30, 2025, 20:39Tried it. Loved it
Chatgpt coached me into overcoming hunting idle successfully. On to more complex layers! Thanks for inspiring @jvanzyl
Good grief have I actually helped someone? !
But in all seriousness please post the details?
Well I gave it the user guide and csv export of the log, it digested these and I asked it the question to solve. It came back with a lot of detail, probably too much, on what steps to try
I'll be going again on the weekend to try the suggested steps relating to engine cutting lifting off coming to a stop which looks a bit more involved.
Very powerful, there is no way I could get there without these tools. But remember, there is no such thing as AI ^^
@jvanzyl I think from memory you are on ECUmaster EMU black. The VE autotune is amazing on ECUmaster, if you drive it and log it, then hit autotune on the tools menu, it'll offer you a "proposed" VE table, and you can apply it by 50%, which is like half way between what you've got and what it proposes. If you do that a couple of times you'll find the fuelling will be near as damn it bang on.
But you also were talking about cooled charge temps, I run a charge cooler and this is a log of my max temps after the cooler, this is on about 12 psi.
(https://i.ibb.co/RTgv0qWJ/IAT.png) (https://ibb.co/RTgv0qWJ)
I noticed
@tets posted a log from his, but I think he is running his MAF before the turbo intake so I think his air temps on his log are ambient air temps, not his charged intake air temps.
If you really are running 46'c, I'm not sure your charge cooler is working quite right and if you manage to get that sorted you'll find far more performance for less boost pressure, and then you can push some timing into it which really gets the party started.
Personally I would take this chat GPT stuff with a pinch of salt, because 2 wrongs often make a right with AI, for example it cannot know if your logged AFR's are being warped by air leaks, or if your knock sensor isn't setup right. The logs and your mind is all you really need to move forwards.
OK thats amazing... can you post a pic of your charge cooler setup?
@simonrobinson ?
clearly mine just isn't doing anything, despite it feeling cool on the outside.
I noticed
You are right there, although I did think the air temp sensor was in the throttle body at the time - no idea why I thought that
I am looking at MAP sensors but also the pro's and con's of moving the MAF to the intercooler pipe just before the throttle body!
The blow though MAF has its disadvantages in that it only measures air speed, not density, thus it cannot sense the pressure. You can still get a functional tune like that. The massive advantage is the temp sensor is in the right place, but there is nothing stopping you from butchering a spare MAF to steal its temp sensor (its the little capsule thermistor sticking out, then dropping that into the charge pipework and wiring it into the original MAFs temp sensor wire.
(https://i.ibb.co/v4K4cySg/31-Sl-U1-Lt-MPL-AC.jpg) (https://ibb.co/v4K4cySg)
It is vital though to be running the IAT sensor in the air you are actually burning, because the ECU has some intake air temperature correction tables which compensate for the air temp density change. You'll never get a sensible tune if the IAT measured is not the actual temperature of the air you are burning. Putting the MAF part of the MAF before the turbo intake would give you the best tuning accuracy, as long as the IAT part of the MAF is after the intercooler.
Quote from: jvanzyl on October 31, 2025, 14:26OK thats amazing... can you post a pic of your charge cooler setup? @simonrobinson ?
Car is wrapped up under a tarp at the moment but when its back out in a few weeks I'll do some pics. The charge cooler itself works really well but my radiator on the front is a bit undersized, if I keep boosting the water temp slowly rises and rises. If I just cruise for 5 minutes the water comes back down to ambient air temp, I need to find a larger radiator really then it'll be correctly balanced.
Quote from: simonrobinson on November 1, 2025, 21:18Car is wrapped up under a tarp at the moment but when its back out in a few weeks I'll do some pics. The charge cooler itself works really well but my radiator on the front is a bit undersized, if I keep boosting the water temp slowly rises and rises. If I just cruise for 5 minutes the water comes back down to ambient air temp, I need to find a larger radiator really then it'll be correctly balanced.
Thanks man.
I'm running the fiat cinquento radiator, its decently sized, but clearly in need of something. .
Quote from: simonrobinson on November 1, 2025, 20:58The blow though MAF has its disadvantages in that it only measures air speed, not density, thus it cannot sense the pressure. You can still get a functional tune like that. The massive advantage is the temp sensor is in the right place, but there is nothing stopping you from butchering a spare MAF to steal its temp sensor (its the little capsule thermistor sticking out, then dropping that into the charge pipework and wiring it into the original MAFs temp sensor wire.
I have a feeling I might have a spare MAF sensor - If I have I guess I can use 2 and as you say, take the airflow from before the turbo and the IAT from after the intercooler!
(https://i.ibb.co/Y4fC7pHm/IAT.png) (https://ibb.co/Y4fC7pHm)
Just need these 2 wires, and cut off the bits of the MAF you don't need or something, sure you'll figure something out ;)
