The Common Room => Reader's Rides => Topic started by: Ch33zy on March 13, 2026, 17:25
Title: 02 Black 1.8t 20v
Post by: Ch33zy on March 13, 2026, 17:25
Hi. I'm due to actually make a start on converting my 02 PFL MR2 to Audi 1.8t power this week.
Thought I'd start a build diary of the process.
First things first a couple of pics of her before I start the work. I've owned her around 18 months and done a couple of mods in that time. Shes got a Malian bumper exit back box with only one of the 2 outlets fitted, a 4 branch manifold and whiteline anti roll bars,front and rear.
I've been busy in the garage refreshing a 1.8t engine from a 225 Audi TT, with a plan to fit it to the MR2 using one of the Zurawski conversion kits.
Engine was completely stripped right down. New crank, thrust and main bearings fitted. Cylinders honed and new piston rings installed. A set of uprated conrods were fitted in case I want to go for more power in the future. The rods being a known weak point on these engines over a certain amount of torque. Cylinder head was fully stripped down, skimmed and then rebuilt with new valve stem oil seals and the original valves. The whole carnk assembly balanced. New single mass flywheel,clutch and slave cylinder. The turbo was fitted with a new CHRA with a uprated 360 bearing. The whole thing rebuilt using new gaskets and stretch bolt where required. New cam belt kit and water pump fitted.
Title: Re: 02 Black 1.8t 20v
Post by: Ch33zy on March 13, 2026, 18:56
First part of doing the conversion required me getting hold of a suitable engine. I opted for buying a whole car, rather than an engine from a breakers or the internet, for a couple of reasons. One was so I had everything from the Audi that I might need and the second reason was that I could get to drive the car and prove it was running ok before I started.
After a bit of searching I found a 225 roadster for sale for sale on ebay that wasn't too far away from where I live. After a little day trip to Great Yarmouth I drove the TT home and then used it for the next month.
 The next step of the plan was to remove the engine and gearbox which was done over the course of a weekend.
Along with the engine and box I also removed all the wiring for the engine. The ecu has 2 plugs going to it. One of the plugs goes to the engine loom and is easily unplugged and all the connections to the engine left in place. The second plug goes to a couple of bits on the engine and to a bulk head plate which is just above the pedals inside the car. Undo this bulk head plate and there is a load of multi plugs under the plate. Undo all these plugs and you end up with both the wiring looms that go to the ecu. This wiring loom is required for the conversion. You also need to remove the entire throttle pedal assembly from inside the car, this is also required for the conversion.
Post by: Ch33zy on March 13, 2026, 19:19
This is the basic engine mount kit from Zurawski motorsport, comes with the engine mount plates and the parts needed to use the MR2 gear shifter with the Audi gearbox.
The conversion calls for the gearbox from a Quattro as one of the engine mounts uses the transfer box mounts.The transfer box is the big lump on the side of the diff housing and transmits power to the rear diff in a Quattro setup.
Remove the drive flange by undoing the allen bolt deep inside the centre of the drive flange, the transfer box is then unboltable from the gearbox.
The engine mount kit comes with a nice cnc'd peice of aluminium that bolts in place of the transfer box. This plate seals up the oil passages that let gearbox oil into the transfer box in the original set up. It also takes the drive flange oil seal and has threaded inserts on the rear of it to bolt the rear engine mount to. A different drive flange is required as the one that came with the Quattro setup will no longer work. A vw 02M409356A or 02M409356 will be needed instead. A new gearbox flange oil seal is also required 02M409189
Mount bolted in place.
Threaded inserts that the engine mount will bolt to.
Post by: Ch33zy on March 13, 2026, 20:26
The engine mount on the cambelt end of the engine simply bolts in the place of the original mount.
The gearbox end engine mount isn't quite as straight forward. There is a lump in the Audi parts of the mount that needs chopping off. This is pretty straight forward to do using an angle grinder and a file to clean up the cut.
Lump removed to provide a nice flat surface for the other part of the mount to bolt to.
The Zurawski conversion mount bolted in place. All the engine mounts are works of art, made from stainless steel using clever interlocking cnc design and some very nice TIG work.
Post by: Ardent on March 13, 2026, 21:19
All above my station, but I love this stuff.
I've had the VW 1.8T in a Golf IV, and a 1.9tdi 130 in the same, both happy smiley places to be.
I don't have the knowledge, skills or bollocks to do a conversion but admire those that do.
No idea how practical, but have always thought the the Alfa mito 1.4 cloverleaf (170) would be a great idea. (I also fully accept it might not) and or the 1750 (220) found in giulietta cloverleaf.
Post by: puma2 on March 14, 2026, 08:29
 :) that is some plans you got going on there :)  :)
fair play for haveing a go 8)
good that your starting with build thread :)
keep posting on here how you get on 8)  8)
Post by: Gaz2405 on March 15, 2026, 09:56
Great to see a 1.8t conversion thread going.
Im especially interested in the costs vs my boosted 2zz.
Post by: 105e on March 16, 2026, 05:23
What is the toothed wheel on the pulley for ?  i have actually watched most of their guides but i must have missed this...
Post by: cptspaulding on March 16, 2026, 11:31
I'll likely never follow suit but I'll be watching your thread with interest. More power to your elbow!
Post by: Ch33zy on March 16, 2026, 21:46
Thank you all for your positive input.
All the hard work has been done by Zurawski Motorsport. The parts are all available in separate chunks so you can either buy the parts for a particular part of the project or if you're resourceful you can come up with your own solutions. The costs of all parts are listed on their website. https://www.zurawskimotorsport.com  I've personally opted to buy all the parts of the conversion. Engine mounts, driveshafts, exhaust, charge cooler, deimmobilized Audi ecu (with cheeky little stage 1 tune), crank trigger wheel, fuel line conversion, coolant system conversion and conversion wiring loom.
They have also produced a series of 7 videos on youtube with step by step instructions on how to carry out each step.
The toothed wheel is to run the original rev counter in the MR2 instrument cluster. The crank sensor from the 1zz engine is used with a bracket that is part of the conversion kit for this purpose.
Didn't get much done on the actual car today. I had to move everything to a friends garage so a lot of the day was spent loading and unloading all the parts and engine into the van and then into the new garage.
I did manage to remove the rear lights and bumper before it got dark. The rear bumper bar is the one that came with the Malain exhaust. Due to the exhaust suffering from the 2 outlets not being level when fitted to the car I blanked one of the outlets off with a blanking plug fitted to the V band joint so it is totally reversible and can have the other tail pipe refitted. I went for having the outlet on the nearside because the exhaust requires the bumper trim cutting and the only available replacement on ebay at the time was the nearside one. Going to one outlet also quietened down the exhaust a little bit.
 I'm hoping to get the old engine out tomorrow.
Post by: Ch33zy on March 17, 2026, 21:47
Good progress today. Old engine has been removed and engine bay fully degreased and cleaned up. Removing the old engine was pretty straight forward but had fun cutting the drive shafts with my grinder. When I cut them, as they were nearly all the way through, they grabbed the grinding disc due to there still being forces transmitted through the drive shaft from the suspension components.  :o
PXL_20260317_153002954.MP.jpgPXL_20260317_153020544.MP.jpg PXL_20260317_152954897.jpg
I removed the crank, oil pressure and temp sensor from the 1zz as these will be required for the Audi engine. The crank sensor to read the toothed aux pulley to provide a signal for the rev counter, the oil pressure sensor for the oil light on the instrument cluster and the coolant sensor to send a signal for the temperature gauge. The conversion runs two coolant temperature sensors, the 1zz one for the temp gauge and the Audi one for the engine ecu.
Now the engine bay is clear the next step will be to modify the fuel system to provide a return fuel line to the petrol tank. With the engine out of the way it provides much better access to install this extra fuel line. Been a long day so that's a job for tomorrow.
Post by: Ch33zy on March 19, 2026, 22:02
Next job was to modify the fuel system. As standard the MR2 runs a 1 fuel pipe setup but the Audi engine requires an additional pipe adding for a fuel return to the fuel tank. Having the engine removed makes this job much easier. The fuel pump assembly requires removal for the fitment of the fuel return, access to this is under the plastic trim in the bottom of the drivers side cubby behind the seat.
 There's a metal cover that is stuck down with a putty like material, it can simply be levered up to uncover the top of the fuel tank and access to the fuel pump assembly.
 Once the wiring plug is disconnected and the retaining screws removed the fuel pump assembly can be taken out of the tank. The top of the fuel pump assembly is unclipped and has a hole drilled and tapped in the top to take a 1/8" threaded elbow.
Part of the conversion requires the removal of the toyota fuel pressure regulator and it being replaced with a blanking plug.
 I also fitted a new upgraded Walbro  GSS342-KL, as the original one was 24 years old and not designed for the Audi engines thirst, it seemed to be the sensible thing to do. The pump is slightly taller than the original one so the end cap of the fuel pump assembly needed trimming to make it fit.
 Once modified the assembly was refitted to the fuel tank and a rubber fuel hose passed through the hole in the engine bay, which houses all the pipes and cables, through to the access panel to the fuel pump. This was then connected to the new fuel tank inlet that was just installed.
In the engine bay the original fuel supply pipe has a quick release connection, the connection was disconnected and the fuel pipe cut off to reveal a barbed tail. This tail is then pushed into another rubber fuel hose and fastened with a fuel pipe clip. This fuel hose and the hose from the return are then cable tied to the steel pipe, the fuel tank vent, attached to the bulk head. That's the fuel system modded ready for the new engine.
Post by: Ch33zy on March 20, 2026, 21:13
I took the opportunity to degrease, wash, polish and wax the engine bay while the engine was out. There are a couple of studs on the near side of the engine bulkhead, one of them hold a guide bracket for the throttle cable.
I cut both of these off to give a bit more room when it comes to fitting the charge cooler, I also gentle massaged the middle of the engine bay bulk head with a hammer and a bit of wood. It bulges outwards into the engine bay so I basically popped it the other way towards the inside of the car to give a tiny bit more clearance between the inlet manifold and the bulk head. With that done the engine bay prep was done.
There are two bolts that hold brackets with the clutch hard line to the bulk head. I undid the top one of these bolts and bent the pipe gentle over around 50mm towards the drivers side, this gives clearance for the oil filter when the engine is in place.
Next step was to actually fit the engine into the car. I jacked the car up just higher than the top of the engine which was sitting on a wooden board on the ground. This step would be a lot easier if you removed the rear cross member, this gives much more room to get the engine in place with out having to jack the car up so high. I did it with the cross member in place.
 With the help of a friend we pushed the engine along the wooden board and roughly into position within the engine bay area. I the attached the engine hoist to the rear cross member using a heavy duty engine lifting bracket but I would recommend using a lift strap instead as it would be a bit kinder on the paint of the cross member.
 Using the crane I slowly lowered the car over the top of then engine until the car was back on the ground. I then unattached the engine hoist from the crossmember and attached it to the engine. The engine was then raised up into position and the 2 side engine mounts attached. The engine was now basically able to hold itself in the car so the engine hoist was removed. I then fitted the front and rear engine mounts. These were treated to Powerflex black inserts, these fill the voids in the factory rubber mounts to make the whole mount much stiffer in an effort to reduce engine rock backwards and forwards. The engine is now actually fitted to the car.
Post by: Ch33zy on March 20, 2026, 21:38
With the engine fitted I turned my attention to the fitting of all the other parts required. First off the exhaust. This is another part from Zurawski Motorsport and is hand made for the conversion. It's 3" stainless steel straight from the turbo and is a work of art. They offer a few different tail pipes to suit different tastes, personally I went for the through the bumper exit version. I also bought a discreet tail pipe which exits downwards behind the rear bumper, this one has a cat incorporated into it for mot time. A new front pipe to turbo gasket was used and a new lambda sensor fitted. I used a genuine bosch 0258007351, this comes with around 1.5m of cable and plugs straight into the wiring loom.
The exhaust is pretty straight forward to fit and is held together with v bands, it came with new blue exhaust hangers. Where the exhaust passes under the diagonal part of the body attention must be paid to the clearance there and if necessary the metal of the body work bent out of the way. In the long run I intend to wrap the exhaust but main priority is getting he car up and running first, then fine tune things.
Post by: Ch33zy on March 20, 2026, 22:26
I've made decent progress so far but still have plenty to do.
Jobs still to do:
Finish wiring.
Fit Audi throttle pedal.
Install drive shafts.
Battery tray install behind passenger seat.
Install 150A circuit breaker.
Get gear linkage bit welded.
Install gear linkage and cables.
Move tab on gear lever.
Bend clutch hard line from gear box.
Clutch pedal adjustment.
Bleed clutch.
Grommet for wiring into cabin from engine bay.
Coolant hoses.
Move fuel hoses-cable tie below vent pipe instead of on top of, hits alternator.
Mount n75 valve and pipe up.
Crank case breather and catch tank install.
Air filter and maf meter install in rear quarter.
Boost hose install.
Charge cooler install.
Charge cooler hose install.
Charge cooler rad install.
Charge cooler water pump install.
Post by: Ch33zy on March 20, 2026, 22:50
The first thing to sort out once the engine is fitted is the wiring. I purchased a wiring conversion loom which makes this a pretty straight forward job. These looms are professionally made and are all tested on an engine rig before being sold. Most of the action takes place behind the passenger seat. The Audi engine loom is passed through the hole where the wiring went for the original engine. I started with the biggest plugs, the ones for the ecu, first. The Audi ecu is used in conjunction with the toyota ecu, I think the toyota ecu is used to send signals to the instrument cluster for revs temp and oil light ect. The conversion wiring loom has genuine plugs that plug into the toyota ecu, Audi Wiring loom, throttle pedal and the toyota sensors that were fitted to the engine before it was fitted. The whole loom is pretty much self contained, it has a live feed that bolts to a post in the fuse box, an earth which bolts to an existing earth point and 3 wires which need soldering into the toyota loom at the wiring to the ecu.
Also a couple of pics of the crank sensor and trigger wheel set up.
Post by: Joesson on March 21, 2026, 10:19
@Ch33zy
Impressed with your progress and reporting and even more so that this work is being done Al Fresco.
Post by: Ch33zy on March 21, 2026, 22:16
Thank you Joesson. Yeah the whole job is being done on my friends gravel drive way with the use of his half length garage as a workshop. Luck has been with me this week as far as the weather is concerned but I do have a motorbike rain suit in case of rainy days. I have a 3 ton trolley jack, axle stands and an engine hoist, so no specialist gear used to get the engine in place. For the most part I've also been using my trusty Halfords socket set and breaker bar. I think if you had access to a proper workshop with a lift this conversion could be done in super quick time, a couple of days for 2 people.
I didn't get a huge amount done today. The clutch hose needed connecting so that was done first. The Audi gear box has a concentric slave cylinder inside the bell housing with the pipe for the fluid coming out of a hole near the starter motor. This pipe has a bleed nipple in a housing and the goes to a short length of steel hydraulic pipe that then screws into the flexi house. The original MR2 flexi hose has the same thread size as the rigid pipe from the Audi gearbox but the problem is that when connected straight to the gearbox the flexi pipe is really tight. In order to make the fit better the rigid pipe from the slave cylinder needs the be bent roughly 45°. I removed the plastic bleed nipple housing along with the rigid pipe. My friend happened to have a suitable bender for the diameter of the rigid pipe so I used this to bend the pipe to the required angle. The whole lot was refitted to the gear box and then the flexi pipe was fitted.
The only jobs left to do with the clutch is to adjust the pedal so it sits as high as it can go and then bleed it through with new fluid.
I also got pics of the the front and rear engine mounts fully assembled on the car. The front mount needs the Toyota part of the mount notching slightly with an angle grinder to clear a strengthening web on the Zurawski mount.
Post by: Ch33zy on March 21, 2026, 22:26
Something to take note of for anyone else doing this conversion is a small problem I had with the off side engine mount. The bolt that goes into the Toyota mount kept binding up before it was tightened down. Upon removing it to investigate I realised the bolt wasn't treaded all the way down its length. The problem was that the original mount is much thicker that the new Zurawski mount and the bolt was running out of thread before it was tightened. Easily remedied by putting a couple of thick washers under the bolt.
Post by: Ch33zy on March 21, 2026, 22:54
The other thing I got sorted today was to fit the drive shafts. The shafts are custom made for and supplied by Zurawski motor sport. The have a Toyota end for the hubs and an Audi end for the gearbox. They are supplied as just the shafts so I had to buy suitable cv joints to go on the ends. The conversion uses Rav4 outer cv joints as they are much beefier than the MR2 ones but still fit in the original hubs plus the abs rings are in the correct place.
The inner CV joints are from an Audi tt quattro. I purchased these from J&R CV joints, the inner are part no jr24 and the outers part no jr141. They are pretty straight forward to assemble, I can highly recommend getting a pair of cv gaiter pliers to help with this job. One thing to look out for with the inner gaiters is not to get the join part of the cv gaiter band in the way of any of the bolt holes that bolt the cv to the gearbox drive flange.
Feeling very smug that I had cracked them off before doing any thing else with the car I undid the hub nuts. This was done with the back of the car in the air and all weight off the rear wheels. The cvs were then hammered out and thrown on the scrap pile. The new drive shafts were then fitted. The new cvs were passed through the hubs and the nuts done up hand tight. The inner cvs were then wiggled into position and bolted up into place. Due to the bolt on arrangement it made the job very easy and none of the suspension needs to disassembled to make room also not a drop of gearbox oil in sight. The hub nuts will be tightened up to spec once the wheels are back on the ground.
Post by: Joesson on March 22, 2026, 09:55
Good to have a friend with tools such as that tidy pipe bender.
As for CV gaiter pliers those that came with the gaiter clips I bought were made of chocolate, fortunately my neighbour had the proper job.
Hope the weather stays dry for you.
Keep up the good work.
Post by: Ardent on March 22, 2026, 10:11
+1
Post by: cptspaulding on March 22, 2026, 15:52
Wow! You're not hanging about!
I'd still be congratulating myself on having bought all the bits  :))
Post by: Nomad on March 22, 2026, 19:56
I've changed the parking brake cables on the weekend and was proud of it.. Your work is insane!!
Post by: Ch33zy on March 30, 2026, 18:47
Yes indeed it is good to have friends with tools. Between a few of us we have quite a collection of weird and wonderful tools that have been collected over the years.  ;D
My CV gaitor pliers aren't the best either but were good enough to get this job done. The aren't as straight as they once were any more!
I was busy for quite a while congratulating myself on having bought all the bits but not having room in my living room due to all the boxes spurred me on to getting started on actually making a start on fitting it. :))
To be honest if you can change the hand brake cables you could probably do this conversion. The conversion parts are spot on and make life simple. Thomas who designed and sells these kits seems to have thought of everything, plus his handy work is top quality.
Post by: Ch33zy on March 30, 2026, 19:21
Not huge progress this weekend. The old engine and gearbox have gone to another home which is another job off the list. I managed to get the gear linkage fitted and connected to the gear cables. As part of the conversion you need to remove a linkage part from the original MR2 gear box. It has 2 arms on it and basically you have to remove one of the arms and weld a new arm on, which is supplied in the engine mount kit.
One of the arms looks like it has a fixing on its face while the other arm has a smooth face, I took an angle grinder to the arm which looked like it had a fixing. The arm with the hole in it, you want to keep the arm with the stud for the cable. It took a while because I was being extra careful with the grinder but eventually the arm came off. The new arm is a nice snug fit over the stub that's left, this needs to welded into place. I was going to farm this out to an professional but I got bored and had a go with my trusty 25years old no gas mig. This worked a treat so it was ready to fit the Audi gearbox.
As part of the engine mount kit there are a couple of bearing races that replace the rubber bushes on the end of the gear cables. When I attached them to the cables I used M8 washers to shim them where they attach to the gearbox. I assembled the cables and linkage without the washers first to work out the best position for the cable to keep the cables as inline as possible.
There is a plate that is supplied that bolts to the top of the Audi gear box to enable the modified Toyota rocker arm linkage thingy be to attached. Once these two were bolted to the box there's a rose jointed rod that connects to the Audi gear selector and the modded rocker. There are 2 new brackets that hold the outer gear cable, one of these bolts to the engine mount and the other bolts to an existing threaded hole in the gearbox. The cable that goes to the modded linkage is for the backwards and forwards movement of the gear stick. The cable that goes to the engine mount mount is the one that does the side to side movement at the gear stick. I can now sit in the car and select the gears. They do seem a bit close together side to side but I plan to mod the gear lever at some point to improve this by giving it some more side to side throw. There is also no gate to stop you selecting reverse but I can't see this being a problem. If it is I'm sure I can come up with something.
Post by: puma2 on April 1, 2026, 07:02
 :) fair play you going this a go with some fast input 8)  8)
keep going and keep thread build  you aredoing a good job :)  :)
Post by: Nomad on April 27, 2026, 10:07
Hi, any updates? I'm really invested  :o
Post by: Ch33zy on April 28, 2026, 20:20
In fact I do have a few updates. I might have been quiet on here but definitely still making forward progress with the car. ;D
With the new engine being drive by wire and the original set up using a conventional throttle cable something has to be done to convert the MR2 to drive by wire. I had saved the Audi throttle pedal when I scrapped the TT as I was aware it would be needed. The pedal itself has to be bent straight to work in the MR2. This was achieved by cutting a small bit of the throttle pedal, bending it into shape and then welding it back together. I bit of care is needed when welding it up not to get too much heat in the pedal and damaging the electronics, patients is required.
The original pedal has to be removed and the new one fitted using an adaptor bracket as the MR2 has 2 fixing holes and the Audi has 3.
 With the wiring loom conversion kit there is a wire supplied to connect the Audi throttle pedal to the wiring loom behind the passenger seat, this is best connected to the throttle pedal before it's fitted as space is tight once the pedal is fitted. I ran the cable above the pedals, under the centre console and onwards towards the compartment behind the passenger seat. I did have to cut a hole in the cross member behind the seat to route the wire, I used a 35mm hole saw. The hole had an appropriate grommet fitted to protect the wire from chaffing, 35mm being just big enough for the wires multiplug to pass through and plug into the Audi engine loom.
Post by: Ch33zy on April 28, 2026, 20:38
Part of the conversion is to modify part of the gear lever. I don't think this is essential but is supposed to give you a bit more throw from side to side. The rocker part on the side of the lever assembly needs to be removed from the main body as it needs welding and plastic isn't a fan of intense heat.
 Its pretty simple to disassemble but you with probably needs a new starlock washer to reassemble the lever. From memory it's a 10mm one that's required, I bought a tub of assorted sizes on ebay for a few quid. I then marked the rocker up as the idea was to remove approximately 12mm from it and then weld it back together.
Once again I broke out he trusty no gas mig welder and got busy modifying the rocker arm.
Once welded it was refitted to the lever assembly and the whole lot refitted to the car.
Post by: Ch33zy on April 28, 2026, 21:55
Next up is the air filter. The idea is to mount the filter under the passenger side rear quarter and connect it to the engine using silicone ducting. The rear quarter was removed and the factory air pipe pulled out along with a plastic duct thingy. There's a metal flap that is in the way so this was cut off with a grinder.
I used an adaptor from Creation Motorsport that clamps to the inlet of the turbo and smoothly takes the 51mm inlet of the turbo out to 80mm. From this adaptor I used a 45° silicone elbow to an aluminium tube which in turn is connected to the silicone ducting that goes out of the engine bay, behind the rear light and along the rear quarter. The ducting is supported with a couple of stainless steel rubber lined P clips.
The last clamp needs to have a hole drilled in the body work to mount it. This needs to be done with great care as the engine wiring loom is on the other side. Ideally the hole would have been drilled before the wiring loom was fitted but I did it after I'd fitted the loom. To be safe I used an nice thick bit of stainless steel sheet behind where the drill bit was going to come through. This did a great job of protecting the wires. I used a bolt that was longer than needed but with a nut wound all the way along it. This way I could get the bracket where I wanted it and use the nut to lock the bolt into position, giving it a bit of adjustability.
The mass air flow meter was connected to the ducting at one end and a K&N air filter fitted to the other, this was then clamped into the clamp. The wiring for the mass air flow meter cone through from the engine bay and plugs straight in.
Post by: Ch33zy on April 28, 2026, 22:16
Next up was to cut the bumper bar to accommodate for the exhaust wanting to occupy the same space. I needed to find the center of the exhaust pipe in relation to the bumper bar. Guessing the center of the hole was one option but I wanted a decent job doing so decided to use lasers. 8)
I used a 3" stainless disc and marked the center of it using a pair of compasses. This was then taped into the end of the tail pipe. I then used a builders cross line laser and set it up so the lines crossed on the mark on the metal disc.
 The tail pipe was then removed from the exhaust and the bumper bar fitted, the laser was then used to show where the centre of the exhaust was, as this wasn't on the bumper I had to strap a block of wood to the bumper bar. This was the centre for the hole saw I then used to cut the clearance hole in the bumper.
Once the hole was cut I could then fit the bumper bar. This will do for the moment but I will be revisiting it and welding some material back into the bumper to close off the cut. I need to be sure the exhaust clears it when the cars driven first though.
Post by: Ch33zy on April 28, 2026, 22:34
Next up is the oil catch cans. I had originally intended to run a tee piece to join the crank case breather to the breather on the cam cover and then on to an oil catch can. After watching Thomas talking about the subject on one of the Zurawski instruction videos I decided against running the 2 19mm diameter hose into one 19mm hose. I decided to fit an additional oil catch can to give the breathers room to work. I used the bracket from the charcoal filter thingy that connects to the fuel tank breather and modified it so the 2 catch cans could be fitted to it. I intend to get some more 19mm pipe so I can run the outlets of the catch cans to behind the back light and I will fit filters to the ends of the pipes. I also have fitted so silicone hose to the fuel tank breather pipe and run it to behind the rear light to route the fumes away from the engine bay.
Post by: Ch33zy on April 28, 2026, 23:06
The battery had to find a new home because the charge cooler needed the space. I decided to relocate it to the compartment behind the passenger seat. I used some long nuts to get a fixing to the body to mount the battery to. These were shimmed using washers to get them level.
 Next up I got a 20x30cm sheet of 5mm aluminium and drilled countersunk holes in it to match the position of the 3 long nuts fitted to the car. The sheet was then screwed down with countersunk screws to provide a flat base for a battery tray and clamp. I had purchased a resettable 150 amp circuit breaker that I wanted to fit so I made a bracket for this using some aluminium angle. I used some 25mm2 cable and suitable crimps to make a new positive cable that runs through the bulk head into the engine bay and to the live feed threaded post in the fuse box. The other end of this cable go to the the circuit breaker and onwards to the battery terminal. A new 25mm2 battery earth cable was made and run to a factory earth point near the seat belt reel. Both the new battery cables were covered in tough nylon over braiding, and the ends finished with heat shrink tubing, to offer some mechanical protection. I am aware that I will need to get a sealed battery at some point because it's in the cabin but the one I've got will do for the moment.
Post by: Ardent on April 29, 2026, 20:15
Great work.
Post by: Joesson on April 29, 2026, 20:38
@Ch33zy
Meticulous comes to mind.
But one question: How will you access the air filter?
Post by: shnazzle on May 3, 2026, 13:19
Quote from: Joesson on April 29, 2026, 20:38@Ch33zy
Given the size of that thing it's not a worry.
As they say in Russia; you don't access the air filter, that air filter accesses you
Post by: Topdownman on May 7, 2026, 08:35
Fantastic work, I look forward to hearing about the test drive, cant be long now!
Post by: Ch33zy on May 10, 2026, 20:17
It is a case of removing the rear quarter to access the filter but it only takes a few minutes to pop off.
Next job to tackle was the final wiring connections. I'd already trial fitted the loom to work out where everything needed to go but hadn't fitted a grommet where it goes through the bulkhead or soldered the wires that need to be joined to the Toyota loom. I reused the grommet from the Toyota loom and got all the multiplugs through it, which was quite a squeeze but I got there in the end. All the various plugs were reconnected, there are 3 wires that need to be soldered to the MR2 loom near the ecu, that was the wiring completed. The conversion loom made it a very easy job.
The cooling system was next. I had a set of Mishimoto red silicone hoses for the MR2 that I'd bought when I first got the car but hadn't got around to fitting so now was a perfect time to do so. I bought the cooling system conversion kit which came with a silicone hose to go from the thermostat housing on the front of the block to the one of the metal pipes under the car to the front.
There's a metal pipe on the front of the engine block that comes from the back of the thermostat housing, this is connected to a t piece. The branch from the tee goes to the lower feed on the expansion tank and the other outlet goes to the metal pipe nearest the passenger side under the car.
The Final metal pipe from under the car is connected to a cast aluminium 45° housing. The original mr2 coolant pipe is used but cut in 2 just after the first elbow from the engine. Also coming from this housing is an outlet to the temp sensor housing on the head and a couple of smaller pipes. One of these goes to the coolant feed to the turbo, the pipes are 2 different sizes so are adapted using a barbed brass adaptor. The final pipe goes to the top of the coolant expansion tank, again these are 2 different sizes so I used a brass adaptor.
With the coolant system all reconnected I decided it would be a good idea to buy a tester kit to check my work rather than find out on the maiden voyage. I filled the system with water first in case there was leak and pressurised it to 1.5 bar for 30 minutes. The radiator cap is rated to let by at roughly 1 bar so the coolant system should never see this sort of pressure. Everything held up so the system was drained and then refilled with coolant.
Post by: Ch33zy on May 10, 2026, 22:33
Final part of the puzzle is the charge cooler kit. This places the charge cooler in the engine bay where the battery was. First up was fitting the mounting bracket which bolts to the engine mount using the existing mounts for the battery tray. Once this was in place the cooler itself could be fitted along with the new map sensor housing and connecting hoses. I'm planning on running a gauge that measures the intake air temperature of both the inlet and outlet on the cooler so the sensors for these were fitted but drilling and tapping the cooler in the appropriate places.
The cooler is a snug fit but uses all the space available. Although the water side of the cooler hadn't been fitted the car was in a position to be started. So the engine was filled with Millers competition running in oil. The fuel pump disconnected electrically and the same with the coil packs the key was turned......a click from the starter but no turning of the starter motor! :'(
A quick look around the car revealed I hadn't tightened up the earth cable between the gear box and the body. With this tightened up the ignition was once again tried and the starer worked this time. I cranked the engine over until the oil pressure light went out. Coil packs and fuel pump reconnected the car was turned over and burst into life settling to a nice idle with everything sounding like it should. I let the car warm up and check the throttle works, which it did. 8)  The main job left now is to plumb in the water side of the charge cooler.
Post by: Ch33zy on May 17, 2026, 23:37
Last major job was to mount a radiator and water pump for the charge cooler. I purchased an AVS 12v water pump and a 24" x 7" twin pass radiator from chargecooler.co.uk. The radiator was to be mounted at the front of the car in front of the engine radiator. I used some 2"x1" aluminium rectangular box section and knocked up a couple of brackets to mount the radiator to the car. These had holes holesawn into them to aid air flow and were then given a coat of black stone chip before being bolted into place and having the radiator mounted to them.
The water pump was mounted to a support bracket for the front trunk liner and wired to the live feed for the power steering pump via a 5amp inline fuse. This means the pump is on whenever the ignition is on.
The header tank for the system was stuck to the top of the charge cooler using some tiger seal  to keep it in place.
The pipework from front to back was tucked up above existing hoses under the car from the cooler and fed through to the front.
With the chargecooler system filled up with coolant it was time to go for a test drive. The maiden voyage was just a quick lap of the village where I did the work on the car. It had been a long time since I had decided I was going to build a 1.8t 20v MR2, around 3 years, and now I was actually getting to drive it. Needless to say I came back from the initial drive grinning from ear to ear. ;D
I had done most of the actual engine swap at a friends house about 45 mins drive from where I live so the next step was to get the car home. With a boot full of tools, jacks and general breakdown tools my friend followed me home. Fortunately none of it was needed as the car performed perfectly on the way home. I'm having to run the engine in after it's rebuild but I can already tell it's so much more powerful than the original engine and makes all the right noises from the turbo. 8) First and reverse are very close to each other but I'm sure I'll get used to it and it pulls away in second gear with no issues if needed. It cruises at 70 at less rpm than it did with the original 5 speed Toyota set up and is much quieter at that speed than it was before with the Malian exhaust. It seems to have really good road manners at normal driving rpm and speed, it needs running in before I can explore its full capabilities. There's still a few little jobs to do, ie wire up the charge cooler AIT gauge, fit a boost gauge but it's mostly done and just needs running in and driving now.
Post by: Topdownman on May 18, 2026, 06:32
Great progress as usual!
Everything seems to be going perfectly so lets hope that continues and we see lots of pictures of you out enjoying the car after all your hard work.
