The Workshop => General => Topic started by: Double Zero on July 16, 2026, 09:48
Title: DRL Fogs and horn
Post by: Double Zero on July 16, 2026, 09:48
I'm getting a bit fed up of not being seen by other drivers seems to happen more in the MR2 than any of the other cars I drive.
Has anyone used a recent fog light DRL kit I have seen that Vinster are good but was wondering if there is a slightly cheaper option as I don't really use my car in the rain if can be helped.
What has everybody replaced their horn with I had to use the horn in anger and it really doesn't cut it.
As the bumper is coming off to do the fog lights I might as well do the horn at the same time.
Any advice for a better sounding horn?
Title: Re: DRL Fogs and horn
Post by: Ardent on July 16, 2026, 12:28
I haven't but have been tempted to fit.
Post by: Joesson on July 16, 2026, 13:51
DIVE, DIVE, DIVE Comes to mind. Just may get some necessary attention!
Post by: fawtytoo on July 16, 2026, 17:06
Quote from: Double Zero on July 16, 2026, 09:48What has everybody replaced their horn with
I haven't replaced mine. It seems plenty loud enough.
Post by: Double Zero on July 16, 2026, 20:28
It's more a warning I was after the horn seems a little high pitched
Any suggestions for DRL's for fog lamps has anyone used any of the cheaper Chinese options
Post by: SurreyMR2 on July 16, 2026, 21:02
I fitted Hella twin tone horn kit. Both horns bolted into original horn mounts.
As for DRL lights I fitted Ring items.
Post by: Double Zero on July 16, 2026, 23:10
Quote from: SurreyMR2 on July 16, 2026, 21:02I fitted Hella twin tone horn kit. Both horns bolted into original horn mounts.
Thank you I've got a face lift so ideally want to replace the dogs.
I will look at the horn
Post by: MisterK on July 17, 2026, 14:21
Like you, I had a few near misses with people not seeing me, so  I fitted the Ring horizontal DRL's. I then obtained a set of the circular combined DRL/ LED fogs from someone who was supplying them on the forum, although it was probably 10+ years ago.  Really pleased with the results & it's made a massive difference to the cars visibility...I've had no issues since they've been fitted.I find the horn OK...it's certainly louder than mist new cars these days  :)
Post by: SV-3 on July 17, 2026, 18:06
Which horn kit?
Post by: Craigjm on July 17, 2026, 23:12
My horn is a really deep blast and I'm sure it's the original
Post by: Nomad on July 18, 2026, 14:02
My horn is original and it sounds so pathetic I've stopped using it..
Post by: SurreyMR2 on July 18, 2026, 20:29
Quote from: SV-3 on July 17, 2026, 18:06Which horn kit?
https://www.amazon.co.uk/HELLA-Trumpet-Horn-Frequency-Plug/dp/B001CC6WR0
Post by: SurreyMR2 on July 18, 2026, 20:32
Quote from: Nomad on July 18, 2026, 14:02My horn is original and it sounds so pathetic I've stopped using it..
I was in a situation where a new Range Rover was in front of me and put car in reverse, thought it was going drive right over me. Beeped the original toy town horn but don't think it heard me. I think the the cars auto braking kicked in or he saw me in the camera and he stopped. Scared me though!
Bought kit below and I now have a horn that actually works  8)
Post by: Double Zero on July 18, 2026, 22:53
Perfect thanks for the advice
I've ordered the Hella horn
Post by: Nomad on July 20, 2026, 17:02
Quote from: SurreyMR2 on July 18, 2026, 20:32I was in a situation where a new Range Rover was in front of me and put car in reverse, thought it was going drive right over me. Beeped the original toy town horn but don't think it heard me. I think the the cars auto braking kicked in or he saw me in the camera and he stopped. Scared me though!
Are they direct swap or some wiring needs doing?
Post by: SV-3 on August 2, 2026, 13:32
Quote from: Nomad on July 20, 2026, 17:02Are they direct swap or some wiring needs doing?
@SurreyMR2  :)
Post by: SurreyMR2 on August 2, 2026, 20:28
Use same bolt holes to fix them on car.
There is a power wire going to each horn, you use this on new horn.
Think my horns needed an earth, I simply bolted the earth lead to the horn fixing bolt.
