The Workshop => Performance Related => Topic started by: GSB on August 21, 2003, 12:26
Title: Big Brake Kits...
Post by: GSB on August 21, 2003, 12:26
Yes I know the MR-S can out-brake just about anything on the road, and no I'm not about to put my order in for them. Just pointing them out as a mere curiosity... So dont flame me, its not worth the wear and tear on your keyboard.
Anyway, here you have it. 330mm x 30mm (13 inch x 1.2 inch) slotted and drilled rotors with 4 pot calipers available in red or blue. The whole kit is available from rotora for $1695 USD. Thats about £1070...
(http://www.spydermagazine.com/files/kits_02.gif)
http://www.rotora.com
Post by: Anonymous on August 21, 2003, 12:29
How can you suggest that - the stoppers on the 2 are fantastic - WHAT WERE YOU THINKING.... oh, you said dont bother flaming you... sorry!   s:wink: :wink: s:wink:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:wink: :wink: s:wink:
I quite fancy a set of big stoppers like that! Not sure i would ever spend that sort of money on them though!   s:shock: :shock: s:shock:    s:D :D s:D
Post by: Tem on August 21, 2003, 12:34
That site doesn't seem to like me at all...
I was just wondering, if those would be lighter than the stock thingies..? And by how much..?
Post by: Anonymous on August 21, 2003, 12:35
Nope, not bothered. I already feel like I am hitting an oncoming train when I hit the stoppers hard, so I don't think I will bother with them!!!!  s:wink: :wink: s:wink:    s:lol: :lol: s:lol:
Post by: Anonymous on August 21, 2003, 12:38
The price would be justified if they came with low pad warning.
Another feature the MR2 lacks...  Even my 10 year old Audi had a warning light for when the pads needed changing; now I have to rely on sqeeky noises...
Post by: Tem on August 21, 2003, 12:45
Quote from: "Emmanuel"Another feature the MR2 lacks...  Even my 10 year old Audi had a warning light for when the pads needed changing; now I have to rely on sqeeky noises...
I don't miss one...I like to know how much pads I have left pretty much all the time anyway. Not only when I run out.
But you can buy aftermarket sensors for those, if you really want that feature.
Post by: Anonymous on August 21, 2003, 13:20
Quote from: "Tem"That site doesn't seem to like me at all...
hmm could be lighter but i'm thinking it might not rust....
Would they fit stock wheels?
**edit** they shouldnt weigh to much, they are grooved and drilled which helps a lot with weight, BUT they will burn pads I would think.
***edit*** the do just normal groved discs front - $187 rears - $139 but I really dont think any extra stopping power could be gotten from them I think the only way to get more stopping power is to up your pads and tires.  Even race prepepd MR2s still use the stock stoppers.
Post by: Tem on August 21, 2003, 13:31
Quote from: "WoodenDummy"hmm could be lighter but i'm thinking it might not rust....
They would probably be rustfree...(just a guess though).
I'm sure it won't fit stock wheels as the disc itself is 13". My guess would be that they need 16" wheels...
And about the weight, the disc would probably be around the same as stock. A bit bigger, but lighter compared to size. But the calipers in big brake kits are usually very light, made from aluminum or something.
Edit: There was a big brake kit for Mk1 MR2 that had 11" discs and it barely fit inside some 14" wheels.
Edit2: I agree about the stopping power. Probably wouldn't give any, since the stock ones have enough power to engage the abs all the time. It's the weight that got my attention..
Post by: mph on August 21, 2003, 13:37
You'll need to re-adjust the brake bias after installation. The calipers will be heavier than ours and grooved discs eat pads. Cross-drilled discs are liable to crack
If you want better-than-stock performance, just buy better pads!
Post by: Tem on August 21, 2003, 13:39
Quote from: "mph"The calipers will be heavier than ours
You sure?
I remember holding HUGE calipers from Supra and wondering how come they weight nothing  s:lol: :lol: s:lol:
Post by: Anonymous on August 21, 2003, 13:45
Quote from: "Tem"
You sure?
Yeah if they are good they should weigh less, but I totaly agree they will eat pads and give nothing back for it.  Better pads and better rubber thats the only way to get better stopping.
Post by: GSB on August 21, 2003, 13:51
Quote from: "WoodenDummy"Yeah if they are good they should weigh less, but I totaly agree they will eat pads and give nothing back for it.  Better pads and better rubber thats the only way to get better stopping.
Agreed, but if you want to take advantage of those better pads and better rubber, and use it to its full extent on a a repeated basis, (track use) then you'd want bigger discs to give you better control and modulation of the braking forces and dissipate the additional heat energy, 4 pot calipers to apply more force to those discs, and slotted or drilled rotors to reduce wieght and ensure that things like pad glazing are reduced in order that the performance of the brakes stays constant, and doesn't change with temperature and use.
Post by: Anonymous on August 21, 2003, 14:21
Thing is mate, there isnt any point.  REAL race MR2s still use the same brakes only changing the pads (we are talking about 300bhp MR2's here) as i'm sure Cin will tell us  s:) :) s:)
Post by: GSB on August 21, 2003, 14:25
Quote from: "WoodenDummy"Thing is mate, there isnt any point.  REAL race MR2s still use the same brakes only changing the pads (we are talking about 300bhp MR2's here) as i'm sure Cin will tell us  s:) :) s:)
I know that, To be honest you'd have to be mad to go to trouble of fitting a kit like this, but if you had a car that wasn't quite so over endowed in the braking dept, then the above points would be a lot more valid...
Just promoting healthy debate, and pointing out the new products  s:) :) s:)
Post by: Anonymous on August 21, 2003, 14:45
I think Tem's statement echo's my own thoughts.  The brakes may be great, and bigger discs/different pads may help, but as I can already engage the ABS without much difficulty, surely the limiting factor is the tyres.  Sure track use and fade is of interest to some, but not really relevant to me.
Post by: Anonymous on August 21, 2003, 14:53
Quote from: "GSB"but if you had a car that wasn't quite so over endowed in the braking dept, then the above points would be a lot more valid...
Sorry didn't mean to sound like I was arguing, your right in every way  s:) :) s:)
Post by: Anonymous on August 21, 2003, 15:13
the project velside has got a brake upgrade but i cant rember what it was i think it was 6 pot bremo's but dont quote me i will find out tonite after rugby pratice
Post by: Anonymous on August 21, 2003, 16:06
Quote from: "Buster"the project velside has got a brake upgrade but i cant rember what it was i think it was 6 pot bremo's but dont quote me i will find out tonite after rugby pratice
lol the VS HAS to have huge stoppers, the stupid size wheels have to have a upgrade to make it stop as well as a stock MR2 because of the extra turning (NOT joking here)
Post by: Anonymous on August 21, 2003, 18:09
yeah i know the proper VS dose WD but  a friend of mine is getting the kit fitting at teh moment and 18" wheels too, so at the same time she upgraded the brakes
but she hasn't got teh turbo just an apexi induction and some japan make exhuast !
when the projects complete i will post pics   s:lol: :lol: s:lol:
Post by: Anonymous on August 22, 2003, 09:39
Quote from: "mph"If you want better-than-stock performance, just buy better pads!
And fluid, if you intend repeated, heavy braking, and want to avoid boiling the stock stuff.
Post by: Anonymous on August 22, 2003, 10:25
Quote from: "pmdye"
Some SS lines wouldnt be a bad thing, better than the stock rubber.
Post by: Tem on August 22, 2003, 11:03
Quote from: "WoodenDummy"Some SS lines wouldnt be a bad thing, better than the stock rubber.
Now that you mentioned it...anyone selling sets for Roadster?
The 30.000km service mentions changing brake fluids...might as well change the lines while I'm at it.
Post by: Anonymous on August 22, 2003, 11:09
Quote from: "Tem"
Thinking about it, I have no idea.  I'm 100% sure somebody does them.
Post by: Anonymous on August 22, 2003, 14:22
Quote from: "Tem"
Geoff Mohler at SpeedToys (http://www.speedtoys.com)
Post by: Anonymous on August 22, 2003, 14:25
Quote from: "pmdye"
Quote from: "Tem"
I should add that I considered them In Nov last year (but didn't bother in the end). Quoted costs (with Porterfield R4S pads) were;
QuoteFor pads + SS lines:  $361.08 to your door via CC or paypal.
For pads only:  $237.32
Quote from: "pmdye"
Quote from: "Tem"
you rule!
Post by: juansolo on August 23, 2003, 18:57
Absolutely nothing wrong with the stock brakes on the Mr2.
Post by: Tem on August 25, 2003, 07:22
Thanks for the link pmdye!
Quote from: "juansolo"Absolutely nothing wrong with the stock brakes on the Mr2.
Sometimes I just love to disagree  s:twisted: :twisted: s:twisted:
But seriously. There is something wrong with the stock brakes. The braking power is great...no wait, perfect, unless you have some crazy rubber. I agree on that.
But they rust. That's not perfect. And they are kinda heavy. That's not perfect either. I don't think the rubber lines are perfect either. And you can't fix those with better pads  s:roll: :roll: s:roll:
Post by: juansolo on August 26, 2003, 09:30
Quote from: "Tem"But they rust. That's not perfect. And they are kinda heavy. That's not perfect either. I don't think the rubber lines are perfect either. And you can't fix those with better pads  s:roll: :roll: s:roll:
I've hammered the car around Cadwell Park for 6x20 minute sessions on a very hot day and the cars braking has remained strong and free from fade.  If it ain't broke, don't fix it.
As for unsprung wieght, I understand the handling benefits of this as the effect of reducing unsprung weight is exaggerated on the Westfield as it is so light (and softly sprung as a result) to start off with.  But you are not going to notice any difference by fitting lighter brakes to the Mr2 as you're simply not going to get enough weight off them.  Ali bells will help with the expansion and contraction of the disk and reduce the wieght a fraction... Once again there should be no issues with this on road rubber.  Drilled disks eat pads and on the whole are uneccessary.  Skimming disks is unwise on a car this heavy.
Brake lines.  Yes this might fractionally increase pedal feel as braided teflon lines cannot expand when hot like rubber, but again I argue that you can't get them hot enough to notice this anyhow.
Basically you're not going to make a big enough weight saving to notice any difference and, unless using sticky track rubber, you're never going to work the brakes hard enough for them to need to be uprated.
If you want to make an easy and noticable difference to unsprung weight, tackle the heaviest item first and swap out the stock wheels for some magnesium items....   and I don't mean 18" jobs!
Sorry to rain on your parade but it just seems a waste to modify things on the car in the name of performance just for the sake of it (rather than just being a GJOB or a Max Muppet) and there are other areas that are more of an issue that there would be benefits to addressing, like the whole bracing issue for example.
Title: Couldn't agree more
Post by: Anonymous on August 26, 2003, 09:40
Couldn't agree more on this point. There is NOTHING wrong with the stock brakes on the '2 that you can't get fixed under warrenty  :-) :-) :-)
This sunday I was belting round Donington Park with a bunch of Elise, MX-5's and MGF's, and there wasn't a single car there I couldn't outbrake into the corners, and especially Goddards Chicane. I was flying past the F's like they were driving through glue. I don't think there are too many drivers that would be able to tell the difference between a stock setup and one with changed lines or calipers. The only thing that did worry me was the amount of damage I was doing to my pads!
And I take back what I said about the ABS. On the road it seemed a little too intrusive. On a track I think it was perfect!
Post by: Anonymous on August 26, 2003, 10:03
Guys this is Tem and WoodenDummy we are talking about, we make it our life to poke the Max Power boys in the eyes.
Our brakes are not perfect, yes they stop us like anchors I'm the guy that likes to point out that we stop faster than the McF1, but they DO rust and i'm not going through this with the dealer again i'm starting to get very sick of Toyota dealers.
juansolo please re-read Tem and myselfs posts here and on SC, to think that either one of us would fit 18" wheels is quite funny, i'm the guy that was thinking about changing to 15" steel wheels before he found out that the stock alloys still weighed less.  Just look at my posts commenting on the recent VS kit in the UK!
Your missing our points my disc's have rusted BADLY and I know two other people personally who have had and keep having the same problem.
Post by: Tem on August 26, 2003, 11:52
Quote from: "juansolo"I've hammered the car around Cadwell Park for 6x20 minute sessions on a very hot day and the cars braking has remained strong and free from fade.  If it ain't broke, don't fix it.
Like I said, I'm not after more braking power. The brakes work just fine even after ~30mins of track when the temp were beyond 100F on a dman sunny and hot day.
"But you are not going to notice any difference by fitting lighter brakes"
You sure?  s:) :) s:)  Some say they notice a huge difference from an intake that only makes more noise. Some say they didn't notice a thing after removing the spare wheel . Different people notice different things.
"If you want to make an easy and noticable difference to unsprung weight, tackle the heaviest item first and swap out the stock wheels for some magnesium items....   and I don't mean 18" jobs!"
First of all, the (front) wheel weights 6.5kg and the tyre 9.5kg, rears are a bit more, but don't remember them right now. And since the tyres are further from the centre than wheel, it only makes matters worse.
Anyway, I never said these brakes are the next item on my to-do-list  s;) ;) s;)  Just weighting options in advance. I'm pretty sure I will get lighter wheels before touching the brakes. And I don't mean 18-inchers either.
"there are other areas that are more of an issue that there would be benefits to addressing, like the whole bracing issue for example"
Actually I'm quite happy about the bracing I have on the car, thanks for asking  s:roll: :roll: s:roll:  This was just a new subject for me, I've never seen brake kits for Roadster before. I wanted to talk about it now, not in a year or two when the update might be next on my to-do-list. No need to get excited about it.
Post by: juansolo on August 26, 2003, 12:55
Quotei'm the guy that was thinking about changing to 15" steel wheels before he found out that the stock alloys still weighed less
Ok I admit I skim read most forums I contribute to and may have come over a little harsh as I've only picked up on odd points that people have made.  I apologise for this.
I would say though that steelies do bring their own problems also.  They're lousy at heat dissipation next to alloys and the wheel & disk will operate at much higher temperatures because of this.  They will also not cool down anywhere near as quickly between sessions.
Other than that, fair do's.  Don't know either of you so don't know your agendas on upgrading.  Saw brake upgrade and instantly thought Max Power drilled disks and painted red calipers.  Once again I apologise if I got the wrong end of the stick.  However if I got the right end then may I direct you toward Halfords for some high temperature caliper paint and B&Q for a £15 special offer power drill.
BTW, never had issues with rusting on my disks.  How is this manifesting?
Post by: Anonymous on August 26, 2003, 13:00
you hit the nail on the head with everything you said, but we are just trying to stop our disc's rusting.  I posted pics of mine, which have gotten worse.
I think I may have to replace my own for the sake of a quiet life so I was also thinking along the same line as Tem, why not just go for steels.  I can live with groves as long as my pads don't get eaten THAT much.  I AM worried that I might get crap aftermarket discs though!
Title: Re: Big Brake Kits...
Post by: Tem on September 27, 2003, 21:22
Quote from: "GSB"Yes I know the MR-S can out-brake just about anything on the road, and no I'm not about to put my order in for them. Just pointing them out as a mere curiosity...
Bumped into another alternative:
 m http://www.zeckhausen.com/Toyota/MR2_Spyder.htm (http://www.zeckhausen.com/Toyota/MR2_Spyder.htm) m
 m http://www.stoptek.com/productphotos/index.shtml (http://www.stoptek.com/productphotos/index.shtml) m
Post by: Anonymous on September 27, 2003, 23:29
I agree with WD and Tem.
One thing though, the F1 stops from 70-0 at 162ft while the MR2 at 167ft...
Post by: Anonymous on September 28, 2003, 08:06
Quote from: "Emmanuel"I agree with WD and Tem.
In which case, make sure you're both doing 60 if following close behind one and it decides to do an all-out stop.  s;) ;) s;)
Post by: Anonymous on June 12, 2005, 18:45
it's worth keeping in mind that the mclaren doesnt have abs, in a bid to save weight, afaik (or power steering for that matter).
the spyder does have awesome 100-0 times though : )
for track work though, i would prefer bigger brakes than the spyder has, i experienced onlyminimal brake fade after 5-8 laps on sepang f1 circuit.
i would particularly prefer them if they were lighter, esp. after the reviews of how porsches handle with the lighter pccb brake kits.
btw, brake bias, as mentioned by someone earlier in this thread, would be interesting to adjust on the spyder. although increasing the bias towards the front would increase chances of spinning and tail happy behavior on the road, it would be awesome on autocross events, which i amparticularly keen on. if my budget strechs to it i will be keen on having an adjustment system on my car.
Post by: Anonymous on June 13, 2005, 16:57
Just backtracking a bit but I fitted stainless steel braided hoses to mine last year. They're Goodridge hoses and I got them off ebay for about £50 or £60 I think? The good thing is they're a 'fit & forget' item as they'll never perish or rust plus they give a great firm pedal and look good as well!
Post by: juansolo on June 14, 2005, 13:46
 s:D :D s:D
Post by: Anonymous on June 16, 2005, 21:59
As i've said in other threads, I know how I like my cars to look and handle, but don't know that much about how they work...
Am I right in thinking that you guys are saying that the standard brakes on a '2 will stop it almost as quick as a multi-million £ McLaren F1 car?!?!?!?surely not?!!?!?
I mean, I heard that the '2 will out-accelerate a boxster in the 40-70mph range, and that it's got about the same power-weight ratio as the 2.8 v6 Z3, both of these I could fully believe, I mean, it is VERY light isn't it! but matching an F1 car's braking??? seriously???
Post by: Tem on June 16, 2005, 22:25
Quote from: "jamesr1"Am I right in thinking that you guys are saying that the standard brakes on a '2 will stop it almost as quick as a multi-million £ McLaren F1 car?!?!?!?surely not?!!?!?
Are you saying that the '2 can't activate the ABS at those speeds?  s;) ;) s;)
...after that it's pretty much only about tyres...
(I think they meant the road legal one with road legal tyres, not the racecar...the real F1's are completely different in braking)
Post by: aaronjb on June 16, 2005, 22:28
Quote from: "jamesr1"but matching an F1 car's braking??? seriously???
Just to clarify.. They're quoting figures for "the" McLaren F1 (like the one Rowan Atkinson owns), not a McLaren F1 car  s;) ;) s;)
Because I very much doubt we can hit 5g decelleration - then again, that's largely down to downforce (aerodynamic grip) in an F1 car, rather than mechanical grip (although yes, that will also be much higher than our car or the McLaren F1, since we have 'hard' road tyres, and the F1 car has very soft F1 tyres  s:) :) s:) )
Post by: aaronjb on June 16, 2005, 22:29
Quote from: "Tem"(I think they meant the road legal one with road legal tyres, not the racecar...the real F1's are completely different in braking)
Sneaky.. when I started my reply Tem hadn't added that bit.. honest  s:D :D s:D
Post by: Anonymous on June 16, 2005, 22:36
aahhhh... that clears it up then! I didn't know there were two sorts!   s:oops: :oops: s:oops:
Post by: aaronjb on June 16, 2005, 22:39
Road legal one would be this one:
http://www.mclarencars.com.ru/images/gallery/hi/009.jpg
(and lots more here (http://www.mclarencars.com.ru/gallery.php))
Post by: Ernie Ball on June 16, 2005, 23:41
Who sells rust-free replacement rotors (no need for big ones as far as I'm concerned)?  I'd really like to replace mine because they're ugly.
