i'm going to clean my MAF Sensor, what types of stuff can i use?
Is WD40 usable??
I also have this Pipercross 'Air Fliter Dirt Retention Additive'
(http://img493.imageshack.us/img493/8031/photo00765tq.th.jpg)
Don't know about WD40, guessing not.
Plenty of posts, enter MAF AND clean in search.
A non-residue carb cleaner is the type of thing you want.
Don't use too much of the dirt fluid - I've heard that stuff is great for coating the MAF and screwing it up when you go mad with putting it on the filter..
dont use WD40, its basically a water displacement fluid or a light penetrating oil, your looking for a aerosol cleaner that leaves no residues behind
Brake Cleaner s:D :D s:D
I use carb cleaner from Halfrauds s:wink: :wink: s:wink:
wynns carb cleaner as Heath said, or electrical contact cleaner which i also buy from halfords
Quote from: "MRMike"electrical contact cleaner which i also buy from halfords
thats what i use
i use STP carb cleaner. works like a champ and leaves no residue. if you wanna know if you can use it or not, spray it on your car window. if it leaves a trace of being there, dont use it.
Quote from: "mefarri"i use STP carb cleaner. works like a champ and leaves no residue. if you wanna know if you can use it or not, spray it on your car window. if it leaves a trace of being there, dont use it.
Good tip there to work out if a residue will be left and cause an issue on the MAF s:wink: :wink: s:wink:
