where can i get a TRD drop in air filter? do these sound good?
also, from what i hear on here intakes only affect the sound the engine makes rather than any performance increase, so in that case, whats the difference between the different ones you can get? might aswell go for the cheapest surely? or am i wrong?
just found this:
m http://cgi.ebay.co.uk/K-N-Air-Filter-To ... dZViewItem (http://cgi.ebay.co.uk/K-N-Air-Filter-Toyota-Celica-MR2-1-8-16v-GT-GTS_W0QQitemZ4592356643QQcategoryZ10428QQrdZ1QQcmdZViewItem) m
is that one any good? i've read on here about oiled ones and non oiled ones, whats the difference?
Quote from: "razorsharp192"might aswell go for the cheapest surely? or am i wrong?
Just remember that the air
filter is supposed to filter air. Now guess if the cheapest ones are any good at that?
Doesn't matter if you want all the crap in the air in your engine though s;) ;) s;)
k&n or trd then? (or Pipercross, there's one on here for sale) which is best? which sounds best? whats the difference between them? and whats this about oiled and non oiled ones?
for best sound go Apexi power intake, its a cone air filter though
Quoteits a cone filter though
what different does that make?
not a lot to be honest, you have a small amount of pipework to fit it and of course remove the stock airbox, but the sound difference is awsome, really grumbly. Totally worth it if you want a nice sound to your 2
where can i get an apexi thing then? and how much is one?
also, whats the difference between the apexi, trd, k&n and pipercross ones? i dont want the car to sound like the exhaust has a hole in it, just want it to sound a bit beefyer
just been reading some other threads, saying that most induction kits actually decrease power! in that case am i better just getting a drop in filter to replace the original? if so, which one?
IMO filters like the Apexi actually decrease power, especially on hot days, because they pull in hot air from the engine compartment, rather than getting cold air through the side vents as the normal box does. However if all you want is noise, then its the cheapest option.
However if you ever get to gut your cats and fit an after market exhaust the noise might be too much s:shock: :shock: s:shock: I have gutted cats, TRD filter, Markiii inlet pipe and H&S exhaust and I think it all sounds brilliant. Quiet on idle or low steady revs, slight burble / pop on over-run, and deep throaty roar that rumbles your insides on full throttle, or when revs are high.
As to oiled, or not. Oiled will last "for ever", you have to clean and re-oil them about every 30K, or the latest TRD advertises as never re-oil. The ordinary need changing every 2 years (or maybe even 1).
The oil is suppossed to be better at picking up contaminents better than paper (or whatever).
TRD can be bought from MRS-passion.
Hope that helps.
The good ol' argument of air intakes. There are no performance gains to speak of so just pick the one that sounds good to you and does filter the air...
In my opinion, you'd better buy a quality item (such as the Apexi as suggested) or you might regret it later. E-bay and Japanparts are good places to start.
Quote from: "roger"However if all you want is noise, then its the cheapest option.
eeeerrrr at over £100 for the Apexi vs $106 for the TRD panel it aint the cheaper option Roger
Quote from: "kanujunkie"Quote from: "roger"However if all you want is noise, then its the cheapest option.
Yeh, but you get more noise IMO. On its own the TRD gives you a bit, but nothing like the Apexi I 've heard on others. To get the Apexi noise without using it, you've got to add the inlet pipe or H&S/TTE (for example)
Quote from: "roger"IMO filters like the Apexi actually decrease power, especially on hot days, because they pull in hot air from the engine compartment, rather than getting cold air through the side vents as the normal box does.
so in that case am i better off just getting a trd or k&n drop in filter that replaces the original? if so, which is better? for sound etc
basically if you want power, then get TRD with a inlet duct but thats only going to give you 1-2Bhp. If you want noise and no power then go with the Apexi
not bothered about more power, just dont want less power! what difference would the trd/k&n filter make on its own? without messing about with pipes
cant say never run either, but i would say that after 2 years of running an Apexi i dont agree with Roger coments of looseing power with the Apexi, i lost the same amount of power in hot weather with the stock intake as i do now and thats pretty negligable
Quote from: "kanujunkie"cant say never run either, but i would say that after 2 years of running an Apexi i dont agree with Roger coments of looseing power with the Apexi, i lost the same amount of power in hot weather with the stock intake as i do now and thats pretty negligable
I've never had an Apexi, only quoting what I've heard which sounds reasonable. TBH I've never really felt a loss of power in hot weather, but the engine doesn't sound quite as crisp and "nice" as it does if its cold.
All i am saying is the air in the engine compartment is warmer than ambient (whatever that is), and perceived wisdom I've picked up is the engines work better on cooler air.
Quote from: "razorsharp192"not bothered about more power, just dont want less power! what difference would the trd/k&n filter make on its own? without messing about with pipes
Power wise, negligible. There is a theory because the air runs better you get more power. Same applies to Apexi.
Certainly TRD/K&N won't give you less. Add the Markiii inlet pipe and you will get a little more, but we are still only talking about hypothetical small amounts around 1 BHP for example.
<double post>
just for info the markiii inlet pipe is identical to the TRD one just pm markiii for details
what about pipercross, gains etc.?
what if i just got the filter though? i can get the k&n one for £40, how much is the trd one? and whats the difference between the 2?
Quote from: "razorsharp192"what if i just got the filter though?
Slightly better sound, longer filter life, might get a minimal power increase. IMO thats it.
TRD is 88Euro retail from dieamond at MRS-passion + shipping. Have to do a Google to see if you can get it cheaper. Sometimes go for sale here or on e-bay.
Very little as far as I am aware, but never seen a K&N.
Just get an A'PEXi, my Mr T dealer fitted mine for me if you are worried about doing it yourself - can't beat the sucky sound! s:wink: :wink: s:wink:
where can i get an apexi one for and how much are they?
try this m http://www.whifbitz.co.uk/mr2-airfilter.html (http://www.whifbitz.co.uk/mr2-airfilter.html) m
what would the "Element filter for std airbox" be like compared?
Quote from: "razorsharp192"what would the "Element filter for std airbox" be like compared?
They are the ones that fit the stock airbox, here's few:
m http://www.spydermagazine.com/2001/Sept ... ilters.htm (http://www.spydermagazine.com/2001/Sept/air_filters/air_filters.htm) m
i meant, what would that be like (sound etc) compared to the cone one?
is there a site where someone has compared filters, performance, sound etc wise?
Quote from: "razorsharp192"i meant, what would that be like (sound etc) compared to the cone one?
Cones make more noise s8) 8) s8)
Quoteis there a site where someone has compared filters, performance, sound etc wise?
There's this one:
m http://www.mkiv.com/techarticles/filter ... index.html (http://www.mkiv.com/techarticles/filters_test/2/index.html) m
I think you should always remember that the filters first and most important job is to filter. After that comes the noise and performance...but since Apexi filters best and made the most power in that best, not to mention it sounds great, there's really not much to think about, is there s;) ;) s;)
ok, apexi it is, but drop in filter or cone? which is best? differences etc?
Quote from: "razorsharp192"ok, apexi it is, but drop in filter or cone? which is best? differences etc?
Apexi is a cone filter, not a drop in
Very short answer ...
A cone filter will make more noise, but probably loose bhp as you're drawing in hot air from the engine bay. I've got a K&N setup on mine at the moment, and I have seen intake temps (from the OBD-II) of 40-45C in stationary summer traffic.
A panel filter will still have all the standard intake plumbing and therefore will be a lot quieter - as that's how Toyota have engineered it.
So -
Cone: Sounds good, costs a couple of bhp due to hot air being drawn in, Apexi best filtering (generally)
Panel replacement: Probably best real world power gains, quiet.
FWIW - I cleaned the K&J intake on mine after the turbo kit went on. Martin probably hadn't ever cleaned the filter, judging by the state of it (although they do say they don't need cleaning). After fitting the turbo, the car was producing 198bhp - 20 bhp less than Martin's. (?)
I got the car home, I noticed the air filter was in need of a clean. Cleaning using "Woolite" it took an incredible 8 changes of water before the water washed through it wasn't black. It had really held an amazing amount of dirt in the oiled fabric s:shock: :shock: s:shock: I suspected it was actually restricting the car breathing.
After re-oiling it and putting it back on the car, I then took it for another RR session and it got the full 220bhp - where it was expected to be - and it ceratinly felt a lot quicker.
Quote from: "BenF"Martin probably hadn't ever cleaned the filter, judging by the state of it (although they do say they don't need cleaning). After fitting the turbo, the car was producing 198bhp - 20 bhp less than Martin's.
Oy! Yes I had cleaned the K&N filter, twice in fact! FYI: I had always intended to fit the A'PEXi filter [which is a 'dry' filter that you don't oil] but never got around to making up an adaptor plate.
Quote from: "kanujunkie"Quote from: "razorsharp192"ok, apexi it is, but drop in filter or cone? which is best? differences etc?
there is an apexi drop in filter aswell though
like this one http://www.whifbitz.co.uk/mr2-airfilter.html
top item
this could be for the MK2 though, not sure
Quote from: "BenF"Cone: Sounds good, costs a couple of bhp due to hot air being drawn in, Apexi best filtering (generally)
so there's no point at all in buying a cone filter then s:? :? s:?
Quote from: "razorsharp192"so there's no point at all in buying a cone filter then s:? :? s:?
Yes if you want the noise factor!
I have just my cone yesterday!!!
I fitted a AEM cold air induction kit cost me around $250 plus shipping and TAX!! s8) 8) s8)
Took me about 3hrs with some help...had to pull suspension brace off, rear lights and the bumper. s:shock: :shock: s:shock:
the cone sits in the bumper just behind the rear left wheel so i reckon it doesn't really suck much hot air down there s:? :? s:? could be wrong...besides got some ideas to ensure more cold air gets in s:) :) s:)
BUT that been said the sound is the best spin off s8) 8) s8)
Quote from: "Liz"Quote from: "razorsharp192"so there's no point at all in buying a cone filter then s:? :? s:?
if its purely for the noise factor wouldnt it be better to get a noisy exhaust tip and have a good drop in filter that wont reduce bhp? then you'd have the noise plus no reduction of power
My apexi doesn't lose me power, infact I keep it pretty cold with lots of halford ducting and reflective wrap. Works well and the response is much better.
Quote from: "LeeUK"My apexi doesn't lose me power, infact I keep it pretty cold with lots of halford ducting and reflective wrap. Works well and the response is much better.
is it just me or does it seem a lot of effort for a bit of noise to anyone else? i could understand if it gave some extra power or something, but just for a bit of noise? and having to go to extra effort to keep it cold just so it keeps up (in performance terms) with the standard one. seems like madness
isnt there just a drop in filter (seens cone ones seem to be more of a pain than anything) then i can put in, that wont reduce bhp but will sound a bit better?
It was very little efford and very satisfying when it all comes together. Well worth doing, sounds sweet, but if you want a drop in filter go for that.
Quote from: "LeeUK"It was very little efford and very satisfying when it all comes together. Well worth doing, sounds sweet, but if you want a drop in filter go for that.
i'm not slagging it off, dont get me wrong s:) :) s:)
what difference would a k&n/trd drop in filter make compared to the standard one? would it be worth doing?
Quote from: "razorsharp192"Quote from: "Liz"Quote from: "razorsharp192"so there's no point at all in buying a cone filter then s:? :? s:?
There's noise and there's noise. Obviously you won't get the lovely intake noise from noisy exhaust.
...there's hardly any mod that's really worth the price, so don't spend too much time thinking about them, just do it. You'll love it... s:lol: :lol: s:lol:
Quote from: "razorsharp192"what difference would a k&n/trd drop in filter make compared to the standard one? would it be worth doing?
Are we going round in circles here?
More cost, longer life, bit more noise,
possibly a bit more power. And, no, I don't know how much.
Is it worth doing? If you want to customise your car its just one of the many options open to you. If its the only thing you are ever likely to do, don't bother spending the money.
Oh and by the way, it hasn't happened to me but has to other(s), but make VERY certain when you take your car in for a service some grease monkey doesn't throw it away and replace it with a standard one.
Just been cruising on an US site, and they were discussing TRD / K&N drop in filters (not for MR2 by the way).
One guy said, definitely makes the car go faster, because your wallet is lighter.
s:lol: :lol: s:lol: s:lol: :lol: s:lol: s:lol: :lol: s:lol: s:lol: :lol: s:lol: s:lol: :lol: s:lol:
There were other (unconfirmed) comments, like over oiling makes your MAF dirty, oil gets sucked into air intakes, don't use in a dusty environment because they are undersized, no better than the paper ones.
Quote from: "roger"There were other (unconfirmed) comments, like over oiling makes your MAF dirty, oil gets sucked into air intakes, don't use in a dusty environment because they are undersized, no better than the paper ones.
All true. Except there are dry models these days, like the Apexi, which obviously can't make anything oily.
Also, we get oil sucked into air intakes all the time through PCV, so the little that might come from over oiled filter isn't an issue at all.
They are actually worse in filtering, but unless you do all your driving on dusty roads, it won't make a difference during your engines lifetime. Assuming you use a good filter in the first place, the worst ones are really sucky.
Quote from: "Tem"All true. Except there are dry models these days, like the Apexi, which obviously can't make anything oily.
Unless you leave your oil filler cap off, like me.. s:oops: :oops: s:oops: But there's no accounting for stupidity s;) ;) s;)
Found it...here's an old post from rec.autos.tech newsgroup.
QuoteArticle: 70381 of rec.autos.tech
From: e cajun@merle.acns.nwu.edu (mailto:cajun@merle.acns.nwu.edu) e ) writes:
> Could you please re-post the K&N report with carriage returns? My news-
> reader makes each paragraph look like one line, and I can't read most
> of the post. Thanks!
> -William
Here it is again. Hope you can read this one.
Subj: K & N filters
To: John M. Saturday, January 21, 1995 5:14:10 PM
John: If I wrote "subjective" I meant "objective".. I was
responsible for evaluating re-usable air filters
for a major construction/mining company that had
hundreds of vehicles ranging from large earthmovers
to pick-up trucks and salesmen's cars. This study
was embarked upon due to the fact that we were
spending upwards of $30,000 a MONTH on paper air
filters. Using them one time then throwing them
away.. I inititated the study in that I was convinced
that a K&N type filter or oiled foam would save us
many dollars per year in filter savings, man hour savings,
and of course engines as these would filter
dirt better than paper. (yes, I had read the K&N ads and was
a believer)
Representative test units were chosen to give us a
broad spectrum from cars right through large front
end loaders. With each unit we had a long history
of oil analysis records so that changes would be
trackable.
Unfortunately, for me, every single unit having
alternative re-usable air cleaners showed an immediate
large jump in silicon (dirt) levels with corresponding
major increases in wear metals. In one extreme
case, a unit with a primary and secondary air cleaner,
the secondary (small paper element) clogged
before even one day's test run could be completed.
This particular unit had a Cummins V-12 engine
that had paper/paper one one bank and K&N/paper on
the other bank; two completely independent
induction systems. The conditions were EXACTLY
duplicated for each bank yet the K&N allowed so
much dirt to pass through that the small filter became
clogged before lunch. The same outcome occured
with oiled foams on this unit.
We discontinued the tests on the large pieces almost
immediately but continued with service trucks,
formen's vehicles, and my own company car. Analysis
results continued showing markedly increased
wear rates for all the vehicles, mine included.
Test concluded, switched back to paper/glass and all
vehicles showed reduction back to near original levels
of both wear metals and dirt. I continued with
the K&N on my company car out of stubborness and at
85,000 miles the Chevy 305 V-8 wheezed its
last breath. The top end was sanded badly; bottom
end was just fine. End of test.
I must stress that EVERYONE involved in this test
was hoping that alternative filters would work as
everyone was sick about pulling out a perfectly good
$85 air cleaner and throwing 4 of them away
each week per machine...
So, I strongly suggest that depending upon an
individual's long term plan for their vehicles they simply
run an oil analysis at least once to see that the
K&N or whatever alternative air filter is indeed working
IN THAT APPLICATION... It depends on a person's priorities.
If you want performance then indeed the K&N is the
way to go but at what cost???
And no, I do not work for a paper or glass air
filter manufacturing company nor do I have any affiliation
with anything directly or indirectly that could
benefit George Morrison as a result..
Well, there you go then. It would appear oiled filters don't give the same engine protection as standard paper ones..........
unless someone knows better. s:wink: :wink: s:wink:
Is there any K&N or TRD write up that proves differently?
Quote from: "mph"Quote from: "BenF"Martin probably hadn't ever cleaned the filter, judging by the state of it (although they do say they don't need cleaning). After fitting the turbo, the car was producing 198bhp - 20 bhp less than Martin's.
Allo Martin s;) ;) s;) it has to be said that cleaning an air filter doesn't normally net you 20bhp gain, but it did in this case. Headley told me it didn't need cleaning (hmm!) .. probably the same logic was applied when the chargecooler circuit was filled with tap water with no Anti-Freeze in it as I found recently .... hmmm.
Anyway, the Apexi should be going into the car shortly - I've got some mounting brackets to hold it up away from the bodywork, and have DIY'd a mounting adapter for it - should be good to get on there.
