The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: leon_in_uk on January 25, 2006, 14:32
Title: window washer
Post by: leon_in_uk on January 25, 2006, 14:32
hi guys, my left washer is blocked, how do i unblock? is it the motor or anything?
Post by: kanujunkie on January 25, 2006, 15:06
normally i'd say try a pin, but seeing as its so F ing cold outside, you sure its not frozen?
Post by: leon_in_uk on January 25, 2006, 15:37
its been dead for about a month, its not the cold and cant be frozen as the other is running freely. its bubbles too.
Post by: Ernie Ball on January 25, 2006, 15:39
Lift the bonnet and make sure there are no kinks or pressure points on the hoses leading to the nozzles.
If that looks OK, gently use a pin on the nozzles themselves.
Post by: Anonymous on January 25, 2006, 15:42
kinda on same sujbest, does everyones washer jets fire a straight line of water wuite high up the windscreen?  half the time doesnt even get the window, on my olf car it came out more like a power ful spray/scoosher, rather than a squirt of water like a water pistol
Post by: kanujunkie on January 25, 2006, 15:51
again, use a pin to re-aim the nozzle
Post by: heathstimpson on January 25, 2006, 16:33
Quote from: "Ernie Ball"Lift the bonnet and make sure there are no kinks or pressure points on the hoses leading to the nozzles.
Or a strut bar squashing it  s:wink: :wink: s:wink:
Post by: kanujunkie on January 26, 2006, 06:29
Quote from: "heathstimpson"
shit! are they that close??  s:shock: :shock: s:shock:
Post by: heathstimpson on January 26, 2006, 07:50
Quote from: "kanujunkie"
s**t! are they that close??  s:shock: :shock: s:shock:
Oh yes if you have a Cusco; mine crushed the washer hose and prevented it working  s:? :? s:?
