I've just bought a Blitz Induction Kit but can't fit it as the rear strut brace is in the way of some of the screws I need to remove. I've tried taking the brace off but my socket set isn't budging it. Any ideas on what sort of tool I need to remove the bolt so I can get my job done?
Phil
If you have one, a breaker bar - if not, hit the ratchet with a rubber mallet (again if you have one). They shouldn't be too hard to shift as the torque specs aren't too hight on those bolts.
I have a rubber mallet. I shall give it a go.
Cheers, Phil
