Cleaning spark plugs?
Started by Anonymous, April 10, 2006, 15:29
Is this something that can be done? Is it a fairly easy job? If they just got all covered in crap etc, can they be repaired/cleaned or do they need to be replaced?
Does the roadster have specific plugs or are there generic ones you can buy and fit yourself?
Thanks in advance!
For as much as they cost, I'd just replace them. If they are dirty.
Any decent motor factor, will be able to tell and sell you what you need.
Anywhere else in Surrey people know of where I can go buy some spark plugs this evening?
edward.carter
Quote from: "Slurpy J"Anywhere else in Surrey people know of where I can go buy some spark plugs this evening?
halfrauds? they should be open fairley late i would think.
karlus972
i ordered mine on MRS Passion. I chose the TRD spark plugs. Yes, any competent mechanic could do it for you.
Should you need some, get hold of Dieamond, he's got quite a wide range (TRD, HKS)......  s:wink: :wink: s:wink:
Madinina Style!!
Yeah Halfords usually open until 8.00pm
karlus972
which ones have you got in mind to buy?
Well if I were you, I'd pay a bit more for decent/performance ones. No way I'd put cheap sparkplugs on my car!   s:? :? s:?
Madinina Style!!
as suggested its probably worth replacing them.
I would remove your current ones though and inspect their condition, and if all they need is a little clean, just use a wire brush to remove any carbon deposits.
Well Halfords have said they have Bosch 510's in stock which are for the '2 and they are £20 for 4...
Does anyone know how easy they are to inspect/remove? I'm not very savvy with these things and wouldnt even know where to look!
They're a piece of cake with a sparkplug puller, other wise you'll struggle big-time. You should be able to get one of these from Halfrauds as well.
To remove, you need to:
1. Remove rear crossbar above engine.
2. Remove cam cover cover.
3. Remove screws holding the coilpacks in.
4. Remove wiring clip from coilpack.
5. Pull on the coilpacks to remove them (they may need a good tug).
6. Unscrew sparkplug using said puller.
10 min job tops.
Thanks Ekona...
Is the cam cover cover the thing with VVTI written on it and the Toyota emblem?
Not sure - cant remember, been a while since I have done this ( and not on this car anyway )
Check that the plugs come with the gaps pre set - otherwise you will need to find out the gap for the plugs, and will need a 'setting' tool that you place in between the metal and the plug, to set the right amount of space.
Quote from: "Slurpy J"Is the cam cover cover the thing with VVTI written on it and the Toyota emblem?
yes
philster_d
i need some colder plugs now too.
Quote from: "philster_d"need some colder plugs now too.
One grade colder has been good for me Phil, but IIRC Thor advised Dan to go two. Be interesting to see how they compare.
Oh, and gap has to come down from stock 1.1 to 0.9, but the colder plugs are already set smaller......sure you know that.
Oh, and get well soon.
Oh, and you have PM.
Ste
Quote from: "philster_d"i need some colder plugs now too.
Just use celica GTS plugs.
