turbo mpg
Started by dlivingstone_19, July 27, 2006, 14:50
dlivingstone_19
what sort of mpgs are people getting from their mr2 with turbos fitted?
** Racing in the Caterham Academy for 2013 Thanks to Pistonheads, Autosport and Caterham **
Toyota MRS Spec:
Trd front splitter, Trd Side skirts, Trd Rear Spoiler, New style Rear Lights, 17inch Dezent Motion Black Alloys, Cobra Quad Exit Exhaust System, Markiii Inlet Pipe & Sony Cd Player
SteveJ
20.5 & 21.1 on the first 2 tanks   s:twisted: :twisted: s:twisted:
Bring on global warming  s:twisted: :twisted: s:twisted:
About the same as before, but I've mapped on the lean side with emphasis on motorway cruising speeds, and only clog it when no-one is looking.
Depends so much on tune, boost and how you drive it.
better than N/a
used to get 225 per tank
now 250
Worst I had so far with TTET is 33mpg  s:shock: :shock: s:shock:   but normally average around 35-36mpg
mg
Between 27 and 33 mpg so far.
[size=67]2005 Silver | Red Heated Leather | TTE Turbo | TTE exhaust | TTE Lowered Springs | TRD FSB | B&M Short Shift | David\'s Style Bars | Bama Tall Deflector | Red Calipers[/size]
not worked it out but i'm getting around 220Miles to the tank, was getting 240 before
I used to get 280 NA, was lucky to get 200 post-turbo.
Gazz
About 250 per tank.
[size=80]Lotus Elise 111R, Larini Sports Exhaust [/size]
Two's Company
Quote from: "Gazz"About 250 per tank.
Wow and I've seen the way you drive!
the ironic thing i've found is the fuel used is at its worst when on tickover sat still, it absolutely drinks the stuff, , think a tweek of the fuel map may be required  s:? :? s:?
Backing off the airflow values in the upper left corner of the map will sort this out Stu. They're already negative but they'll cope with quite a bit more.
The more precise tuning, especially if done directly on your car, should deliver the capability for better miles per gallon, if driven in a similar manor to N/A.  This must be balanced against the fact that it feels so much better when you mash the pedal, you find yourself looking for more occaisions to do it.
Quote from: "shiftless"if driven in a similar manor to N/A.
  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:  Like thats going to happen  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
  s:wink: :wink: s:wink:
Quote from: "kanujunkie"
When stuck on the M1 roadworks  s:? :? s:?
BenF
I'm still seeing 35-36mpg on a 30 mile commute to and from work along dual carridgeways. That does drop a fair bit if I take the 'long' way home and enjoy some backroads.
I was quite suprised that after turbo'ing there wasn't a larger mpg penalty - but at a steady cruise, the turbo isn't really restricting anything and 'costing' power - the engine's compression ratio remains unchanged too.
On track, this plummets as you'd expect - 10-15mpg is normal, depending on how hard I'm driving.
