Clutch & flywheel
Started by Tem, November 6, 2003, 11:34
dieamond
What's teiwa ?
TRD - Cusco - C-One - Tom\'s - Amuse - Top secret - Veilside - Spoon - Blitz - Invidia
JUN - Racing Gear - APR Performance - HKS - Apexi - Project Mu - Trial
Quote from: "dieamond"What's teiwa ?
 m http://www.teiwa.co.jp/ m
Ships stuff from Japan, just like Takakaira or Japanparts.
Jap GT300
I have the Toda installed as well.  For those with an SMT do you notice (Especially in 3rd gear) under hard acceleration when changing gear you get an over run of revs?
Also when letting off at 4000rpm or higher the car shudders or dramatises the engine braking effect?
I'm not sure if this is related to my other engine problems or not?
Thanks Adam
Quote from: "Jap GT300"Also when letting off at 4000rpm or higher the car shudders or dramatises the engine braking effect?
I believe that's quite normal for lighter flywheel. The more it weights, the more energy it stores. And when you engine brake, that energy is released...so heavier flywheelhas slower engine braking than a lighter flywheel.
mph
Quote from: "Jap GT300"I have the Toda installed as well.  For those with an SMT do you notice (Especially in 3rd gear) under hard acceleration when changing gear you get an over run of revs?
I only get a problem with changing up under light/part-throttle - full throttle is always fine. Letting off the throttle abruptly (especially in 1st/2nd) is rather noticable, but nothing unexpected for a lightweight flywheel. I'd blame the missing turbo for your problems   s:wink: :wink: s:wink:
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Jap GT300
Quote from: "mph"I only get a problem with changing up under light/part-throttle
Hmmm. light/part-throttle I haven't tried that in a while   s:wink: :wink: s:wink:
Quote from: "Jap GT300"Hmmm. light/part-throttle I haven't tried that in a while   s:wink: :wink: s:wink:
That's the throttle position you have to use when some Civic floors his in front of you. Otherwise you'd hit him  s8) 8) s8)
