Amp Problems
Started by rtbiscuit, March 17, 2007, 19:01
why would it solve teh problem though?
10 to 1 says its Dan's wireing!  s:wink: :wink: s:wink:
only kidding too mate
Quote from: "kanujunkie"10 to 1 says its Dan's wireing!  s:wink: :wink: s:wink:
Don't you have any confidence in our Dan's electrical skill then Stu  s:? :? s:?    s:?: :?: s:?:    s:lol: :lol: s:lol:
philster_d
Adding a resistor will do nothing to help.
you are probably mixing up that with adding a capacitor to a circuit design to reduce electromagnetic incompatibility.
adding a fuse, on the otherhand may be useful   s:D :D s:D
Quote from: "heathstimpson"
You never saw my attempts at soldering the Profec in, did you Heath?  s;) ;) s;)
rtbiscuit
the system has a 40 amp fuse in, if the fuse value is to high would that affect the amp?
current car: Jaguar XKR
Previous cars:
mr2mark
well try a 10amp fuse...... The worse thing that can happen is blowing the fuse..... its safer than 40amp.
filcee
You can't see electric when it's leaking.  No wonder Dan's having problems.   s:lol: :lol: s:lol:
Phil
2003 6-sp SMT in Sable
rtbiscuit
you fancy meeting up again this weekend dan to finish this off, or are you busy this weekend!
Previous cars:
I've got friends over all weekend bud so will be a tad busy, but let me know how you get on with it.
Rich, i'm going to try and re-arrange a date with Liz to do hers, perhaps we can do yours at the same time?
rtbiscuit
#36
that would be great,
i am going to try a few of the test mentioned previously, to see if i can get it to power up on its own.
Previous cars:
rtbiscuit
when removing a scotch lock, or wire connected to one. do i leave the lock in place and just cut loose the wire i need. or can i remove the lock.
i need to move my live feed from the black wire to the blue and white if i am correct.
blue and white is the ariel isn't it?
what was the black?
and if i do this will the supercharger noise go?
Previous cars:
remove the lock completely (carefully) and tape over teh cut
rtbiscuit
cheers
Previous cars:
#40
 m http://www.stuandele.co.uk/mr2roc/aerial.pdf m
do yourself a favour though Rich, dont use scotchlocks, they are quicker but are terribly unreliable
rtbiscuit
#41
what should i use instead
Previous cars:
Liz
#42
As for dates I am available on next Sat and Sun if any use, we can go for lunch if you like, room around mine to do the work if necessary.
rtbiscuit
#43
sounds like a plan!
Previous cars:
rtbiscuit
#44
Have got it all running!   s:bounce: :bounce: s:bounce:    s:mrgreen: :mrgreen: s:mrgreen:    s:bounce: :bounce: s:bounce:    s:D :D s:D
swapped the remote wire over to the blue and white!
was a bit hit and miss, first time i did it, it all worked, the started to put the dash back together and then it wasn't working.
so dismantled again, checked all connections, and tidied the wires up in the bin, disconnecting them all and reconnecting. tried again and it was all working.
tested as i put it back together at all stages and it is all working super. he amp is on, the sub works and the setup sounds great!
my only problem was that when i came to move the car i had run the battery flat.  s:roll: :roll: s:roll:   managed to push start it, but then the power steering had gone!  s:x :x s:x   went for a drive came back turned off. came back 5 min later, and now the power steering is fine.  s:D :D s:D
so its all A.O.K  s:D :D s:D
tomorrow i shall check the fluid level for the pwer steering when it is daylight!
Previous cars:
#45
get those god damn awful scotchlock things out Rich, they really should be banned  s:? :? s:?   put some propper butt splices in
rtbiscuit
#46
well stu, you can come and splice my butt anytime  s:wink: :wink: s:wink:
Previous cars:
#47
oooooeeeeerrrrr  mrs!  s:oops: :oops: s:oops:
trying to sort a date out with Liz to come here, if you can do that date then i'll shove some in for you  s:wink: :wink: s:wink:
rtbiscuit
#48
i'll defo come down,
and we can put it as a possible if there is time, as it all works,
and if it is next weekend i may be helping si fit his manifold!
Previous cars:
Glad you got it all working mate, and apologies for the slight wiring issues  s:oops: :oops: s:oops:
