oh dear there goes teh gearbox
Started by markiii, May 7, 2007, 19:05
#75
I thought the MR-S and Celica boxes are the same, only difference being the gear change stick. And they sure seemed identical, when they were side by side.  s:? :? s:?
We took the input shafts off the box already when we removed the box from the car and left the shafts there, so that wasn't an issue. It just seemed easier this way, cause we didn't have any special tools either.  s8) 8) s8)
I think we are talking cross terminology here
Tem, if you left the input shafts on teh car I assume your talking about driveshafts?
Stu is talking about teh Primary shaft in teh box itself
#77
Quote from: "markiii"Tem, if you left the input shafts on the car I assume your talking about driveshafts?
Oops, driveshafts that is.  s:oops: :oops: s:oops:
QuoteStu is talking about the Primary shaft in the box itself
When we opened the "LSD-end", all the shafts remained in the other end of the box. I'll see if I can find the pics I took.  s8) 8) s8)
#78
Interesting - we've already tried to take the bell housing (clutch end housing) off the main gearset housing, and it wouldn't come off (or rather it would pop off about 2cm and then stop - with no amount of hammering on the input shaft with a hide hammer making it go any further).
Looking at the BGB it appears that the splined section of the input shaft (which usually goes into the clutch) is wider than it's plain section, meaning it wouldn't fit through the input shaft bearing.. but you're saying the only thing jamming both halves together is the gear selector mechanism?
Right, just ordered a UK 6 Speed LSD box for £246 with 43K on teh clock
should be here Thursday
anyone know how I can identify a 6 speed from a 5 speed by sight before I install it?
Will it have a part no. on it? Check with toyota if it has?
anyone know where I can get a magnetic gearbox drain plug?
#82
Quote from: "markiii"Right, just ordered a UK 6 Speed LSD box for £246 with 43K on the clock
You and your ruddy bargains, jammy sod  s;) ;) s;)
Pretty sure the casing is the same either way, so perhaps the shift forks and bracket is the best way?
Oh - and to check it has the LSD, if you can see through the output hole it doesn't, if I remember rightly..
#83
Quote from: "aaronjb"you're saying the only thing jamming both halves together is the gear selector mechanism?
It's not the only thing, but it's one thing.
This is kinda hard to explain, cause I have no idea about the correct english terms  s:? :? s:? , but here goes. There are three small steel balls against the shafts. You can remove them from outside, they are under bolts through the cover. You can see there in the exploded views in BGB and maybe it'll make more sense than my explanation.  s:lol: :lol: s:lol:  But you probably need to take some or all of them off. It might be different depending which end you open, but IIRC, we had to remove one of them.
It opens roughly an inch without excess force before you remove those. We had the same issue and you can't force it open much more than that without breaking anything. Once they are off, the halves are completely loose and you can just lift it off.
#84
Quote from: "markiii"anyone know how I can identify a 6 speed from a 5 speed by sight before I install it?
I'd say you can't. They are identical, including the labels. But if the gear selector shaft is in place, you can use it to see which one it is. Either by checking the number of gears or the reverse location.
Quote from: "aaronjb"Oh - and to check it has the LSD, if you can see through the output hole it doesn't, if I remember rightly..
Yeah, that's correct.
#85
Quote from: "Tem"This is kinda hard to explain, cause I have no idea about the correct english terms  s:? :? s:? , but here goes. There are three small steel balls against the shafts. You can remove them from outside, they are under bolts through the cover. You can see there in the exploded views in BGB and maybe it'll make more sense than my explanation.  s:lol: :lol: s:lol:
Hmm.. just looked through the BGB and I can't figure out which parts you're referring to  s:lol: :lol: s:lol:  D'oh!
#86
I'll try to explain it better later tonight with the BGB in other hand.  s:D :D s:D
#87
Quote from: "Tem"I'll try to explain it better later tonight with the BGB in other hand.  s:D :D s:D
 s;) ;) s;)  I'm sure it's not your English - just me not being able to see the bits in the diagram that you're referring to  s:) :) s:)
There's always method no 2. for casing removal I suppose: an angle grinder  s;) ;) s;)   s:lol: :lol: s:lol:
SteveJ
#88
Quote from: "Tem"
Page MX-18, para 21  s:?: :?: s:?:
philster_d
#89
errrkkkk
Think I have a problem, is it gearbox week or what ?
I can hear a knocking when going slow maybe in first gear, seems to be pulling ok etc. Sounds like a diesely noise in fat I dismissed it as the white van behind me at first. Just got home and noticed it again while parking up.
Sounds awfuly familiar.
Just check the dipstic, there is a bit of residue, not exactly grit but clearly not good.
Phil
you won't get gearbox remains in teh sump Phil, the oil supplies are completely seperate
philster_d
#91
OK could just be dirty then.
Still seems to be drive or load related, the engine revs freely enough.
#92
You sure it's not the belt tensioner, Phil?
Work in progress for me too  s;) ;) s;)
Damn fu**** bearings !
Did you find a new gearbox markiii?
#94
Congrats on managing to get that driveshaft out with it all still on the car Ben - it takes a fair bit of thumping with a drift, doesn't it!
When we did Marks we actually pulled the hub & driveshaft off with the box and removed it once off the car - easier to get at it that way..
Oh and..
*points at the trolley jack* See guys, told you we should have done it like that  s;) ;) s;)
*hides from Mark & Stu*
thx lol
I had to get out the driveshaft before the gearbox, cause my MR2 was stuck in front of my house, outdoor, and gearbox blocked, so it was my only solution to get it indoor... :S
Does the other driveshaft is as hard as the first??!!
It was really fuc***** boring to get it out  s:( :( s:(
#96
Nope - the other driveshaft has no snap-ring, it just slides right out  s:) :) s:)
In fact, we dropped the box off the driveshaft, rather than remove the driveshaft.  If you drop the centre bracket off the block that might make things even easier.
Quote from: "aaronjb"Nope - the other driveshaft has no snap-ring, it just slides right out  s:) :) s:)
Thank you for this news, you just make me smile after 2 crying days !
 s:D :D s:D
Now, I just have to wait all my parts...
#98
Quote from: "Tem"
Check the page MX-11. The first one is on the top right corner, Ball, Spring, Seat and a 25Nm bolt. There are two more on other shafts.
#99
Ahh! D'oh!
See, I told you it'd be me not seeing something, rather than your description  s:) :) s:)
