Fuse for aerial
Started by Anonymous, January 10, 2008, 13:22
Apologies if there is already a thread for this topic but i couldn't find it using the search option.
If i was to remove the fuse which the aerial works off, would it stop anything else from working?
Also if it wouldn't stop anything else from working....where is the fuse situated?
Thanks in advance
The power antenna gets it's power through three fuses - unfortunately all three control other things (one is the dashboard fuse - so you can't pull that, and it also draws through RADIO1 and RADIO2 - both of which also supply the radio).
Best thing is to unplug the relay module - under the drivers side rear bin (five screws - three on the door, two on the rear of the bin).  It's the black module just left of the fuel tank trap door.
