Are my tyres right? Wheel size help
Started by Ilogik, December 21, 2008, 14:03
Ilogik
As I can't  see wheel sizes on my wheels, I measured them, im pretty sure im running 16x8 front and 16x9 rear. Need to work out the et but pretty sure from hub to outer on front its 5cm and on the rear its 7 1/2 cm.
Currently running 205/45/16 front and 215/45/16 rear. Rear looks a little stretched so would like to go a size bigger.
Ex: TRD stage 1 TTE Turbo
Ilogik
bump, anyone?
im pretty sure they are 16x8 and 16x9 as I measured from the inner lip to outer lip. Unless I have managed to gain an inch on both.
fstsven
Go for 225/45/16 at the rear. I did, no issues.
2004 fire red TOYOTA MR
K&N air filter
BLUEFLAME single exhaust
3.ORACING breastplate
25 kgs extra lightness
Quote from: "Ilogik"bump, anyone?
I'm pretty sure they are 16x8 and 16x9 as I measured from the inner lip to outer lip. Unless I have managed to gain an inch on both.
measuring can be deceptive, it should be stamped on teh back of teh wheels
Ilogik
Quote from: "markiii"
measuring can be deceptive, it should be stamped on the back of the wheels
cool, will try removing the front wheel, see if they are stamped on the inner side of the wheel.
