The size of stock bumper opening
Started by Tem, January 2, 2009, 20:28
Anyone happen to have the width/height of the stock (pre-facelift) front bumper opening?
The big one that is. Can't measure mine right now and need it.  s:? :? s:?
Sepp
It is 950mm wide and 95mm high at the sides and 199mm in the middle. Measured within the plastic frame.
Hope that helps.  s:D :D s:D
Quote from: "Sepp"It is 950mm wide and 95mm high at the sides and 199mm in the middle. Measured within the plastic frame.
Thanks Sepp! That's perfect.  s:D :D s:D
