Corkys like breastplate
Started by FuZZy_gr, January 1, 2010, 09:22
I'd be intrigued to see an estimate cost for teh spec you listed Chris as so far 12mm thick plate is looking rather expensive,
do you reckon these would match or better teh usual price of a corky plate?
ad_car_08
Quote from: "ChrisGB":roll: Lazy cad designer. The information box shows dimensions in "inches (mm)" but the cad designer has neglected to tie up the units. Much of the other stuff in the box is irrelevant too. Why do cad guys do this so often. No wonder stuff is so expensive. Also, 619 x 280 inches is 15.722 x 7.112 Meters, which will foul the wheels and passing traffic and make parking tricky. Actual blank size is 619 x 280mm. No material thickness is specified either, but we do know it should have a maximum surface roughness of 250 Ra.
For anyone not finding that tying up these basics is not obvious, I would suggest that making bits for the car is not what they should be doing.
If I had enough time, or interested parties, I could get some ally ones made up.
Chris
Alright, alright, no need to get all moral and upity...so I made a slight mistake with the conversion of measurements..  s:oops: :oops: s:oops:
Thanks for the clarification non-the-less
[/size]
that CAD picure just shows where to drill the holes not how to make the brace
I think the LM Corse plate was 6mm sheet type design, here is a pic of my original one that was fitted to my first Roadster, next to the stock items.
having owned both an original MR2 Spyder one, owned a corkies, and experience both teh lm corsa and cusco versions I'd lean towards the corkies every time
I'm relatively sure that flat 12mm plate as described by chris would be similar in result to teh corkies though obviously I have no empirecal evidence
the problem is whether you can make something as effective as corkies for teh price you can buy a corkies
FuZZy_gr
Quote from: "ad_car_08"FuZZy_gr - how much angle metal did you use to make this? My brother is quite handy with a welder, and has 3mm thick metal lying about his garage that he said he'd happily donate, but I fear it'll be way too thin to be able give any kind of rigidity as a brace, so am looking at how much materials would cost!
The materials cost me about 18pounds and i used the angle because the flat metal sheet has more streching than the angled one. Thats why corky uses the angles in the center just to reduce the twist of the brace. I just added angle to the perimeter too to make it even more rigid.
ChrisGB
Quote from: "markiii"I'd be intrigued to see an estimate cost for the spec you listed Chris as so far 12mm thick plate is looking rather expensive,
do you reckon these would match or better the usual price of a corky plate?
If I can get Autocad R14 working in Vista, I will rustle up a drawing and get it quoted next week.
Chris
ad_car_08
Quote from: "FuZZy_gr"
but how much angle did you use? length?
[/size]
FuZZy_gr
It is 90 degrees angle and it was 6 meter long before i cut it to pieces. It is not exactly a usual angle. Its one side has 6cm width and its other side has the half width(3cm).
ad_car_08
Brilliant, thanks fuzzy!
[/size]
dj2k21
I for one would be very interesting in buying one of these braces in ali if they are made.
and people on this site seem to be talking about corkey braces as though everywhere sells them and they are very easy to obtain, I cant find one anywhere lol, can someone point me in the right direction to get hold of a corkey's? thats the only suspension mod I feel I am missing now.
thank you  s:) :) s:)
nathanMR2
#36
I too am after a Corkys, so if something simular is made and tried and tested, then im sure a few people would be up for them on here.
2nd hand Corkys do come up from time to time but they are usually snapped up pretty quick.
If its a Corkys you want your best trying SpyderChat, you more likely to get one on there, just depends on how much you want to fork out
FuZZy_gr
Can someone tell me what is the weight of the corkys?
ChrisGB
Quote from: "FuZZy_gr"Can someone tell me what is the weight of the corkys?
Cannot tell you the weight, but it is light enough to make no perceptible difference to the cars accelleratio.
Chris
Mad Matt
I could be interested in this too. I've got a rollover bar, which may help stiffness to an extent, but from what I've read here this kind of thing would make a nice improvement.
Rollover bar? Are you sure or do you have a style bar?
Style bar will add no rigidity to the chassis, the proper roll bars may however but I dont know anyone who has one in the UK
Mad Matt
#41
I would imagine it's a style bar, but it came with the car so I can't be sure what its for. It's chrome finished but quite thick (which is annoying for looking out the rear) and it seems pretty sturdy but hollow.
Looking around, I think it's this one  m http://www.tte.de/popup/TTE/cm_mr2_rollbar.htm m
I'm not claiming it does stiffen things up, it just occurred to me that it might given that it's lateral strength should be reasonable.
Chris
Umm. Step of the soapbox sir.
Actually I drew that drawing a while back. The reason it is messy is that my CAD pdf macro (automatic, one button) lobs on my standard drawing border (inch primary units) unless I tell it otherwise and getting this up was a quickie for the forum; I did not post up my own final drawings - that is simply giving too much away....
As for not making bits for cars - you are correct; my company actually works on a load of high pressure containing critical products and is highly paid for its expertise..... for good reason : accuracy and speed. If you use oil based products, then these have likely come through equipment with my company engineering in there. If you heard of the bad weather shut down in Norway that threatened our gas supplies over this cold snap then know that my company designed the flexible pressure piping on the well completion system in that massive gas field.
nathanMR2
#43
Im looking at getting a Corkys 'like' breastplate made (im just speaking with a few contacts). It wouldnt be bits welded together, it would be complete. I need to work out pricing, but im looking to guage some interest.
Would anyone else be up for buying them if i can get it sorted for less than a Corkys shipped?
FuZZy_gr
#44
I would like to see a complete plate but welded parts are the same as the complete one in strength except that the welded parts need more work to become so good looking as the complete.
nathanMR2
#45
Ive start a GB thread.
Im no expert but im guessing that this plate will be under continous flex and stain. I would have thought no matter how good the weld is it likely to crack at some point with the pressure its under.
Ill see what prices i can come up with
ChrisGB
#46
Quote from: "sjspitz"
Chris
Hehe, sorry, did not realise this was a draft. My quality management background mean that I have seen so many under or over priced, under or over specced, mis quoted or rejected parts due to someone injecting a draft into the system on a "standard" border and box that it just sends me off on one  s:oops: :oops: s:oops:   I have even seen expensive bits made in mm that should have been in inches and vice versa. And the cost of those was nothing compared to NASAs loss a few years ago for a similar error.
Quote from: "sjspitz"As for not making bits for cars - you are correct; my company actually works on a load of high pressure containing critical products and is highly paid for its expertise..... for good reason : accuracy and speed. If you use oil based products, then these have likely come through equipment with my company engineering in there. If you heard of the bad weather shut down in Norway that threatened our gas supplies over this cold snap then know that my company designed the flexible pressure piping on the well completion system in that massive gas field.
Again, sorry. The design is obviously well considered and you clearly understand the stresses the brace will be under and it is IMO very nicely drawn. I have no doubt that you would make this sort of thing without any problem. What I was getting at is that if someone where going to use your drawing to make the brace who did not easily figure out the dimension box discrepancy, they would probably not be suitably qualified to make something for the car where safety could be an issue.
Structure wise, comparison between a solid 12mm piece vs a welded angle reinforced 6mm piece will be interesting. I am sort of swamped at the moment, but am generating something for pricing purposes. I would value your opinion on it when I have draw it.
Chris
No worries Chris... I did think about what you were saying about people using the drawing as provided and it ending up costing someone money in mistakes so I have updated my drawing to the latest version and I also combined all 3 pages of the drawing so all the info is there.
I am perfectly happy to update this drawing as appropriate for the community and to keep it published on my box.net account at http://www.box.net/shared/0jzj10g4ej so it we work together we can end up with a design that everyone is happy with and which is 'makeable' that perhaps someone can source.
To reiterate my points elsewhere in the board, this part as I have shown it fits my X-plate roadster perfectly. The only problem with the design as shown: the three holes used to fit the Toyota pipe clips into are actually odd shapes (two are rectangular and one is oval); this is fine for thin plate that can be pressed and where the pipe clips can stick through the plate. With the thicker plate I used, the clips cannot stick through and the holes cannot be so easily formed.
When I get some time I will run a comparative FEA between the part as shown with one made simply from thicker plate perforated with holes in certain places for lightness i.e. one not requiring welding. I have been wondering if a solid slab of 10mm thick GRP would be a superior solution but again, have not had time to get into it in any detail - other than - it will cost a shit load more in GRP.
ChrisGB
#48
Quote from: "sjspitz"To reiterate my points elsewhere in the board, this part as I have shown it fits my X-plate roadster perfectly. The only problem with the design as shown: the three holes used to fit the Toyota pipe clips into are actually odd shapes (two are rectangular and one is oval); this is fine for thin plate that can be pressed and where the pipe clips can stick through the plate. With the thicker plate I used, the clips cannot stick through and the holes cannot be so easily formed.
I was going to have the plates waterjet cut, so the hole shapes are easy, then mill out the areas for the clips and the countersinks for the floorpan bolts.
Quote from: "sjspitz"When I get some time I will run a comparative FEA between the part as shown with one made simply from thicker plate perforated with holes in certain places for lightness i.e. one not requiring welding. I have been wondering if a solid slab of 10mm thick GRP would be a superior solution but again, have not had time to get into it in any detail - other than - it will cost a s**t load more in GRP.
  s:lol: :lol: s:lol:  I was thinking about some 10mm GRP maybe a Tufnol. Also have access to some 6mm Carbon Fibre plate that would look sexy. But Ally seems to offer the best practical option.
Chris
Paulm
#49
How much is one of corkys plates,  I can get a piece of 6mm steel sheet drilled with the location holes with the cut outs in and the angle welded on myself, with the plasma and tig.
Not sure how neat the plasma cuts would be, but it'd certainly do what its meant to £90 plus shipping ?
Might find out how much for an Ali one
Performance:  4.2ltr V8 380hp conversion - DTA S80 ECU- DTA S80 EMS - Ferrari F360 exhaust - de-Cat\'d
Handling : Brace bars front & rear - EBC Drilled and Grooved - 205/225/40/17 - ETA Beta Alnir\'s- 2\'s rUS drop links - Ultimate breastplate
Future uprades - Supercharger- Ultimate floorpan brace and front brace - 355mm discs - Widebody kit
