HELP! WHISTLE SOUND WHEN ACCELERATE!
Started by Anonymous, February 15, 2010, 16:07
vinp182
#50
Did you find out what this was cuz mine does it   s:( :( s:(
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
vinp182
#51
Just thought i'd post up what i found for anyone else that might have this problem
My problem was the cat
 When i had it removed we found that there was hardly anything left of it which was making the whistle sound
New custom exhaust with sports cat has solved my problem   s:D :D s:D
1994 Rev3 Turbo mk2
Interesting that's the second main cat I've heard of disintegration recently!
The Gimp
#53
Quote from: "uktotty"what is an accessory belt? Sounds like something from Primark
Made me giggle lol!!
You sure your car isnt supercharged  s:) :) s:)
But more seriously, it could be a loose bearing (but thats generally more of a wurring sound).
Have you had the car pressure tested for air leaks, water leaks, etc ? Not sure if this would help...
Im not sure how much its going to cost to have belts replaced, but im sure its worth replacing if not expensive?
Can you run a car without certain belts? I know you can run without auxilary (correct me if im wrong), but the alternator, etc wont charge, power steering wont work... but might help diagnose where the issue lies.
(im not a mechanic, but just trying to think of issues from my previous cars)
The Gimp (Shane)
TF054
Facebook: Clicky
FGrob
#54
Quote from: "The Gimp"Can you run a car without certain belts? I know you can run without auxilary (correct me if Im wrong), but the alternator, etc wont charge, power steering wont work... but might help diagnose where the issue lies.
(Im not a mechanic, but just trying to think of issues from my previous cars)
You can run them for a short period, but remember your water pump is also driven by this belt and it will overheat after a period of time.
Power steering is an electric pump at the front on the car   s:wink: :wink: s:wink:
Rob.
The Gimp
#55
Quote from: "FGrob"You can run them for a short period, but remember your water pump is also driven by this belt and it will overheat after a period of time.
Rob.
Cheers Rob  s;) ;) s;)
Maybe worth removing the aux belt, give it a rev ... listen to see if the whistle is still there then?
My mate has a supercharger sound coming from his car yesterday, due to a loose belt... Might be an idea to check tension on all belts?
The Gimp (Shane)
TF054
Facebook: Clicky
