Wonky headlight
Started by jjr197, March 19, 2010, 14:02
jjr197
Hi all
Having finally found me an MR2 (2002) I've noticed that my left hand head light points quite a bit higher than the right hand side one. I'm guessing that I can adjust the reflector in the head lamp, but I thought I'd check on here to see if anyone else has any thoughts.
I know that the front bumper has just been replaced (no big accident though!) so could it be that it was knocked when the bumper was taken off/replaced?
Jimi
"If you're driving with the top up, the storm outside had better have a name!"
Two likely reasons....
1. The headlamp unit has not been replaced properly, or
2. The bulb has jumped out of, or has not been fixed properly in the headlamp.
Both need careful checking, but if you can wobble the bulb from the back of the headlight I guess it would be the latter.
ChrisGB
Quote from: "jjr197"Hi all
Jimi
The headlights do not need to come off to remove the bumper IIRC. If the bumper has been replaced, there is a chance that whatever necessitated that change has knocked the headlight out of adjustment. Another possibility is that the bulb has not been seated properly. Also, some cheaper bulbs do not have accurately located filaments, so quite a lot of adjustment can be needed when they are fitted.
Adjustment is pretty easy anyway, so nothing to worry about.
Chris
jjr197
Cheers guys.
What with the rugby...... and the beer...... I didn't get round to sorting this out at the weekend, but it looks like quite an easy adjustment to make.
Jimi
jjr197
Had a fiddle (ooo errrr matron) and the bulb simply wasn't fitted properly.
Only thing is..... now I want brighter ones!!!
