Noob stereo question....
Started by ex-member, July 21, 2010, 14:13
ex-member
When looking to buy a cd player for the car...does it need to have anything specific, connector-wise? I can see on the unit at the moment, that the main one that was used was a chunky rectangular plug?
You'll need a Toyota to ISO connector. Quite cheap on well know auction sites. Or the ability to join tons of wires together  s:wink: :wink: s:wink:
ex-member
Ahhh haa, well I'd pressume I have one in there already seeing as Mark had that Kenwood unit fitted! I shall but a headunit and see if it fits!
Cheeeeers  s:) :) s:)
skinz
Mines originally had a kenwood in it, and i replaced it with pioneer - needed to buy a new wiring block for this, and due to my impatience it got it from halfrauds so lyk £15- but can prob get them cheaper online, iirc some suggestions were that you need a pioneer/sony/jvc (or watever brand you got) to iso connector, and also iso to toyota. But mines worked with one, so think it depends on headunit choice depended on if you will need 1 or 2 looms.
If not already get your aerial on a rocker as its uber uncool for it to go up auto everytime u turn on hu. - esp since your car looks ace :p (will try an sweet talk u up until the day u sell ur car, in hope that u will consider selling me the alloys - lol jokin m8  s:P :P s:P )
kentboy
Another Noob here.....
Have been given a nice BRAND NEW Pioneer single DIN head unit.
Anyone know where I can get a decent conversion kit to change from the double DIN?
Ta!!!!!!!!!
VVT-i
2005 MR2 Roadster  (Black)
kentboy
Marvelous!!!!!!!!!!!!!!
Thanks for that.
One more question, what size are the standard door speakers.
Found a nice set of speakers/tweeters for £40 ish depending on size
ex-member
Ok folks....bought a cheap CD player to replace the broken one, and the plugs/connectors for the old unit dont fit the new one - doh!
Here's a photo of what's on the rear of this new one:
And these are the "obvious" dangly connectors that are already wired into the car.
Finally, these are the connectors that came with the new (maybe new isnt the word...) stereo - not much use to me as they're all chopped off!
Davy - would that link you posted above work for this? The new stereo has a bigger connector (connector being the main on at the fuse in the stereo itself) than my old unit.
If not, does anyone have any idea what I need to fit this lil beastie? thanks in advance!
you can put the plug off and join. guys correct me if im wrong.
yellow is main live straight from batt
red is a live from the ignition
black is earth
orange is the ilumination wire
blue is live out for sub etc
then the speaker wires
white and white/black is one speaker on front not sure what side (im thinking this is right)
grey and grey/black is another speaker on the front (im thinking this is left)
then purple and purple/black is a rear speaker
and finally green and green/black is the last rear speaker.
hope it helps
richard
ex-member
Cheers dude, but I think I've found a simpler solution (phew!)  s:) :) s:)
