Engine light comes orange after 3 miles
Started by rabscott2003, August 12, 2010, 00:34
rabscott2003
could bypassing the air filter work? or even if i removed the air filter altogether. I am getting a OBD2 reader but dont know which one to get for engine management. DO OBD2 readers operate the clock too? As i need to put my miles up on the speedometer once its fixed as the clocks where changed from KPH to MPH and they are not working cable has been replaced too but not the gearbox speedometer sensor. Think it might be faulty, a mechanic fitted the new clocks and cable andi ashume he done it corretly.
Well what ever i done to correct the engine light its been 3 days now and its never came on.
Can a OBD2 reader calibrate the engine settings?
If your import came from outside Europe an OBD2 wont work in it,reasonably priced readers have yet to be sourced for imports.Which is why I referred you to this in an earlier post.  l viewtopic.php?f=11&t=30617 l  Spoon feeding is over now,you need to use the search for your answers.
Turbotrucker
QuoteI am also thinking of replacing the lights to Halogen, has anyone done this and i seen a kit on ebay for £40 should i do this?
You could do this, but your car doesn't have auto levelling on the headlights, so is illegal really. I think only traffic cops might spot it though. oh and everyone coming towards you at night, but they'd be blinded. I've contemplated this, but for these reasons I didn't. Don't think it'd fail mot though. Your choice.  s:) :) s:)
2005 Sable grey Red edition,2zz by Rogue,Toyota GB skirts and spats.Markiii pipe+k&n Panel, Rogue manifold, Sports Cat,TTE Exhaust, TTE style bar, S2000 Seats, Mongo's;) Red Mohair Roof, Whiteline ARB's.
The headlights should already have Halogen bulbs in them.
If you're talking about HID, then it's a bit more involved than just fitting bulbs, you need stabilised optics too.
However in the UK retro-fitted HIDs are not legal (just to make the statement of law).
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
rabscott2003
Your all right i checked it, its not worth the hassel i am sticking with the ones i have they are good anyway.
I have however asked an auto electrican about my speedometer problem, i also phoned a few garages and expained the situation but none want to help or even take the job on. SO i have posted pics of the change over from KPH dial to MPH dial and all the wiring behind the speedo so maybe someone who has done a convert from the KPH to MPH dials can see if the wiring is correct.
Thanks again
rabscott2003
 m http://s925.photobucket.com/albums/ad95/rabscott2003/ m  check the pics of the car and problems with the speedo
Thudd
Quote from: "rabscott2003"but i think it is 6.8 sec 0-60mph
s:lol: :lol: s:lol:
More like 8.6!
rabscott2003
Saying that I tested it 8.9 but I was too late on the 2nd gear change
redcarblackhorse
i had o2 sensor engine light come on. Frogger told me how to check the engine light error with a paper clip. See my posts. There are only 2 lamda sensors on the exhaust. I read somewhere they need replacing at about 70k miles. Cheapest place i found them was camberley auto factors. About 50 quid each. Toyota ask 160 quid.
Once you have replaced the sensors don't forget to reset your ecu to clear the errors.
1999 MR-S with a few tweaks!
Circuit de catalunya
24 Heures du Mans
Thruxton
Abingdon Track day
