Speed and G's MR2v350ZvWRXv911turbo
Started by MRMike, March 15, 2004, 21:44
MRMike
Not sure if anyone else is interested..but I find these things really interesting..It's a graphical representation from the software you get on a GTECH PRO Comp. These are G's and speed graphs.  I was amazed at how well the MR2 launches, light weight, mid engined etc it's 0-60 foot time is quicker than a 350Z, and not far behind a 911 turbo which has monster power and 4wd. It pulls quite a bit more G from the start than the 350Z.
 m http://www.SpyderMagazine.com/files/MR2 ... 1TTg's.jpg m
Also speed wise this graph is pretty interesting, notice how the MR2 is pretty much with the others in first, but then falls away at the end of second.  What is remarkable though is the 911's pace, which seems to increase at a linear rate in the first three gears!  I Thought it was incredible to see the difference between a quick, fast, and bloody fast car!
 m http://www.SpyderMagazine.com/files/MR2 ... Tspeed.jpg m
Anyways thought I'd share!
Then.. Blue 350Z
NOW M3 V8
looking at the second graph, im assuming where the graph straightens out is when their is a gear change, and it looks like 2's 2nd gear takes to 65mph. Mine only takes it ti 59mph, though it is a j-spec   s:? :? s:?
MRMike
Yeah that's right it is second! Though the ratios between 5 and 6 speed I believe are the same so I would assume it would do the same speeds? Not sure if the ratios are any different between UK and imports though?? Maybe the GTECH is off or a speedo is out? I know mine will go beyond 60 in second if it really has to...  s:? :? s:?
Then.. Blue 350Z
NOW M3 V8
mine definately hits the limiter at 59mph, which means i have to change up to third to get my 0-60 time   s:x :x s:x   j-spec 2's must have shorter ratios. why would they change this for the UK?
MRMike
I've done a few searches and nothing come up..maybe one of the Guru's could answer ! I'm pretty certain the ratio's would be the same
Then.. Blue 350Z
NOW M3 V8
Blatantly stolen from SC,
Courtesy of WalkSkyluker
Ratios
US Spyder
3.166
1.904
1.392
1.031
0.815
F 4.312
Europe Spyder
3.166
1.904
1.310
0.969
0.815
F 3.941 (LSD)
Europe 2003+ 6spd
1. 3,166
2. 1,904
3. 1,310
4. 0,969
5. 0,815
6. 0,725
R. 3,250
LSD 3,941
6-Celica & Matrix XRS
3.166
2.050
1.481
1.166
0.916
0.725
F 4.529
6-Corolla (europe only? I hadn't heard of this one)
3.166
1.904
1.310
0.969
0.815
0.682
F 4.529
USA Corolla 1999-2002 (5spd manual)
1st 3.166
2nd 1.904
3rd 1.310
4th 0.885
5th 0.725
Reverse 3.250
Differential Ratio: 3.722
USA Corolla 2003?
1st 3.17:1
2nd 1.90:1
3rd 1.31:1
4th 0.89:1
5th 0.73:1
Final drive 3.94:1
any j-spec ratio listings available?
MRMike
Thats interesting about the US ratios, is this presumably because of their lower avg speeds ?? and the need to have more torque in 3rd??
Then.. Blue 350Z
NOW M3 V8
nothing I could find.
Adam anything you have from teh imprt spec sheets?
