Speed Computer
Started by Anonymous, March 20, 2004, 12:27
Quote from: "perry190"the base weight for a manual is 1225kg (2701 lb) or for an SMT  1235kg (2723 lb)
Those must be assuming there's a driver and passenger in the car?  s:shock: :shock: s:shock:
The manual without AC is quoted to weight 975kg...that's without anyone in the car.
these figures i think are from the Toyota manual which are normally worst case scenarios i.e. inc driver, passenger and possibly some luggage
its well worth getting it weighed properly on a weight bridge with you in it as the weight is critical to the calculations the gizmo does
as tem said every bodies car is slightly different and it matters
