Leaving roof down
Started by Richsouth, April 2, 2011, 17:56
Richsouth
Iv taken the wheel out so the alarm sounder is exposed and there is still no sound at all...
SimonC_Here
Obvious question but have you checked the plug is all the way in?
calaerial
As many have said, if i can see it from where i'll be - I'll leave it down.
Or if its say, on my mothers driveway where i'll be able to hear the alarm from within, same.
Otherwise it goes back up. Too many vandals.
It also depends on what you leave on show. Some probably obvious pointers that are worth repeating:
The radio on the '2 is bolted in such a way that its gonna be a bit of a  sbastard bastard sbastard  to steal quickly. But that wont stop some scrote stealing your front just out of badness. Take it off.
Dont leave a sat nav charger or mount on display, even if the sat nav itself is locked away in the glove box. It just advertises that you own one, and its a pretty safe bet its in the car. Fair play it locks but a pry bar will have that open no problem. Even if the sat nav isnt there, you dont want some smashing open your dash to find out.
Make sure you lock the bonnet/fuel door release mechanism
Even if the glove box is empty, lock it, or your frunk is also unlocked.
Be aware of the weather, if it looks like it might change in a hurry, dont chance it. I had to towel dry about a gallon of rainwater out of mine the other week because i wasnt paying attention.
Work in progress - 2001 MR2 Roadster - Silver
Current faults:
General dings
Rotten brake discs
Sticky aerial
