turboing a SMT
Started by Anonymous, October 26, 2011, 14:27
i have found a turbo kit for the 2 but was off a manual. would this be able to go on my smt with all the existing ecu component? the turbo kit is running a HKS Fcon ProV which is tuned for the manual, so would i need to retune?
Manual and SMT makes no odds when it comes to tuning a car, however..
The SMT requires (absolutely) the stock ECU and various signals to & from it in order to know how & when to shift gears. That mens you can only use a piggyback ECU for fuel & ignition mapping.
Fortunately, the HKS Fcon ProV is a piggyback.. however (to my knowledge) nobody has ever done what you are about to do before, so you're basically on your own and at the mercy of finding a tuner experienced enough to know how to make it work and overcome any hurdles that might come up. It might be plug & play, it might not..
FWIW the only SMT turbo I know of used a Unichip, though I suspect there's a TTE one around somewhere (both are piggyback ECU solutions)
Quote from: "aaronjb"Manual and SMT makes no odds when it comes to tuning a car, however..
meaning HKS Fcon ProV needs to be rewired to my smt and tuned. any idea where i can get it tuned?
as long as its a piggyback then you can pretty much forget about the SMT
the FCOn will likely need connecting to
power
gnd
injector lines x 4
ignition x 4
and maybe a few others. The exact wiring is an unknown as I've never even seen one.
more important is to find somewhere who know ho to tune it as its not a typical piece of kit in teh UK.
In fact I've not heard of anyone on ROC using one before
I would have thought you'd need to keep the boost reigned in, as if you needed to change the clutch to handle the power, the SMT might have an issue adapting to a harsher clutch unit. Just a thought.
SMT can relearn a  harder clutch Nige, and a lightened flywheel come to that
and learn it pretty damn well from memory
Its a very clever unit then, that is useful to know. Boost away then !!
mrzwei
IIRC when Silverstone Performance were offering the TTE turbo kit they did make mention of the SMT. If that is the case, then mattperformance may be worth a pm.
Memory fades, so I may be wrong.
Sorry, Im probably not allowed to use 'IIRC'    s:lol: :lol: s:lol:
i
Ex.MR2 SMT sadly missed.
Tte works quite happily with smt
The first demonstrated was an smt
been doing some research and emailing hks europe about the Fcon (silver case), and no one in uk will tune it due to it being an old version. they will tune the gold case version 3.0, 3.2 etc
