Does anybody have these heated seats ?
Started by Green Goblin, May 4, 2012, 17:28
Green Goblin
Connectors to seat
Again
Wiring loom
Switch
Can't get them to work properly. Or better said, can't get them to turn off ! If I connect teh powercable, they heat, all the time.
Here is schematics of the wiring
[centre]1986 MK1 Sherwood Toning - 2000 MK3 Black
Click here for MK1-keychains - MK2-keychains - MK3-keychains[/centre]
Green Goblin
To be complete:
The purple wire isn't purple, but red/blue
The green wire is green/black
The grey wire is white
mrzwei
I'm assuming the switch means off, heat one seat, heat two seats? I'd be tempted to just try a cheap on /off switch on the one or two setting.
Ex.MR2 SMT sadly missed.
Green Goblin
No there's two switches, one on each side of the steering wheel. But on I and on II, the same green wire is switched on.
Seen rocker switches do this before when the power through them is too high. The rocker gets stuck in a position in this case on.
SteveJ
Is that your scematic or one that came with the heaters? If I had to guess, the switch is supposed to select low or high output which would entail having three connections to the controller PCB (gnd [brown] + 2 others). I suspect the purple being connected to red is the source of the problem, but without a circuit diagram of the controller I don't know for certain.
Green Goblin
This is the one I drew up, this is how it was connected.
There is power going into the circuit through the red and the purple wire, power coming out of it through the green and the white.
paulsutton
Quote from: "Green Goblin"This is the one I drew up, this is how it was connected.
..looking at your switch, these are the original Toyota ones same as mine. If so its a 3 position rocker switch. 1 - Low power  2- Off (Central)  3 - High Power...this is for one seat. Same repeated for passenger side.
pre-facelift silver | recon engine   | SP12 wheels   |  hard top OFF | custom hard top cover | air con | pre-cat free  | che header  | facelift new red cloth seats/doorcards  | Toyota heated seat kit  | TTE twin  | TTE style bar  | rear facelift inserts  | facelift rear lights  | rear spats  | facelift front bumper | roadster luggage | toyota ducktail spoiler | facelift side vents |
Other cars - Suzuki GV1600 softtop with removable hardtops | Nissan 2.2 tdi X-trail
