Wires?
Started by manchestermatt1986, June 14, 2012, 17:29
manchestermatt1986
Iv recently been doing a overhaul on the car and some things need wiring up. The question i need answering is on the thickness of wires.
I have put a new illuminated button for the rear fogs and also im going to rewire my front fog lamps. The fronts are aftermarket and the car is import incase it makes a difference.
Also im going to get an amp for some after market front speakers
Does wire thickness make a diffrerence? Can they be too thin or too thick? are there different types of wires?
I can handle very basic electrics like splicing into things and fitting headunits but just wanted some more tips/knowledge
Toyota/TRD Stage 2 Kit - C-one Wing - Hardtop - Injen Induction - Inner Vent LED\'s - Double Din JVC - Armrest - Painted Calipers - Custom Heatshileld - Two Active Subs In Bins - Blitz Nur Spec-S - Team Dynamic 16" - Twin Vocal Speakers On Bin Lids - JSpec Gear Knob - Che Manifold - Angel Eye Fogs -
Wires can never be to big. Always fit larger gauge wire, otherwise it could cause a fire.
mrzwei
Basically, Watts = Volts X Amps
You know the voltage is 12 and you know the wattage of the speaker or whatever  and, from the above, Amps = Watts divided by Volts.
The thickness of the wire must be able to AT LEAST (as said) carry those Amps or it will overheat.
If you are drawing more than one speaker from a single source wire then the source wire must be thick enough to carry the total number of Amps.
Something like that   s:D :D s:D
Ex.MR2 SMT sadly missed.
Steve Green
Probably best to calculate Voltage at at least 13.5V as that is the charging voltage of the battery, or what the alternator shoves out.
It adds a little more safety factor.
2003 Facelift SMT
Did my old avatar offend you?
manchestermatt1986
So I can't go 'too big' or the wrong type
Depending on amp go for 10 gauge wire should be more than enough, and any wire type be fine.
Steve Green
Any type? Not really.
Most car wiring is made from multi-cored (10 or more) copper as flexibility and vibration issues are usually important. Domestic cables have far fewer cores.
Have a look at http://www.autoelectricsupplies.co.uk/category/10
If you are routing cables through bulkheads etc make sure they are further protected and secured in place.
2003 Facelift SMT
Quote from: "Steve Green"Any type? Not really.
very true but unless your buying twin and earth cable 99% of cables sold in b&q, halfords, etc are all flex ie multi-strand.
SteveJ
Quote from: "rbuckingham"
And as noted by Steve G, they are still not flexible enough - car wiring is 10 strand plus, most of the stuff you get from B&Q et-al will be 3-7 strand.
Ive got a butchered engine loom here Matt. Just come and chop what you want off it.
Steve Green
As a footnote to wiring, it is very useful to follow the colour codes used elsewhere on the car. They are generally standard these days especially any ground -ve ones. It's much better than having a bunch of unidentified same coloured wires when it comes to troubleshooting two years down the line.
2003 Facelift SMT
manchestermatt1986
Quote from: "dick2ski"Ive got a butchered engine loom here Matt. Just come and chop what you want off it.
Thankyou, i may take you up on that   s:) :) s:)
There is a heap of wire in it. Take the lot if you want.
stargazer30
For the AMP wiring just make sure you have an inline fuse within about 10cm of the battery on the positive feed.  Then as has been said the thicker the wire the better.  The fuse fitted should reflect the power of your amp, usually in the range of 20 to 40 amps.  If you buy an amp wiring kit it will have this.
Steve Green
Good advice, but... The fuse is there to protect the wiring and not the device or amp that it feeds.
So the wire must be able to carry a lot more than the amp needs as well.
2003 Facelift SMT
