How to go louder cheaper?!
Started by 2000MR-S, April 17, 2013, 14:33
chris3boro
Quote from: "Zonda_"Alternatively get a BMC style carbon airbox, loads cheaper than an induction kit and does actually benefit performance and gives the engine a lovely roar under load.
Isn't there a bit of hassle to accommodate the air flow sensor?  s:? :? s:?
Zonda_
Quote from: "chris3boro"
Nope, I got my adaptor from Amazon.com, very cheap including delivery.
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
chris3boro
That's handy  s:) :) s:)
Quote from: "mr mr2"Induction kit I got mine off eBay £100 posted from the USA makes a great noise
hope you changed the filter for a decent one,
last ebay special filter I saw killed the engine its filtering was so bad
nathanMR2
If you want to benefit from a mod like this the its worth investing in a decent filter. Id go for an Apexi Cone filter as featured in the PPE Cold Air Intake. I saw gains from it on the PPE i had.
mr mr2
this is the filter that came with it
Excelsior
never heard of the, I agree with Nathan I'd stick an Apexi on
westcoast
The cheapest way is to just remove the pipe after the airbox=instant growl.=FREE
Even got some compliments on the sound  s:) :) s:)
Might lose some hp in high temperature situations, but the sound is worth it  s:) :) s:)  and you can keep the good filter capabilities of the stock unit.
I think the sound matches the car real nice, deep and subtle but powerfull.
chris3boro
Quote from: "westcoast"The cheapest way is to just remove the pipe after the airbox=instant growl.=FREE
You mean the pipe that the Markiii pipe replaces?
westcoast
Yes, that's the one!
There is also a resonator in the first bend of the intake that could be removed, haven't tried it yet.
The car then growls when you give it 80%+ throttle, gives a lovely bass sound in lower revs and peaks at around 3800 rpm.
I've just done this. By accident really as I heard a rattle and noticed I hadn't put it back properly last time and it came loose. Wife needed the car then so I just pulled it out.
Great noise!! Love it. Don't want to see what it's doing to intake temperatures though
Sent from my iPhone using Tapatalk 2
