Gutted my speakers now stuck!
Started by amz91, August 8, 2013, 18:00
amz91
Think Iv done it wrong lost on what to do next ?
Blue 2000 pfl roadster, gutted pre cats, The Ultimate Gear Shift Cable Bushings, Markii pipe, devs door sills, MR2 leather armrest, JDM bonnet badge, sp body brace, edge speakers, powder coated alloys, Vogtland lowering springs, ROC drop links, EBC brake pads, toyo proxes, FL side vents, FL door arms, FL control unit... more to follow \":)\"
AckersMR2
Rip out the white plastic speaker plug socket from the grey speaker mount leaving a hole that you can feed the speaker wire through. Cut off the white plastic plug from the speakers and fit some spade connectors that will slide onto your new speaker connections.
If you look at my post here on the last page I've put which wire is + and -  s:) :) s:)
Re: Fitting New front speakers !!!!! All explained
 l viewtopic.php?t=144#p440729 l
My only car is a Ducati
amz91
AckersMR2 ur a life saver!! How did u get the white plug socket out? im struggling :-/
s12vea
Just cut the wires the put crimp connectors on or even better solder them direct to the terminals on the speakers
Another one won't hurt  .....
amz91
Il have get some spade connectors, I'm bloody lost saw this
And haven't a clue!
AckersMR2
Quote from: "amz91"AckersMR2 your a life saver!! How did u get the white plug socket out? I'm struggling :-/
If I recall just brute force and ignorance  s;-) ;-) s;-)
amz91
Quote from: "AckersMR2"
Like this ? Haha
s12vea
Haha I just got some big wire cutters and twisted it off.
AckersMR2
That looks like the cable that goes from the tweeter to the crossover or if you don't have separate crossovers then to the main speaker. Try dropping a PM to Stargazer30 as I think he has installed a set of those in the past?
AckersMR2
Quote from: "amz91"Like this ? Haha
Yep looks just like mine  s:lol: :lol: s:lol:
AckersMR2
Check the depth of your new speakers, if there's plenty of room between the back of the speaker and the door skin then rip off that cardboard and foam from the plastic mount, otherwise the front of the speaker rim might touch the door card. If I recall I ripped it off.
AckersMR2
Quote from: "amz91"Il have get some spade connectors, I'm bloody lost saw this
And haven't a clue!
Connect the spade ends to your speakers and the wire ends to the Toyota speaker wire in the door. If you look in the box you might find a wiring diagram, if not look here  s;-) ;-) s;-)
 m http://edgecaraudio.co.uk/manuals/ed3_c ... manual.pdf m
amz91
Quote from: "AckersMR2"Check the depth of your new speakers, if there's plenty of room between the back of the speaker and the door skin then rip off that cardboard and foam from the plastic mount, otherwise the front of the speaker rim might touch the door card. If I recall I ripped it off.
Your joking I ripped this off by mistake then thought s*** that wasn't suppose happen and stuck it bk on! Haha  s:-D :-D s:-D
s12vea
Make sure you flash tape the doors it makes a massive difference
amz91
Thank you both, will do this either 2mora or Saturday.
I don't know what I'd do without this forum!
Iv pm'd stargazer30  :-) :-) :-)
