TomAky Westfield SEIW
Started by tomaky, September 2, 2013, 20:48
0 Members and 5 Guests are viewing this topic.
Quote from: "s12vea"
Quote from: "shnazzle"
Quote from: "1979scotte"Cant believe Tom is going to get his running properly before Helens!
 s:) :) s:)  Haha. Helen's has been roadworthy for months! hehehe
Surely there is a difference between roadworthy and running properly..?! Lol
Sshhhhh...you talk too much
tomaky
Quote from: "tomaky"Perhaps a meet if it passes its MOT haha.
hmm...a stationary meet?  s:) :) s:)  I don't want to be near you when you're "trying out" the car hahaha
Dotn worry you wont be you will be a mile back  s;) ;) s;)  wahey.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
tomaky
Amen brother  s;) ;) s;)
will see what happens Tuesday that's the biggest upcoming speed bump to navigate.
Westfield Seiw
Ex - 2003 Sable
tomaky
MOT passed no advisories.
Westfield Seiw
Ex - 2003 Sable
 s:bounce: :bounce: s:bounce:    s8) 8) s8)
s12vea
 s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:
Ex TTE Turbo
Another one won't hurt  .....
tomaky
AND breathe haha
Westfield Seiw
Ex - 2003 Sable
Jrichards20
Quote from: "tomaky"MOT passed no advisories.
how much was the bribe?
Street Triple 765 RS
tomaky
£350 :O ha
Westfield Seiw
Ex - 2003 Sable
tomaky
New studs and nuts ordered for the turbo, the current ones are goosed.
Westfield Seiw
Ex - 2003 Sable
tomaky
Rebuilt the turbo up, dropped the exhaust off to have a new flexi welded in, removed all the charge cooler gear. Removed the pillar pod, that's basically scrap as are the gauges likely, due to incorrect fitting the gauges have taken on water, Removing the pod itself has met a similar demise due to fitting it was a nightmare to get out and hasn't lasted the journey. Started tracing back the engine bay additional sensors back into the the loom, swapped the braces back over to the sable for the third time. Next step dropped the suspension and remove the gb to get the clutch out. remobilise blue get her out of the garage then fit the chargecooler kit and under brace. then transfer the centre pod gauges to sable. that just leaves one weekend where i need to fit the sump/SW plate and oil pressure sensor, clutch and turbo back, oil in coolant in drive.
Westfield Seiw
Ex - 2003 Sable
s12vea
You make it sound so simple  s;) ;) s;)
Hopefully you can then drive it
Ex TTE Turbo
tomaky
Its becoming simpler, i could def drop the susp blindfolded haha. Hopefully Before CMAS.if not between cmas and new year.
Westfield Seiw
Ex - 2003 Sable
tomaky
Not particularly looking forward to dropping the box if im honest.
Westfield Seiw
Ex - 2003 Sable
MR TWO
Progress!
cabbydave
Think I will have to get mine done now. Just about to order a cross member from toyota for the silver car be rude not to slam the turbo on at the same time
tomaky
well if you get your self up here al show you how to do it  s;) ;) s;)  tehe
Westfield Seiw
Ex - 2003 Sable
cabbydave
I will come up in the turbo then fella with my Apexi plug and play ecu. Did I tell you you dont have to make the apexi fit the loom it plugs straight in?
tomaky
Shame its a crap ecu tho...
Westfield Seiw
Ex - 2003 Sable
Quote from: "tomaky"Shame its a crap ecu though...
Its not exactly state of the art it doesnt even have a map sensor but it does plug straight in.
tomaky
Faster is not always better a suppose is the morale of the story.
Westfield Seiw
Ex - 2003 Sable
cabbydave
Moral is get it right first time
s12vea
Quote from: "cabbydave"Moral is get it right first time
Spot on !
Ex TTE Turbo
Spot on !
Cant disagree with that.
Also take your time and get one job right before moving on to others.
Plan for the worst not the best.
If it can go wrong it will go wrong.
cabbydave
Spot on !
+1
