TomAky Westfield SEIW
Started by tomaky, September 2, 2013, 20:48
tomaky
Scratch that the cars 1.8 without mirrors a think.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
tomaky
Ot uh I go to view potentially my new daily tomorrow poor MR2.
Westfield Seiw
Ex - 2003 Sable
tomaky
Just filled the boot of my new passion wagon with mr2 parts out of the parents garage 😂 even got a engine block in the front footwell.
Theres still a built engine to move tho 😩 need to get 2 big strong mates or a engine hoist.
Westfield Seiw
Ex - 2003 Sable
tomaky
 Been busy in the garage. To boards up with thinks mounted. Got abit bored so threw some decoration up. Stews @stewart@boro lakes poster and burtie bus are present.
Westfield Seiw
Ex - 2003 Sable
s12vea
Looking good
Nice wide garage you have
Did you seal the floor?
Ex TTE Turbo
Another one won't hurt  .....
puma2
 :) keep it going  :) always a work in progress :)  :)
tomaky
Quote from: s12vea on August 24, 2021, 14:25Looking good
Did I seal under the floor tiles?
Westfield Seiw
Ex - 2003 Sable
s12vea
Quote from: tomaky on August 25, 2021, 13:40
Yes or just tile over
Ex TTE Turbo
tomaky
Quote from: s12vea on August 25, 2021, 13:42
Gung-ho with the tiles :)
Westfield Seiw
Ex - 2003 Sable
tomaky
We now have electricity in the garage! it has highlighted that the walls needs more paint!
Westfield Seiw
Ex - 2003 Sable
tomaky
2 6ft led spars and 2 double plugs.
Westfield Seiw
Ex - 2003 Sable
cptspaulding
tomaky
Ive not been having fun... id not driven the proka for 3 weeks as the weathers been awful, went to take it out and the cross over pipe on the rear brake caliper was leaking... Replaced the cross over, decided it was time for a brake flush. snapped 1 out of 8 pigging bleed nipples. had all sorts of fun with that, i am now going to have to heli coil it. The saga isn't over there. Its had new brake lines in the past and they work fine the fittings are cheap mild crap. I tared at the brake line into caliper fitting for a week throwing wd at it. finally took to it with a spanner and butane torch on Saturday an with about 1 fingers worth of force it rounded. Ended up removing it with stilsons, one the fitment moved sadly it took the pipe with it :( I've ordered a replacement oem pipe for £20. now my problem it the rest of the pipe is still attached to the hose and doesn't bleeding swearing sodding want to come apart.
Westfield Seiw
Ex - 2003 Sable
This does shake my faith in porsche build quality tbh.
tomaky
#439
None of the above is Porsche build quality, the brake lines are aftermarket, TBH there copper pipe bent up.
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on November  9, 2021, 20:41None of the above is Porsche build quality, the brake lines are aftermarket, TBH there copper pipe bent up.
Typical porsche fan boy.
Denial isn't a river in Egypt.
tomaky
#441
So the Porka is now ready for MOT again!! bit of a interesting evening, i finally got my engine stand back from a friend and we brough t the stand and the turbo cars engine to the garage. Definitely found what blew on it...
When the Engine and turbo setup was in Nath's car they had issues at mapping and it wasnt holding the full 10psi. It sat at about 7. Making 200ps not 250ish. I think through the reinstall of that engine and turbo we fixed some of the issues.
I take full blame for it blowing, ill get that out early. I believed it would still be running the very safe 200ps. So i did proceed to give full beans! It would appear we might have made 2 much power.
Picture to follow from phone.
Westfield Seiw
Ex - 2003 Sable
tomaky
Westfield Seiw
Ex - 2003 Sable
tomaky
This is a tough 1
The sable is gone...
Westfield Seiw
Ex - 2003 Sable
Chilli Girl
tomaky
Cars gone but im still here! New car coming with abit of luck just not a 2.
Westfield Seiw
Ex - 2003 Sable
tomaky
I dont drive enough! Took the porka out for a drive with a friend on his bike! Big grin on the face! Might well nip to the Wensleydale cheese factory tomorrow! The same again Tuesday in the new car if anyone wants to come!
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on February 26, 2022, 00:38I dont drive enough! Took the porka out for a drive with a friend on his bike! Big grin on the face! Might well nip to the Wensleydale cheese factory tomorrow! The same again Tuesday in the new car if anyone wants to come!
I do but it's a long way to come and nothing decent to drive.
tomaky
Quote from: 1979scotte on February 26, 2022, 10:03I do but it's a long way to come and nothing decent to drive.
You wont behave ;)
There is a new car on the scene it is absolutely mental. Its also broken!  :o  :o
Westfield Seiw
Ex - 2003 Sable
