Caliper refurbishment, brake hoses and fluid!
Started by tricky1138, February 28, 2014, 09:00
tricky1138
So after getting an advisory on my MOT and knowing the handbrake was rubbish anyway, I'm looking at replacing the rear callipers.
I managed to pick up a pair of old calipers and going to get the Big Red refurb kit.
I have a local guy that will shot blast them for me then I'll paint them up.
Question is do I need to totally dismantle them before blasting or leave it till afterwards? My concern is that the cylinder might get damaged during the process if I remove the piston?
Anyone done it before? Any recommendations on what to remove?
Caliper as it stands :
Also been looking at changing the brake hoses while I'm on. Are the uprated ones worth it? Is it worth doing the rears? Been looking at the Hel ones. Any good?
 m http://www.brake-lines.co.uk/hel-brake- ... -2000.html m
Also while I'm there, is it worth changing to 5.1 fluid? I'm only planning on changing the rears at the moment. Would it be better to change the fluid later on after I've done the fronts too?
tomaky
out of interest how much is the kit? and the blasting?
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
I got a pair of refurb calipers off eBay for £60 each (after surcharge refund) and I was impressed, nicely blasted, painted, etc.
I am fitting hoses too, you might as well when your in there doing it all anyway. The rubbers are probably quite perished by now and it's not a job you'd probably rush to do again just to replace the hoses in the future. HEL are quite highly rated, I would go for them
tricky1138
Quote from: "tomaky"out of interest how much is the kit? and the blasting?
The Bigg Red kit is £30 each for a refurb diy. I don't know the price for them to do it.
I can get them shot blasted for £10 then it's just a paint with some hammerite.
Think I'm going down the Hel route while I'm there.
Just deciding whether to change fluid now or later!
tomaky
ive gone HEL and 5.1 dot, just get it done while your there  s:) :) s:) , ill be changing a caliper near future, ill buy buying a refurbished unit, mines sticking deciding wether to do it now or after my next pay as im travelling to sheffield 3 hour drive next friday and back ha
Westfield Seiw
Ex - 2003 Sable
tricky1138
Ok, I'm going down the Hel route with 5.1 fluid.
Just need to know what to do about shot blasting the old calipers.
Should I remove the piston before or after blasting?
Should I remove everything else too?
tomaky
Id just splash out if it had been me, might be worth replacing the springs though.
Westfield Seiw
Ex - 2003 Sable
Quote from: "tricky1138"Ok, I'm going down the Hel route with 5.1 fluid.
I'd definitely remove the pistons. Don't want to damage the sleeves and get grit in between.
Are these the ones I gave you?  s:) :) s:)
tricky1138
Quote from: "shnazzle"I'd definitely remove the pistons. Don't want to damage the sleeves and get grit in between.
Yeah they are Patrick.   s:) :) s:)  Wasn't going to name names in case you didn't want to!
And was just worried about the shot blasting damaging the part the piston sits in if it was removed!
Now looking again at the Bigg Red kit and it doesn't include a new piston!
Is a new one necessary or just best practice?
Haha no worries. I'm sure favours will be returned in the future  s:) :) s:)  Car Karma haha.
 I wouldn't replace it unless the sleeve was damaged or there was any evidence of wear. Don't know how much a new one is mind. For a few quid it's worth it  s:) :) s:)
I see what you mean though...hmm...there's a video of them shot blasting a caliper on the bigg red website. Did they remove the piston?
tricky1138
Couldn't find a video but did find the step by step guide and that removes the piston before blasting.
Have emailed them for price of pistons as they're not on the website - the mk 2 ones are £15 though.
Also asked for fully refurbished price and will add it all up and see how close it is as to which way I go.
Just a waiting game now.   s:( :( s:(
tricky1138
Digging up my old thread as it's took me this long to decide!
Well actually decided and changed mind three times!
Now getting some newly refurbished calipers, and have ordered some new hel braided hoses.
Now onto brake fluid! I know I need 5.1 but any recommendations for make and where from?
Also how much will I need?
I'm also presuming when I change my calipers and hoses that I just let all the old fluid run out then put the new stuff in and start bleeding them?
Don't let the reservoir run dry which will draw air into the system and make bleeding much harder.
AndyM
I may be wrong on this (I'm going to be hassling some people on this myself soon when I fit my braided lines) but one method I've read is to pipet/syphon off the bulk of fluid from the reservoir. Then refill it up with the nice new fluid and force it through the system (and each line/caliper) by bleeding it, making sure you top up the reservoir as you go. That way you avoid introducing air into the system but it takes less time to get it all flushed through.
Good idea. I just pumped the pedal to flush it out of the drivers side front to achieve the same effect  s:) :) s:)
Jandaw
Chatting to the lads in my local tyre depot while they changed my oil they offered to pressure change the brake fluid when I've got my new callipers etc. That way it's just a matter of cracking the bleed valve till new fluid runs through then closing.
Recommended Hel hoses and 5.1 fluid just need to decide which discs and pads now. Object of the exercise?  2 years freedom of worry at MOT time more than anything.
Fancy grooved and dimpled but not drilled discs. Any suggestions?
Ebc are good
tricky1138
Daft question but will any 5.1 fluid be ok?
Been to a couple of local shops and all they have is Carplan, carcare or the like, no major names.
Any good?
tomaky
Ive got Motul 5.1dot off camskill.
Westfield Seiw
Ex - 2003 Sable
tricky1138
Quote from: "tomaky"Ive got Motul 5.1dot off camskill.
And is 500 ml enough?
tomaky
I was advised to get 2 of the 500ml bottles i had spare in 1 but i have had to rebleed due to claiper changes since so its good to have the 2nd bottle.
Westfield Seiw
Ex - 2003 Sable
tricky1138
Have ordered a 1 litre bottle of Toyota 5.1
Same thoughts as you - will be changing front calipers / hoses later so will need more fluid for that!
tomaky
That will do the trick  s:) :) s:)
Westfield Seiw
Ex - 2003 Sable
tricky1138
Reviving an oldish thread as I've finally got a weekend free to swap my calipers!   s:D :D s:D
Just a quick question - should I attach the new Hel hoses to the calipers and just take the whole caliper and hose off in one go or is it recommended to connect hose to car first then the caliper?
Any other tips from the professionals?   s:wink: :wink: s:wink:
AndyM
Attach the line to the car first. You have to orientate it to fit the slide clip in which holds it in place (and it only goes in when in two positions 180deg apart) but then orientate the hose itself to avoid rubbing on the body/wheel.
Plus it helps to be able to spin the line to get it seated nicely in the flared nut.
I sound like an expert but actually I pretty much just watched Spit do mine 2 weeks ago.  s;) ;) s;)
