Alex's 2ZZ Swapped MR2 Roadster
Started by Alex Knight, September 1, 2013, 08:26
lamcote
#175
Do you mean a standard gear cage instead of a quick shift? If so why is the quick shift so bad? Thanks
justinread72
#176
How is the exhaust ? Is it better than the old one ?
Quote from: "lamcote"Do you mean a standard gear cage instead of a quick shift? If so why is the quick shift so bad? Thanks
I had a standard cage with the shifter cut down to reduce the throw.
I found that it baulked going into 2nd gear on track a few times at very high revs. This was due to the lack of leverage.
Quote from: "justinread72"How is the exhaust ? Is it better than the old one ?
I'd say so chap. It's really quite loud, but seems like it'll still pass trackday static testing. Reckon it's still under 100dB @ 4500RPM.
SDB278
#179
Nice car! Have enjoyed reading this thread.   s:) :) s:)
Like the front splitter, do you mind if I ask which one it is? And do the rozzers give you grief for the front plate?
Huambo81a
#180
Fantastic,
I wish i was mechanically minded, been quoted £4500 for the same job . . . . .  (sad face)
2ZZ - Apexi PFC - Proflow Exhaust - Yellowspeed Coilovers
cabbydave
#181
Quote from: "Huambo81a"Fantastic,
Who by?
Quote from: "SDB278"Nice car! Have enjoyed reading this thread.   s:) :) s:)
Thanks. It's an EZ-Lip from the states. Think I got it from Amazon.
And no, I've not been stopped by the police at all.
I did however receive a smart-alec remark from one of the customs police about the plate on the way to Le-Mans, but I just ignored him!
So, a few updates.
I've fitted a Personal Neo Grinta steering wheel and Momo boss. It's 330mm in suede with red stitching (to match the Recaros and gear gaitor). Apologies for the crap pic, but the light was fading.
I've also now replaced the Meister-R coilovers with some TEIN Superstreets and TEIN EDFC I sourced from Japan (via Streetercorp - brilliant service once again).
The wiring has been run to the strut tops for the EDFC motors, but I've not yet had chance to wire the controller in, will update when I can. It allows me to adjust the damping force from inside the car  s:) :) s:)
Initial impressions with the shockers set to full soft are that the ride is much more compliant than the Meister-Rs, especially the primary (low speed) ride.
The spring rates are 3KG/mm (Front) and 6KG/mm (Rear). I haven't had them on track yet, but I expect them to be similar to the Meister-Rs when wound up.
I've also fitted a Pioneer SPH-DA120, which has Apple CarPlay included - this is excellent, I'm really pleased with it. I listen to a LOT of music via Spotify, and the application interface is spot on. Plus you have the added bonus of being able to use Apple Maps/Nav, which means I don't need an external Sat-Nav either  s:) :) s:)
Glad you are happy with the tein.
From memory they were a lot of money from new.
I found them used on  m http://www.auctions.yahoo.co.jp m
Quality bit of kit.
Nice day today, and I had a couple of hours to spare, so I thought I'd drag the car out and give it a polish.
I'm always amazed at how well it comes up, the panels are like glass when you run your fingers over them.
suj
#187
Pics don't work for me Alex
TEIN EDFC finally fitted over the weekend.
Massive thanks again to Andy at Bonsai Car Services.
It's great to be able to adjust the damping from inside the car, at the touch of a button. Will be very handy on track, as I will be able to adjust the balance of the car without having to come into the pits.
Haven't yet managed to stick the controller down properly, but it hides away nicely in the dashtop cubby.
FYI, anyone that wants to fit EDFC, the motors DO clear the front and rear bonnets with no modification.
Alex how does the edfc connect to the strut?
Do you screw it on?
 Basically what I'm getting at is whether it would work with setting BC or MeisterR coilovers.
Steve954r
#190
Ok what size is the plate and where did you get it? I need one that size
Quote from: "shnazzle"Alex how does the edfc connect to the strut?
Do you screw it on?
Yes, its screws on.
Can't speak for whether it would work with Meisters, the installation procedure is quite specific to ensure the dampers are set and can adjust properly.
Quote from: "Steve954r"Ok what size is the plate and where did you get it? I need one that size
I have no idea what you're talking about?
I know i shouldn't mention this but have you seen the edfc active pro, same motors but g force adaptive settings from a new black box.
Quote from: "rbuckingham"I know i shouldn't mention this but have you seen the edfc active pro, same motors but g force adaptive settings from a new black box.
Yes, I did consider the pro version, but I decided that I want the damping to remain static for a predictable balance on track. I can't be doing with a constantly, subtly shifting balance.
Steve954r
#195
Quote from: "Alex Knight"
Sorry, front number plate
Pretty sure the size is 12" x3 ".
Can't remember where I ordered it, but it was online somewhere.
Steve954r
#197
Quote from: "Alex Knight"I have no idea what you're talking about?
Many thanks
swiftyds
#198
Hi, I've been looking at getting a Pioneer SPH-DA120 - presume this just slotted in OK along the same lines as any other double DIN head unit would?
Quote from: "swiftyds"Hi, I've been looking at getting a Pioneer SPH-DA120 - presume this just slotted in OK along the same lines as any other double DIN head unit would?
Yes, standard double DIN fitment.
Great choice, I'm really pleased with the unit.
