Door speakers
Started by Pavett1990, May 17, 2014, 12:50
Pavett1990
Hey guys, looking to modify my boot build, looking to take one of the 12" subs out and put the other in the middle with 2 6x9s each side.. Im looking to upgrade my door speakers at the same time.. What size speakers are needed?
AckersMR2
16.5's I believe?
My only car is a Ducati
Yeah, 6.5" = 16.5cm = 165mm
If you're also running wire this might come in handy  s;) ;) s;)   m http://www.midshiprunabout.org/mk3/the- ... -the-door/ m
AndyM
I don't want to sound all 'audio snobby' (and technically its off topic) but what is the purpose of the 6x9's?
With the old lot I used to hang out with who did competition builds both for SPL and SQ the 6x9 was looked upon as a bit of a 'jack-of-all but master of none' speaker, hence why they were very popular for quick and dirty upgrades in old Fiesta/Nova parcel shelves, etc...
If you want more rich bass/mid-bass then you could consider matching the 12" with two smaller subs (or mid-bass comps) with a nicely set crossover/EQ to give each size the optimum signal. If it is rear fill you want then you would probably be better off with some 2-ways (and fairly small and mounted high) as it's going to be too close for a large set to mix well (and the higher frequencies will be muffled by the seat).
I thought I'd mention it as if you are buying some front comps at the same time you could look at matching/complimenting the rears.
As I say though, I'm just sticking my nose in so feel free to ignore me.  s:) :) s:)
Pavett1990
Lol thanks for replies guys.. Amdy.. Thanks for the info im not sure what im going to put in but the info will help thanks
Pavett1990
Are there any adapter kits needed?
vincenzo
I've read that the stock plastic mounts can be used by removing the stock speakers which are glued to them.
The plastic mounts also provide a bit of water protection.
If you want to  change the sound of your subs then you can maybe just modify your box, such as port length and/or size, add some bracing, and add filling. As Andy said 6x9's are a good jack of all trades but not as good as some subs with components. Adding some small components or coaxials would be a nicer sounding rear fill solution.
If you've got a ballsy amp then maybe you just need to upgrade your alternator and it's wiring?
fyi mdf speaker mounts provide better SQ than plastic ones.
you may wana consider changing for an under dash sub... they're pretty good.  s:) :) s:)
I see people using 6x9's and they're not too bad - just not as good as an old fashion sub!
maybe you just need a better HU with more control over the EQ...  s:) :) s:)
