2zz turbo
Started by gazza-blackpool, July 7, 2014, 23:53
gazza-blackpool
I'm thinking of 2zz turbo. What kinda turbos am I to use etc?? And can I use a piggyback ecu???
Piggy back should be ok if the engine staying standard with a turbo bolted on. Turbo wise it needs to be fairly large due to the cfm requirement upon lift.
gazza-blackpool
My pals got a Scooby Sri turbo will be up for sale soon may get involved:)
2zz is a fairly high compression engine (it's designed to be high performance NA) so you will need to be pretty careful with Turbo choice.
Quote from: "gazza-blackpool"I'm thinking of 2zz turbo. What kinda turbos am I to use etc??
Any one you like. As long as it fits.
Quote from: "gazza-blackpool"And can I use a piggyback ecu???
Of course you can. You can use anything you like. As long as it fits.
Quote from: "Wabbitkilla"2zz is a fairly high compression engine (it's designed to be high performance NA) so you will need to be pretty careful with Turbo choice.
+1 i know some people get away with 12 psi but i would stick at 8 as a safe place, but others might know better
To be honest, if I was looking at a 2zz type of project, I would have to say supercharging is the way to go. A Rotrex installation would be a sensational choice.
Quote from: "rbuckingham"
Quoting arbitrary psi values is utterly irrelevant.
Different sized compressors have different efficiencies.
(Generally speaking) the larger the compressor, the more efficient it will be. Therefore the charge temperatures and flow rates will be different for different turbos at the same given boost pressure.
It's much more complicated than you make it appear to sound.
Quote from: "loadswine"To be honest, if I was looking at a 2zz type of project, I would have to say supercharging is the way to go. A Rotrex installation would be a sensational choice.
That's what I was thinking, the corolla engine was supercharged wasn't it
Yes, they did the Corolla Compressor with a positive displacement supercharger. Lotus had versions of Elise and Exige similarly enhanced.  Very nice!
Quote from: "Alex Knight"
that is true but the more the charger makes over what the engine uses increases pressure and air temp has effect on pre detonation. So yes bigger the charger the more efficient it is so air temps are lower at a certain pressure as that is determined by the cfm of the blowers output at that time and the engines cfm usage at the time. Of course the lower the air temp the more you can turn things up as at the end of the day the only thing you really need to watch is the knock.
i learnt alot on it during building my turbo kit even tho its for a 1zz.
Quote from: "loadswine"Yes, they did the Corolla Compressor with a positive displacement supercharger. Lotus had versions of Elise and Exige similarly enhanced.  Very nice!
I love OEM things like that, I'd love to swap one into a roadster, shame there aren't a few more inches to play with!!
Quote from: "Meeerrrk"
it has been done before, but requires a hammer on the firewall   s:crazyeyes: :crazyeyes: s:crazyeyes:
Yeah, I get it's very very tight! And the corolla ECU can't be used so it all starts getting expensive!
Speak to Paul woods as he managed it, don't know the full details but he might of found a workaround.
Paul woods was running both ECUs when I spoke to him.
gazza-blackpool
Cheers dudes. I would love to supercharge it but costs a lot. Turbo maybe the way forward atm
If costs are factored in, a decent 1zz turbo installation might suit just as well. The 1zz in turbo form can be quite satisfying to drive.
gazza-blackpool
I've already done the 2zz conversion so no point putting the 1zz back in lol
Ah, good reason then!  s;) ;) s;)
PaullyP2010
I have a 2zz Turbo - albeit the 2zz has had some tinkering too. I love it (although still not totally finished) but, the supercharger option is much more popular with the Celica crowd, and I would have gone that route if I didn't already have most of the Turbo bits from my 1zz. I would suggest speaking to viet - as he has a rotrex in his 2zz, and would be able to advise what you need / how easy it is.
Cheers,
Paul
2003 Sable Grey
Built 2ZZ Turbo with lots of other goodies.........
gazza-blackpool
I was speaking to Viet at weekend at jap show at Santa pod. I would love to go the supercharged route but Viet was saying it cost in excess of £4000 plus mapping and it's a lot outta my price range. Gonna be summet I do next year unless really cheap stuff come up. What turbo are you running paully???? Bhp etc???
