No alarm
Started by oxXLEWISXxo, October 16, 2014, 06:58
oxXLEWISXxo
My alarm on my car isn't working. I have done the tests to try and set it off but nothing. The doors lock with the central locking but then nothing happens. I can even open the door with the key and start the engine. Could this be the alarm ecu or something else.
2002 MR2 Roadster. Red. 39000 miles. TTE Twin pipes. Fast as Feck
Quick check... is it plugged in? It is located in the frunk under the spare wheel.
oxXLEWISXxo
Yes, that was the first thing I checked, still had the foam on the connection
Next thing would be to check the ecu which has a sensitivity dial on it.  Its under the rear bins.
