Hardtop
Started by Anonymous, September 23, 2004, 15:52
Is there a set time to wait for the softop to dry before putting the hardtop on or should it just look and feel dry?
I don't want a mouldy hood next spring!
  s:cry: :cry: s:cry:
I just clean it, chamois the water off and stck the top on - it's worked for two years so far with no mould or staining problems.
Darth Paul
As Sean said. Don't forget, the folded top sits on top of a very hot engine and the cabin's heaters will be blowing hot air throughout the winter. The folded top will get very dry.  s:wink: :wink: s:wink:
filcee
If you're worried about it, and have access to a garage or somewhere dry, you can always (carefully) use a hairdryer to dry the soft top before putting the hard top on.
I have  s:oops: :oops: s:oops:
Phil
2003 6-sp SMT in Sable
Just make sure there is no moisture under the flap around the rear windscreen. I washed the car and put the soft top down with a bit of residual moisture in there, and when I put the soft top back up, it was a bit wrinkly for a couple of days, but it eventually flattened out again.
  s:roll: :roll: s:roll:
