high power 2zz swap by jaworjawor
Started by jaworjawor, May 22, 2015, 20:26
Many have and state that it makes quite a big difference. Unlike a rear strut bar,which apparently is a waste of cash
It depends what suspension you have IMHO.
With coil overs I think as much bracing as you can get.
With standard ish spring and damper a mid style  brace would do for most.
We all have different ideas however so whatever works for you.
Edit
Obviously later cars benifit from better bracing from the factory so that makes a difference too.
Quote from: "jaworjawor"not sure if front strut brace helps anything, the front is very light in our cars. Maybe someone who installed one may tell if felt any difference
I fitted an upper front brace and felt it really helped with understeer on my pre facelift
jaworjawor
#53
hmmm I'm sold  s:D :D s:D
I remember when people said the middle brace wouldn't make as much of a difference on facelifts.... We all know better now!
I would like a complete set of ultra bracing but it's a little to rich for me.
Gone a bit off topic here tbh.
wotugonado
#56
Very impressive, id be interested in front arb if you do knock some up. Theres a massive gap in the market for those over here.
tomaky
#57
Like these lower strut braces! And the arb id definitely want some of that action! Im ultra front and rear top struts now.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
jaworjawor
#58
exhaust job done. I fitted oem 2zz manifold, just rewelded it by the flange. This is how oem manifold fits in mr2
Welding:
Manifold flange neede resurfacing after welding. Then we ported and polished the runners and port-matched to head (exhaust gasket was pattern)
The rest of the exhaust system are two big staight-through mufflers. The system starts at 2,75 then goes to 2,5 inch diameter
The whole system with manifold weight 13,5kg (oem mr2 is 28,5kg). Other jobs done recently:
-clutch cylinder
-throttle body connected
-fuel
-wiring loom
-gear selector linkage
-cooling system
-catch tank
-mocal sandwich plate and cooler lines
-axles and rear suspension
tomorrow is a big day  s:) :) s:)
jonty
#59
great progress, exhaust looks very nice indeed!
Nice job on the exhaust!
Nice exhaust!! Very impressive. And a hell of a diameter on those pipes.
jaworjawor
#62
Neeed help please! The engine doesnt start without a little gas, then dies if I let go the gas pedal. The revs are unstable. Theres engine light on but I dont know what code because it is jdm ecu. Did I swapped the tps wires correctly?
Paul1087
#63
mine did this when the temp sensor had failed.
try another one.
Mark A
#64
Mark A
Mark A
#66
An Ipad or similar device is now one of my essential tools
The wires are correct. Did you do the wires at the ecu end correctly?
jaworjawor
#68
to be honest I;m not sure if all the wiring is correct because I did it 2 months ago, but I remember I checked everything 5 times before doing anything, I think the tps wires I did good too. Tps was my frist thought, but if this is correct I'll try the coolant temp sensor, I have a spare. Then I think I will try to read the code and maybe that will help.
Another bad news is I lost coolant reservoir cap and cant driv without it   s:evil: :evil: s:evil:
We have had a few of those go missing lately.
Tomaky knows all about it.
tomaky
#70
Haha yes yes i do! Its a nightmare!
Westfield Seiw
Ex - 2003 Sable
jaworjawor
#71
is there any way to read jobd codes on mr2 spyder? Any way to bridge ports in diagnostic port somewhere and count the flashes?
There is the paper clip method
jaworjawor
#73
yes I read about that metod but do you know any details? Which ports to bridge, where are they?
pauls0212
red 2003 standard so far
