Red Exhaust Plume
Started by 1979scotte, June 8, 2015, 07:02
Oooooo nasty.
Leethesparky
#51
Oh!!!.. just found this thread.
Sh!t news mate, I did my turbo on my saab last year, the blades were wrecked. Bought a shiney new turbo for 600 quid and it lasted 2 weeks..  forgot to prime it before running it... ouch, bought a recon turbo and touch wood it's been ok since.
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
Nasty,what would cause that?
Something went into the blades is the only way it happen. No play on the shaft at either end but the balance will be off.
What would the cause of the red smoke be?
Red arrows formation flying?
Fuel additives. Rust in the exhaust. Not 100% but we found no evidence of coolant in the turbo.
Quote from: "Leethesparky"Oh!!!.. just found this thread.
Any ideas what caused your problems in the first place? We found nothing to blame the damage on.
Tbh my car seems to be running fine although i am trying to stay under 3k rpm.
carolineasb
#57
Showed my hubby pic of bent blades and said nothing else about the post and he immediately said "Bearing in a turbo has collapsed"  s:( :( s:( .  He says there must have been a blockage in the oil feed or a leak in the oil feed  s:( :( s:(
2006 (56) Blue TF300 (Newbie)<br />2001 (Y)  Silver (Oldie)
2004 (04) Black (The Inbetweenie) 2002(02) Red (Little Red Rocket)
Mikeymead
#58
You say that you found the water issue, what was it?  Is there end float on the compressor shaft?
I'm no expert Caroline but there is 0 play in the turbo.
Surely if the bearing is shot it would wobble all over the shop.
Doesn't matter really it's scrap either way.
Nope no float at all, to shaft was spot on with no play. Water was going as the rad is poorly. The orange I can only really think is down to fuel additives as it not doing it today, but you could see places that showed it had.
Quote from: "Mikeymead"You say that you found the water issue, what was it?  Is there end float on the compressor shaft?
The radiator leaks mike. We pressurised the coolant to over 15 psi and the only place we found any coming out of was the rad.
End float mate? Best explain that to me.
mrzwei
#62
[quote="1979scotte"
End float mate? Best explain that to me.[/quote]
Basically you have shafts rotating within bearings. You shouldn't be able to rock the shaft backwards and forwards, if you can then there may be an issue.
Ex.MR2 SMT sadly missed.
Mikeymead
#63
Good to know that the water leak is only the radiator, that's a cheap fix, shame about the turbo but at least the engine seems ok.
I was just thinking that if the turbo spindle was moving longitudinally in it's casing the compressor fins could be fouling on the case. Either way as you say it's toast. Not an expense you need at the moment.
It's so strange mike.
Something has obviously hit the blades but there where no bits of debris anywhere.
It has no play and spins freely.
Driving it you wouldn't know anything was wrong.
Confused.com.
Before i replace it everything will need to be checked.
Leethesparky
#65
Quote from: "1979scotte"
No mate, one min was ok, next min made horrible wining noise. Tracked it down to the turbo, took off the inlet pipe and it was completely knackered. Fan blades bent and mangled and the shafts completely collapsed.
I put it down to high mileage , one of those things. Found nothing obvious wrong and it's been ok for the last year
carolineasb
#66
Hubby says it wouldn't necessarily wobble about and it could have just been a bit of the bearing that has come loose  s:( :( s:(
tricky1138
#67
Just getting caught up on this after a weekend away at a stag do!
Well looks like good and bad news there Scotte.
Its always hard to diagnose problems when there are actually 2 different problems. You assume they are related when as you've found out it was just coincidental.
Hope you can manage to get it fixed. Looks like an easy, but expensive fix!   s:scared: :scared: s:scared:
This radiator as good as any?
 m http://m.ebay.co.uk/itm/281080296575?nav=SEARCH m
Its the cheapest i could find.
tomaky
#69
That will do the job  s:) :) s:)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
That's the one I've had for 1.5 years
Ordered.
Whats going on with the other bits that need replacing?
Awaiting wife approval mainly but also some checking to do about the technicalities
Good luck with that!  s;-) ;-) s;-)
