My Black 2003 Turbo Build - CrazySX
Started by CrazySX, July 23, 2015, 10:59
s12vea
Look at the tte installation manual I'm sure it will show you.
Ex TTE Turbo
Another one won't hurt  .....
CrazySX
Looking at it now, great document!!!
yep great doc. Page 50 - 52.
And for a real life pic.
 m http://mr2roc.org/phpBB3/viewtopic.php? ... 17#p210811 m
CrazySX
Thanks ardent that's very helpful! Only thing that worries me in that position is if it gets crunched on a hump!!!
I would say if it does then a lot of other bits will be the squish as well, as it is tucked up higher than the lowest point. red part of chassis.
Edit.
Having looked at it in the flesh, despite how it looks in the manual and the pics. It does actually sit on the angle and not tucked up as it looks.
Sorry about that. Came as a surprise to me.
Never caught mine yet mostly it's my mid brace that takes the brunt.
CrazySX
Ok so a couple of updates. Replaced my driver side seat belt last week as it was frayed.
Next jobs on the list are front brakes as the pads are worn thin and replace the rear subframe.
I found these pads  m http://pages.ebay.com/link/?nav=item.vi ... 68&alt=web m
 anyone tried them?
And thinking of going for drilled and grooved discs. Suggestions welcome.
CrazySX
Oh I also changed the oil in the gearbox last week. The oil that came out didn't look too clever
Also I would say just over a litre came out so probable the original factory stuff  s:o :o s:o
Anyway I stuck 2 bottles of this stuff in
 m http://pages.ebay.com/link/?nav=item.vi ... 74&alt=web m
What a difference!
CrazySX
Jobs left to do...
Replace subframe
Replace front brakes
Fit Tein S springs
Replace/refurb wheels
Wheel alignment
Do something with the front bumper I have not yet picked up  s:o :o s:o  fit splitter and SMD LED fogs (with halo)
Take out headlights, de-cloud, blacken, fit LED sides and HID mains
Paint and fit JDL skirts
Get Dings taken out  (next wknd  s:D :D s:D  )
And whilst doing all that collect parts for turbo build.
So far I have secured a oil drain. And have all the bits as listed at the start.
I need to get a TTE style intercooler. Or I am going to look at fitting a sidemount near one of the side ducts.
CrazySX
Today I started to clean the replacement subframe.
First I used a grease remover
Then I used washing up powder with a scourer  s:) :) s:)
Started with this
Ended up with this..
CrazySX
Next steps to get a wire brush on a drill and get all the surface rust gone.
Then a tub of hammerite and a can of bilthamber dynax.
Not sure if I should use a primer.. don't need it with hammerite rite?
jonty
#36
Is look at getting a tub of rust eater of some sort, may as well get the stuff out properly whilst you're putting in the effort.
For the brakes is consider getting yellow stuff rather than those pads you linked to, since is you're throwing a turbo at it you'll probably be arriving a bit more urgently than normal and a bit of extra power and fade resistance won't go amiss.. !
CrazySX
Quote from: "jonty"Is look at getting a tub of rust eater of some sort, may as well get the stuff out properly whilst you're putting in the effort.
The rust really ain't that bad. It's just surface rust. I have rust eater but hammerite is suppose to be good for it.
As for the brakes, what are yellow stuff pads like from cold?
I have yellow stuff with Grooved and drilled disks.
Stops well enough but is noisy.
Good from cold IMHO.
When I'm done with the disks I currently have will probably go back to stock disks.
CrazySX
That's interesting to know. I had grooved discs on a car once and they are noise and tend to create a lot more dust than normal.  Also the drilled discs can crack.
My discs are actually in decent shape just a bit rusty. Might just stick a set of stock discs on with good pads then. Somebody else has also recommended yellowstuff.
CrazySX
#40
My current discs and pads...
CrazySX
#41
So next steps..
Used the wire wheel first then the pad..
Got me to this..
CrazySX
#42
The quality of the toyota oem weld is shocking. There is weld splatter everywhere! !!  s:o :o s:o
So I took Jonty's advice and used this stuff on the subframe
I was hoping to get it painted today. But this stuff takes 24hrs to fully cure. Thanks Jonty :p
Got it in all the nooks and crannies..
CrazySX
#43
Now wait...  s:( :( s:(
jonty
#44
Quote from: "CrazySX"I was hoping to get it painted today. But this stuff takes 24hrs to fully cure. Thanks Jonty :p
Haha sorry mate, will be worth it though! Good effort, my brother's s2000, my mr2 and our jointly owned 200sx all need a lot of this type of love...  s:( :( s:(
jonty
#45
Oh, and as for brakes I never use drilled or grooved discs, seems all they do is wear pads faster, no benefit to performance and just cost more....
CrazySX
#46
Quote from: "jonty"Oh, and as for brakes I never use drilled or grooved discs, seems all they do is wear pads faster, no benefit to performance and just cost more....
My 200sx needs some of this too. Will hit that next. Need to do this first as it's my daily.
I see you're coming to Dong day, will be good to put a face to the name  s:) :) s:)
jonty
#47
I'm not confirmed yet as I don't have the car MOT'd, but yeah it'll be good to get along to a meet soon mate!
CrazySX
#48
Quote from: "jonty"I'm not confirmed yet as I don't have the car MOT'd, but yeah it'll be good to get along to a meet soon mate!
You got a whole week man, get on it  s:) :) s:)
jonty
#49
Yeah I know, but don't want to commit til I'm certain... Should be ok, all I need to do for the 2zz conversion is do the wiring changes (add 3 wires to the plug and move 3 wires) and I'm all set. I fired it up on the 1zz ecu and it worked fine, so that was a big milestone. (And a fvcking huge relief!!)
