My Sable 2005 MR2 - shnazzle
Started by shnazzle, August 27, 2015, 15:20
tomaky
From 112 to 113lbft? Haha
Sent from my CLT-L09 using Tapatalk
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Quote from: tomaky on March 19, 2019, 10:18
When you've not got a big fat porker every little bit matters.  :thebird:
Quote from: 1979scotte on March 19, 2019, 10:21
Damn right!
Well, put it this way, I get wheel spin rather easily now whereas before I had to force it, which my clutch would not thank me for
tomaky
That might be the most asbo thing I've read from you [emoji23] the r888s refuse to spin.
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on March 19, 2019, 10:29
Complete turd they span plenty at Scotch Corner.
So much that you had to be rescued.
Quote from: 1979scotte on March 19, 2019, 10:40
tomaky
Didn't have to be just had a bloody panic attacking girlfriend haha
Westfield Seiw
Ex - 2003 Sable
Yes I'm back obsessing about fueling and stuff, following the install of my Zero manifold and new cat.
Go on, get it out your system...
In the meantime, I've been collecting logs to try to determine where my map is failing me and causing the issues.
Created a spreadsheet that creates a nice little 16x16 table based on loading in logs from Torque Pro on rpm, throttle and LTFT1/2. Finds all the values, splits them across throttle and rpm and averages the trims.
Result so far after just 3 logs-worth are interesting already.
You know what that's telling you don't you?
Your car knows Kung Fu...
Quote from: Call the midlife! on March 19, 2019, 22:14
Que?
delhusband
never mind that, a man of your talents with all those divide by zero errors!  ;)
Quote from: delhusband on March 19, 2019, 22:46
Don't even..
I was going to add error handling  into the formula but its already quite long!
Once I start adding more parameters (timing and o2 voltage) I'll switch to VBA to do the analysis :)
I reckon if I do the same for o2 voltage and cross-reference against trims, I can get a decent impression of the stock target AFR map :)
0.45=stoich., so it should be easy to map out where it's targeting 14.7...which I think is damn near everywhere but full throttle
Quote from: shnazzle on March 19, 2019, 22:43
Que?
https://youtu.be/6vMO3XmNXe4
=IFERROR(<your existing formula>,"")
Will fix this. Sets all errors to blank cells.
Quote from: Alex Knight on March 20, 2019, 11:34
Did this on my version already.
But, with a few thousands rows of data so far, it has made it very slow. So, going down VBA route now.
There we go. Can now flexibly choose the table resolution as well.
I tried doing a 64x64 table which leads to even more interesting results.
The only thing I don't like is that I'm averaging the LTFT bank 1 and bank 2. The core assumption in that is that both sensors are equally accurate, and that fueling across both banks is similar. It hides that one bank could be running leaner than another for one reason or another.
What this tells me is that my low load areas are smashing but the part throttle areas not so much.
Good news is that it seems to be an almost flat value of about 7%. Easy fix!
Oil and filter change today.
This little doodad on the oil bottle is awfully handy
Whilst under the automobile I did see something I didn't like, engine mount rubber is just holding on on two sides. No wonder the head steady made such a difference :) Time for some Sikaflex treatment. Didn't have any in the house unfortunately:
Also took some pics of the cat:
The gaps on the sides are as it's made.
But doubtless it will be floppy.
Clean as thoroughly as you cam. Tooth brush, degreaser, then fairy liquid and then water.
Jack the engine to centre the bush.  Put goop in from both sides.
Leave jacked for 24 hours to cure.
Oh that's odd. At the top there I felt a load of rubber deposit like as if the mount had been attached there at one point.
Regardless, it's getting stuffed.
As usual the engine oil replacement job was 20mins to let it drip a while and replace oil and 40 mins to remove and replace the damn nappies! I hate those things
cptspaulding
Quote from: shnazzle on March 22, 2019, 13:10
exactly that  :(
in this pic, you can see an example of the extra bit of rubber-  It does not connect, it's simply a buffer.
smarty72
At the age my car has reached, I consider it a grown up, so I don't force it to wear a nappy anymore...
current: Astral Black FL
Ex: Forest Green 2003.
Quote from: smarty72 on March 22, 2019, 15:50
I know! But you know me... I get worried when people start talking about how the nappies help with airflow into the engine bay and even downforce/lift!
If someone could say, with some certainty, that it has no negative effects then they'd be off.
Concerns I have are:
- the gaping hole into the flywheel (like everyone else, my little plastic cover is long gone)
- excessive corrosion, as it is an all-year daily
- downforce/lift
- engine bay temps.
@shnazzle -
I've said previously that I believe manufacturer's do things for a reason. I can't see why Toyota would put the three ( is it in total) under trays on the 2 if there were not valid reasons.
The "concerns" that you have are likely among the "reasons".
Quote from: Joesson on March 23, 2019, 09:33
@shnazzle -
Exactly. They can't just be cosmetic.
What I do find ridiculous is the pointless oil draining "port" in the mid nappy. It's far too small so it just goes into the nappy and causes a massive mess and you can't get to the oil filter. Why would you drain oil without changing the filter.
So, on that note, Toyota designers can sometimes get it very wrong.
