RESOLVED- ultrasonic injection cleaning/rich running
Started by wotugonado, December 6, 2015, 15:05
The read out numbers that are pertinent to the diagnosis.
If it is everything on the screens, so be it. I didn't want to just copy all of it down if it wasn't necessary.
lamcote
What is the difference between the B1 and B2 fuel trims?
wotugonado
Ah OK so from what I'm led to believe the long term fuel trim should fluctuate between + or - 8 and this is acceptable. Anything over this is showing a problem either running lean+ or running rich -.
Mine were - 11 and - 13 and sometimes worse. I don't think it throws a code till you reach the 20s hence why no eml.
